macOS Catalina unable to compile using SES or command line
Attached is Cmake error log from one of the failed builds.
This is a new MBP with freshly installed nRF Connect - following tutorial.
Anyway, I am not able to open a nordic project in SES nor build manually in terminal.
Tried both V1.0.0 and - V1.1.0 git branch.
Any suggestions is appreciated.
CMakeError
Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
Compiler: /Users/sindrevr/ncs/gnuarmemb/bin/arm-none-eabi-gcc
Build flags:
Id flags:
The output was:
1
/Users/sindrevr/ncs/gnuarmemb/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/libc.a(lib_a-exit.o): In function `exit':
exit.c:(.text.exit+0x2c): undefined reference to `_exit'
collect2: error: ld returned 1 exit status
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Compiler: /Users/sindrevr/ncs/gnuarmemb/bin/arm-none-eabi-g++
Build flags:
Id flags:
The output was:
1
CMakeOutput
The target system is: Generic - 2.0.99 - arm
The host system is: Darwin - 19.0.0 - x86_64
Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
Build flags:
Id flags: -c
The output was:
0
Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.o"
The C compiler identification is GNU, found in "/Users/sindrevr/ncs/nrf/applications/asset_tracker/testing/CMakeFiles/3.15.5/CompilerIdC/CMakeCCompilerId.o"
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
Build flags:
Id flags: -c
The output was:
0
Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.o"
The CXX compiler identification is GNU, found in "/Users/sindrevr/ncs/nrf/applications/asset_tracker/testing/CMakeFiles/3.15.5/CompilerIdCXX/CMakeCXXCompilerId.o"
Checking whether the ASM compiler is GNU using "--version" matched "(GNU assembler)|(GCC)|(Free Software Foundation)":
arm-none-eabi-gcc (GNU Tools for Arm Embedded Processors 7-2018-q2-update) 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907]
Copyright (C) 2017 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
