csense_pca10059 documentation/integration
I've integrated the "csense_pca10059" (SDK_16.0.0) into my application. I have only added the button (not the slider), and am getting some functionality from the cap sense routine, however:
- sometimes it does not detect a button press.
- sometimes it detects a button press when there is not one.
I expect to see these results as my physical set-up is probably slightly different from others. I would like to fine-tune the parameters so that my button works reliably. Here are my questions:
1. Is there any documenation for the csense_pca10059 library? If there is not, can you give a basic explanation of how it works (looks like A/D and oscillator may be involved).
2. Is there a way to directly log the A/D conversion values so that I can see the sensor values in real-time (I do have serial log running)?
Thanks for your assistance.
    How did you integrate the csense_pca10059 into your application? Which example are you using?
    Could you kindly check with the Adapt a simple example (without SoftDevice) section in this tutorial?
    -Amanda H.
  • Hi Amanda,
    I have no issue programming the dongle and the code has already been integrated into my application. I'm looking for details on how the example (csense_pca10059) functions. It is possible to use the example (csense_pca10059) on it's own, so you could address it from the perspective of looking at this example on it's own.
    Thanks.
  • Hi Amanda,
    I'd like to simplify this question. Let's just put it in the context that I'm using the csense_pca10059 example code, and I wire up a button (wire with metal pad attached).
    1. How to I determine the THRESHOLD_BUTTON value that I should use?
    2. How to I deter the RANGE value?
    3. How do I determine APP_TIMER_TICKS() value?
    4. Is there a way to add logging in real-time to the csense_pca10059 example, so that I can see what values are generated when button is pressed and not pressed?
    Thank you.
    If no information is printed out on UART or the values from the slider are meaningless, try changing the THRESHOLD_PAD_1, THRESHOLD_PAD_2, THRESHOLD_PAD_3, THRESHOLD_PAD_4 or THRESHOLD_BUTTON value in the main example file.
    The RANGE is the input variable of NRF_CSENSE_SLIDER_4_DEF for the Number of relative pads. It means that the slider in its handler will give values (1, steps_no).
     It depends on the number of timer ticks you want. Please see APP_TIMER_TICKS.
     In the Cense example, NRF_LOG_BACKEND_UART_ENABLED is enabled. You could use the terminal tool like Putty to see the log.
    -Amanda H.
  • I am seeing the UART messages when the button is pressed. What I would like to add to the log is the raw data, as this will help me calibrate the button. Can you suggest a way to do this?
