I am trying USB DFU trigger.
I have connected GPIO P024 to Reset port P018.
Bootloader is also programmed.
When I use nRF connect/programmer.
It's always waiting at "Using USB SDFU protocol to communicate with target".
Anything else I need to do for USB DFU trigger?
Attached the main.c, sdk_config.h and screenshot.
SDK 15.3.0.
PCA10056 DK.
ble_connectivity_s140_usb_hci_pca10056 patched.
/** * Copyright (c) 2013 - 2019, Nordic Semiconductor ASA * * All rights reserved. * * Redistribution and use in source and binary forms, with or without modification, * are permitted provided that the following conditions are met: * * 1. Redistributions of source code must retain the above copyright notice, this * list of conditions and the following disclaimer. * * 2. Redistributions in binary form, except as embedded into a Nordic * Semiconductor ASA integrated circuit in a product or a software update for * such product, must reproduce the above copyright notice, this list of * conditions and the following disclaimer in the documentation and/or other * materials provided with the distribution. * * 3. Neither the name of Nordic Semiconductor ASA nor the names of its * contributors may be used to endorse or promote products derived from this * software without specific prior written permission. * * 4. This software, with or without modification, must only be used with a * Nordic Semiconductor ASA integrated circuit. * * 5. Any software provided in binary form under this license must not be reverse * engineered, decompiled, modified and/or disassembled. * * THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES * OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE * DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE * GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /**@file * * @defgroup ble_sdk_app_connectivity_main main.c * @{ * @ingroup ble_sdk_app_connectivity * * @brief BLE Connectivity application. */ #include <stdbool.h> #include "nrf_sdm.h" #include "nrf_soc.h" #include "app_error.h" #include "app_scheduler.h" #include "nrf_sdh.h" #include "ser_hal_transport.h" #include "ser_conn_handlers.h" #include "boards.h" #include "nrf_drv_clock.h" #include "app_timer.h" #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" #include "app_timer.h" #include "ser_phy_debug_comm.h" #include "ser_config.h" #if defined(NRF_DFU_TRIGGER_USB_INTERFACE_NUM) && defined(QSPI_ENABLED) #define BOARD_DETECTION 1 #else #define BOARD_DETECTION 0 #endif #if BOARD_DETECTION #include "nrf_dfu_trigger_usb.h" #include "nrf_drv_qspi.h" #define PCA10056_PIN_RESET 24 //#define PCA10059_PIN_RESET 19 #define PCA10059_PIN_RESET 24 #endif #if defined(APP_USBD_ENABLED) && APP_USBD_ENABLED #include "app_usbd_serial_num.h" #include "app_usbd.h" static volatile bool m_usb_started; static void usbd_user_evt_handler(app_usbd_event_type_t event) { switch (event) { case APP_USBD_EVT_DRV_SUSPEND: break; case APP_USBD_EVT_DRV_RESUME: break; case APP_USBD_EVT_STARTED: m_usb_started = true; break; case APP_USBD_EVT_STOPPED: app_usbd_disable(); break; case APP_USBD_EVT_POWER_DETECTED: NRF_LOG_INFO("USB power detected"); if (!nrf_drv_usbd_is_enabled()) { app_usbd_enable(); } break; case APP_USBD_EVT_POWER_REMOVED: NRF_LOG_INFO("USB power removed"); app_usbd_stop(); break; case APP_USBD_EVT_POWER_READY: NRF_LOG_INFO("USB ready"); app_usbd_start(); break; default: break; } } static void usbd_init(void) { app_usbd_serial_num_generate(); static const app_usbd_config_t usbd_config = { .ev_state_proc = usbd_user_evt_handler }; APP_ERROR_CHECK(app_usbd_init(&usbd_config)); } static void usbd_enable(void) { APP_ERROR_CHECK(app_usbd_power_events_enable()); /* Process USB events until USB is started. This is related to the fact that * current version of softdevice does not handle USB POWER events. */ while (m_usb_started == false) { while (app_usbd_event_queue_process()) { /* Nothing to do */ } } } #endif //APP_USBD_ENABLED typedef struct __attribute__((packed)) { uint32_t magic_number; /* Magic number to verify the presence of this structure in memory */ uint32_t struct_version : 8; /* Version of this struct format */ uint32_t rfu0 : 24; /* Reserved for future use, shall be 0xFFFFFF */ uint32_t revision_hash; /* Unique revision identifier */ uint32_t version_major : 8; /* Major version number */ uint32_t version_minor : 8; /* Minor version number */ uint32_t version_patch : 8; /* Patch version number */ uint32_t rfu1 : 8; /* Reserved for future use, shall be 0xFF */ uint32_t sd_ble_api_version : 8; /* SoftDevice BLE API version number */ uint32_t transport_type : 8; /* Connectivity transport type, 1 = UART HCI */ uint32_t rfu2 : 16; /* Reserved for future use, shall be 0xFFFF */ uint32_t baud_rate; /* UART transport baud rate */ } version_info_t; #if defined ( __CC_ARM ) static const version_info_t version_info __attribute__((at(0x50000))) = #elif defined ( __GNUC__ ) || defined ( __SES_ARM ) volatile static const version_info_t version_info __attribute__ ((section(".connectivity_version_info"))) = #elif defined ( __ICCARM__ ) __root const version_info_t version_info @ 0x50000 = #endif { .magic_number = 0x46D8A517, .struct_version = 2, .rfu0 = 0xFFFFFF, .revision_hash = 0, .version_major = APP_VERSION_MAJOR, .version_minor = APP_VERSION_MINOR, .version_patch = APP_VERSION_PATCH, .rfu1 = 0xFF, .sd_ble_api_version = NRF_SD_BLE_API_VERSION, .transport_type = 1, .rfu2 = 0xFFFF, .baud_rate = SER_PHY_UART_BAUDRATE_VAL, }; static void on_idle(void) { if (!NRF_LOG_PROCESS()) { // Wait for an event. if (nrf_sdh_is_enabled()) { ret_code_t ret_code = sd_app_evt_wait(); ASSERT((ret_code == NRF_SUCCESS) || (ret_code == NRF_ERROR_SOFTDEVICE_NOT_ENABLED)); UNUSED_VARIABLE(ret_code); } else { // Wait for an event. __WFE(); // Clear the internal event register. __SEV(); __WFE(); } } #if defined(APP_USBD_ENABLED) && APP_USBD_ENABLED while (app_usbd_event_queue_process()) { /* Nothing to do */ } #endif } uint32_t timestamp(void) { return DWT->CYCCNT; } #if BOARD_DETECTION void pin_to_default(uint8_t pin) { if (pin != NRF_QSPI_PIN_NOT_CONNECTED) { nrf_gpio_cfg_default(pin); } } /** * Function for configuring UICR_REGOUT0 register * to set GPIO output voltage to 3.0V. */ static void gpio_output_voltage_setup(void) { // Configure UICR_REGOUT0 register only if it is set to default value. if ((NRF_UICR->REGOUT0 & UICR_REGOUT0_VOUT_Msk) == (UICR_REGOUT0_VOUT_DEFAULT << UICR_REGOUT0_VOUT_Pos)) { NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen; while (NRF_NVMC->READY == NVMC_READY_READY_Busy){} NRF_UICR->REGOUT0 = (NRF_UICR->REGOUT0 & ~((uint32_t)UICR_REGOUT0_VOUT_Msk)) | (UICR_REGOUT0_VOUT_3V0 << UICR_REGOUT0_VOUT_Pos); NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren; while (NRF_NVMC->READY == NVMC_READY_READY_Busy){} // System reset is needed to update UICR registers. NVIC_SystemReset(); } } #endif /**@brief Main function of the connectivity application. */ int main(void) { CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk; DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk; uint32_t err_code = NRF_SUCCESS; APP_ERROR_CHECK(NRF_LOG_INIT(timestamp, 64000000)); NRF_LOG_DEFAULT_BACKENDS_INIT(); NRF_LOG_INFO("BLE connectivity started"); #if BOARD_DETECTION uint32_t pin_reset = PCA10059_PIN_RESET; nrf_drv_qspi_config_t config = NRF_DRV_QSPI_DEFAULT_CONFIG; //Using qspi memory to de err_code = nrf_drv_qspi_init(&config, NULL, NULL); if (err_code == NRF_SUCCESS) { //qspi memory is present on pca10056 pin_reset = PCA10056_PIN_RESET; nrf_drv_qspi_uninit(); // turn on LED0 nrf_gpio_cfg_output(13); nrf_gpio_pin_clear(13); } else if (err_code == NRF_ERROR_TIMEOUT) { //pca10059 assumed when no qspi memory nrf_drv_qspi_uninit(); pin_reset = PCA10059_PIN_RESET; pin_to_default(config.pins.csn_pin); pin_to_default(config.pins.io0_pin); pin_to_default(config.pins.io1_pin); pin_to_default(config.pins.io2_pin); pin_to_default(config.pins.io3_pin); pin_to_default(config.pins.sck_pin); // turn on LED0 nrf_gpio_cfg_output(6); nrf_gpio_pin_clear(6); if (NRF_POWER->MAINREGSTATUS & (POWER_MAINREGSTATUS_MAINREGSTATUS_High << POWER_MAINREGSTATUS_MAINREGSTATUS_Pos)) { gpio_output_voltage_setup(); } } #endif //BOARD_DETECTION // turn on LED0 // nrf_gpio_cfg_output(11); // nrf_gpio_pin_clear(11); nrf_gpio_cfg_output(14); nrf_gpio_pin_clear(14); #if (defined(SER_PHY_HCI_DEBUG_ENABLE) || defined(SER_PHY_DEBUG_APP_ENABLE)) debug_init(NULL); #endif /* Force constant latency mode to control SPI slave timing */ NRF_POWER->TASKS_CONSTLAT = 1; /* Initialize scheduler queue. */ //lint -save -e666 -e587 APP_SCHED_INIT(SER_CONN_SCHED_MAX_EVENT_DATA_SIZE, SER_CONN_SCHED_QUEUE_SIZE); //lint -restore /* Initialize SoftDevice. * SoftDevice Event IRQ is not scheduled but immediately copies BLE events to the application * scheduler queue */ err_code = nrf_drv_clock_init(); if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_MODULE_ALREADY_INITIALIZED)) { APP_ERROR_CHECK(err_code); } nrf_drv_clock_hfclk_request(NULL); nrf_drv_clock_lfclk_request(NULL); while (!nrf_drv_clock_hfclk_is_running()) {} #if defined(APP_USBD_ENABLED) && APP_USBD_ENABLED usbd_init(); #endif #if BOARD_DETECTION APP_ERROR_CHECK(nrf_dfu_trigger_usb_init(pin_reset)); #endif /* Open serialization HAL Transport layer and subscribe for HAL Transport events. */ err_code = ser_hal_transport_open(ser_conn_hal_transport_event_handle); APP_ERROR_CHECK(err_code); #if defined(APP_USBD_ENABLED) && APP_USBD_ENABLED usbd_enable(); #endif err_code = nrf_sdh_enable_request(); APP_ERROR_CHECK(err_code); err_code = app_timer_init(); APP_ERROR_CHECK(err_code); ser_conn_on_no_mem_handler_set(on_idle); /* Enter main loop. */ for (;;) { /* Process SoftDevice events. */ app_sched_execute(); if (nrf_sdh_is_suspended()) { // Resume pulling new events if queue utilization drops below 50%. if (app_sched_queue_space_get() > (SER_CONN_SCHED_QUEUE_SIZE >> 1)) { nrf_sdh_resume(); } } /* Process received packets. * We can NOT add received packets as events to the application scheduler queue because * received packets have to be processed before SoftDevice events but the scheduler queue * does not have priorities. */ err_code = ser_conn_rx_process(); APP_ERROR_CHECK(err_code); on_idle(); } } /** @} */
What bootloader did you program ? The one in examples\dfu\open_bootloader\pca10056_usb ?
If that does not work, try this bootloader:
0636.bootloader.hex
Yes, I am using project examples\dfu\open_bootloader\pca10056_usb.
After change the DFU enters method to NRF_BL_DFU_ENTER_METHOD_PINRESET.
I can communicate with DFU trigger and upgrade the dongle right now.
The new problem is after a hardware reset or plug the dongle into the PC.
The dongle will into the DFU mode.
Only software reset can let the dongle running application.
Is it normal?
I have connected P024 to reset port P018.
I expected that only nRF connect/programmer will trigger the dongle into DFU mode.
840usbConnBoot.hexUSB840_Connect3in1.hex
I tested this on a nRF52840-DK. With P024 connected to reset pin P018. I used these commands:
nrfjprog -e nrfjprog -f nRF52 --program USB840_Connect3in1.hex --verify --reset
Then, in the nRF Programmer app, I select the device(NOT the PCA10056, but the com port with USB: Nordic Semiconductor nRF52 Connectivity) and programmed the ble_app_hrs_pca10056_s140.hexfound in SDK15_folder\examples\ble_peripheral\ble_app_hrs\hex
After the DFU is done, the device advertises as Nordic_HRM. I turn the power off, and on again, and it still advertises as Nordic_HRM.
Thank you.
I used PCA10059 and Fanstel dongle does the same test.
These boards do not have that problem.
Maybe there is some problem on my PCA10056.
Can I also use "nrfutil dfu usb_serial" to do the DFU trigger then programming?
The "nRF connect/programmer" first time DFU trigger is working.
When I try to do DFU trigger again.
There is no response from the programmer.
Every time DFU trigger a dongle.
I need to close "nRF connect/programmer" then re-open it to avoid the problem.
The below video shows the problem.
https://www.dropbox.com/s/5hibuj6tk14zlux/Second%20time%20failed.mp4?dl=0
nRF Connect 3.3.0
Programmer 1.3.1
I don't see this issue here, testing on nRF52840-DK(PCA10056 v1.0.0) with a Windows 10 computer.
Make sure that pin P0.24 and P0.18 is connected.
Could you test with the hex file attached here:
ble_connectivity_s140_usb_hci_pca10056.hex
What version of the DK do you use ? v1.0.0 or something else ?
Could you test with a Windows 10 computer?
