LESC initialization on FreeRTOS
Hello -
We are also bumping into the problem described here, where it is not possible to initialize LESC when BLE is initialized from a FreeRTOS task. The nrf_stack_info_overflowed() function returns true, which causes the LESC initialization to terminate early with an error code. I believe that the nrf_stack_info_overflowed() function should not even be called when LESC is being initialized from a FreeRTOS task because the stack values are not relevant in this context. Searching for clues, I found this FreeRTOS commit, which suggests the same.
We are using the 15.3.0 SDK on a nRF52840-DK board. The 16.0.0 SDK has the same issue. We are linking against the no-interrupts version of the cc310 library, thought I don't believe that is relevant to this specific failure. In our sdk_config.h file we set both NRF_CRYPTO_RNG_STATIC_MEMORY_BUFFERS_ENABLED and NRF_CRYPTO_RNG_AUTO_INIT_ENABLED to 1. If I comment out the call to nrf_stack_info_overflowed(), the LESC initialization sequence completes without any errors.
Is there a workaround for this issue that doesn't require changing the SDK code? In other words, is there a way to enable LESC with Numeric Comparison when BLE is initialized from a FreeRTOS task?
Brian
