How to get nRF52 to act as a central and a peripheral with FreeRTOS?
Hi Nordic DevZone,
I am currently trying to implement a system whereby a nordic nRF52 board scans and broadcasts in alternation, using freeRTOS tasks.
I have yet to find any example code that could lead me in the right direction. I was trying to start from scratch but I am having difficulties finding a way to efficiently architect the
code in an efficient and intuitive way. Is there potentially there is a good SDK example I can base my code on?
Any input is highly appreciated.
Thanks
  • All I could find, was this example:
    https://devzone.nordicsemi.com/f/nordic-q-a/41508/sdk15-2-freertos-ble-central-and-peripheral
    If this is not sufficient, or if you would like to get a more detailed answer, please tell me and I will ask for a comment from the freeRTOS expert on the support team.
    Simon
  • Hi Simon,
    I already saw this post and it wasn't as detailed as I was hoping for.
    Currently, I have two code bases where one acts as a peripheral and one acts as a central. I would like to create tasks to have the board act as both, and I would like to use a counting semaphore do to some inter-task communication, which directly controls components on the board such as an LED.
    In short, the final goal is to have some scanner that listens to a signal (a BLE advertisment from an external source), as well as be advertising itself and allowing a characteristic in a custom service to be written to.
    I am looking for FreeRTOS compatible code that could achieve the above specifications.
    Thank you,
    Daniel
  • I haven't tried this myself, but thinking out loud.
    It does not look like this is a difficult functionality to achieve. The initialization of both roles(peripheral and central) can be done in main function without any threads stated.
    • You can have two threads, one purely handling peripheral BLE events and the other purely handling central events.
    • The events that are received n the BLE event handler and can be forwarded to corresponding threads using message queues
    Apart from that, there should not be any architectural challenges you should see related to FreeRTOS.
