nRF52840 UART app_uart_init
Hi I plan on using two UART modules from the nRF52840 which is why I am trying to use the app_uart_init however at this stage I keep getting the following error:
undefined reference to 'app_uart_init'
Moreover what is the difference between UARTE and UART? or would you recommend using the Serial library instead?
#include <stdbool.h>
#include <stdint.h>
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "app_uart.h"
#include "nrf_uart.h"
#define UART1_TX NRF_GPIO_PIN_MAP(1,1)
#define UART1_RX NRF_GPIO_PIN_MAP(1,2)
void uart_error_handle(app_uart_evt_t * p_event)
    /*UART*/
    const app_uart_comm_params_t comm_params =
          UART1_RX,
          UART1_TX,
          APP_UART_FLOW_CONTROL_DISABLED,
          false,
          NRF_UART_BAUDRATE_9600
    uint8_t UART1_RX_BUF;
    uint8_t UART1_TX_BUF;
    const app_uart_buffers_t p_buffers =
          UART1_RX_BUF,
          255,
          UART1_TX_BUF,
          255
    app_uart_init (&comm_params,&p_buffers,uart_error_handle,APP_IRQ_PRIORITY_LOWEST);
  • Hi!
    What IDE are you using? You need to add the path to app_uart.h in your project, where the function is defined, so that the compiler can find it. It should be in SDK/components/libraries/uart.
    The nRF52 series has two UART peripherals, legacy peripherals (UART) and peripherals using EasyDMA (UARTE), which is a direct memory access module used to gain direct access to Data RAM.
    The advantages of the Serial port library over UART library is described in the documentation:
    This module allows to create and handle serial port instances. It is designed as a more sophisticated replacement for the app_uart module. The following are the advantages of this module over app_uart:
    • API is more generic and robust: you can read or write any amount of bytes.
    • Multi-instance capability.
    • The module can work in three modes: POLLING, IRQ, and DMA.
    • Calls can be asynchronous and synchronus (with timeouts).
    • Independent RX/TX FIFOs with configurable sizes.
    • Configurable RX/TX transfer buffers (smallest transfer slice).
    • Event handler (not mandatory).
    • Sleep handler (not mandatory).
    You can find an example of how to use the Serial library in the SDK.
    Heidi
  • Hi Heidi,
    Thank you for getting back to me!
    I am using Segger, as far as I know I added that path but I will check again.
    In which cases would you suggest using EasyDMA (UARTE) ? Apart from accessing the read/write data buffers in UART, what added benefits does it provide?
    Br
    Luke
  • Hi, in most cases, I would suggest using UARTE.
    Taken from the PS of the nRF52840, the main features of UARTE
    • Full-duplex operation
    • Automatic hardware flow control
    • Optional even parity bit checking and generation
    • EasyDMA
    • Up to 1 Mbps baudrate
    • Return to IDLE between transactions supported (when using HW flow control)
    • One or two stop bit
    • Least significant bit (LSB) first
    while the main feature of UART are
    • Parity checking and generation for the 9th data bit
    However, the power consumption when using UARTE is generally much higher.
    Heidi
  • both UART and UARTE have huge disadvantage - it's unable to use polling mode. Look at the piece of code of nrfx_uarte_rx function:
    do {
        endrx  = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_ENDRX);
        rxto   = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_RXTO);
        error  = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_ERROR);
    } while ((!endrx) && (!rxto) && (!error));
    Its endless loop if there is no incoming data. Who write code like this??
