用nRF5SDK160098a08e2里面的spis工程在52832开发板上跑,但数据发送不正常
1,从逻辑分析仪图上看,spi主的时序没问题,发送的数据内容也没问题,但MISO这跟线的数据经常发不完整
Do you mean nRF52832DK MISO sent incomplete data while executing the SDK 16/spis example? If so, which pin are you using for MISO on Slave and Master boards?
-Amanda H.
Yes, in the example, the MISO pin is p0.30, but i use the silicon's efm32zgf32 to work as the Master spi。
Did you modify the spis example code? If so, what is that? Could you share with us?
I tested two nRF52832DKs with SPI Master Example and SPI Slave Example, and I could not reproduce the problem.
-Amanda H.
I also test other three situations(nRF52832DK as SPIM with nRF52832DK as SPIS,nRF52832DK as SPIM with efm32 as SPIS, efm32 as SPIM with efm32 as SPIS), they all work well, only use efm32 as SPIM with nRF52832DK as SPIS, it make mistake。
efm32 means efm32zg210f32
my nRF52832DK code file and efm32zg210f32 code file。
#include "em_device.h"
#include "em_chip.h"
//#include "hal-config.h"
#include <stdint.h>
#include <stdbool.h>
//#include "efm32.h"
//#include "efm32_chip.h"
#include "em_cmu.h"
#include "em_gpio.h"
#include "em_usart.h"
#define autoCS 0
#define PIN_CS 14
#define PORT_CS gpioPortC
static uint8_t spis_idx = 0;
void SPI_Initial(bool master)
CMU_ClockEnable(cmuClock_HFPER, true);
CMU_ClockEnable(cmuClock_GPIO, true);
CMU_ClockEnable(cmuClock_USART1, true);
USART_InitSync_TypeDef SPI_init = USART_INITSYNC_DEFAULT;
// SPI_init.baudrate = 1000000;
SPI_init.autoCsEnable = autoCS;
SPI_init.msbf = true;
SPI_init.master = master;
USART_InitSync(USART1, &SPI_init);
if (master)
GPIO_PinModeSet(gpioPortD, 7, gpioModePushPull, 0); //MO
GPIO_PinModeSet(gpioPortD, 6, gpioModeInput, 0); //MI
GPIO_PinModeSet(gpioPortC, 15, gpioModePushPull, 0); //clk
GPIO_PinModeSet(PORT_CS, PIN_CS, gpioModePushPull, 1); //cs
GPIO_DriveModeSet(PORT_CS,gpioDriveModeHigh);
GPIO_PinModeSet(gpioPortD, 7, gpioModeInput, 0); //MO
GPIO_PinModeSet(gpioPortD, 6, gpioModePushPull, 1); //MI
GPIO_PinModeSet(gpioPortC, 15, gpioModeInput, 0); //clk
GPIO_PinModeSet(PORT_CS, PIN_CS, gpioModeInput, 1); //cs
#if autoCS
USART1->ROUTE |= USART_ROUTE_CSPEN;
if(!master)
USART1->ROUTE |= USART_ROUTE_CLKPEN | USART_ROUTE_TXPEN
| USART_ROUTE_RXPEN | USART_ROUTE_LOCATION_LOC3;
void delay(uint32_t count)
while (count--)
void CSBegin(void)
#if !autoCS
GPIO_PinOutClear(PORT_CS, PIN_CS);
delay(40);
void CSEnd(void)
#if !autoCS
delay(40);
GPIO_PinOutSet(PORT_CS, PIN_CS);
void test1by1(void)
for (int i = 0; i < 256; i++)
CSBegin();
USART_SpiTransfer(USART1, i & 0xff);
CSEnd();
void test256(void)
CSBegin();
CSEnd();
void teststr(void)
char *pStr = "efm32zgM";
CSBegin();
for (int i = 0; i < strlen(pStr); i++)
// USART_SpiTransfer(USART1, *(pStr + i));
USART_Tx(USART1, *(pStr + i));
CSEnd();
void spiM(void)
SPI_Initial(true);
/* Infinite loop */
while (1)
// test1by1();
teststr();
delay(10000);
void spiS(void)
char *pStr = "efm32zgS901234";
uint8_t len = strlen(pStr);
SPI_Initial(false);
while(1)
uint8_t tx = 0xAA;
if(spis_idx < len)
tx = *(pStr + spis_idx++);
spis_idx = 0;
USART_Tx(USART1, tx);
// if(USART1->IF & USART_IF_TXUF)
// spis_idx = 0;
/* Chip errata */
CHIP_Init();
SystemCoreClockUpdate();
// spiS();
spiM();
* Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include "sdk_config.h"
#include "nrf_drv_spis.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPIS_INSTANCE 1 /**< SPIS instance index. */
static const nrf_drv_spis_t spis = NRF_DRV_SPIS_INSTANCE(SPIS_INSTANCE);/**< SPIS instance. */
#define TEST_STRING "Nordic"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 5]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
static volatile bool spis_xfer_done; /**< Flag used to indicate that SPIS instance completed the transfer. */
* @brief SPIS user event handler.
* @param event
void spis_event_handler(nrf_drv_spis_event_t event)
if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
spis_xfer_done = true;
NRF_LOG_INFO(" Transfer completed. Received: %s",(uint32_t)m_rx_buf);
// Enable the constant latency sub power mode to minimize the time it takes
// for the SPIS peripheral to become active after the CSN line is asserted
// (when the CPU is in sleep mode).
NRF_POWER->TASKS_CONSTLAT = 1;
NRF_LOG_INFO("SPIS example");
nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
spis_config.csn_pin = APP_SPIS_CS_PIN;
spis_config.miso_pin = APP_SPIS_MISO_PIN;
spis_config.mosi_pin = APP_SPIS_MOSI_PIN;
spis_config.sck_pin = APP_SPIS_SCK_PIN;
spis_config.def = 0xaa;
// spis_config.orc = 0x55;
APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
while (1)
memset(m_rx_buf, 0, m_length);
spis_xfer_done = false;
APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length));
while (!spis_xfer_done)
__WFE();
NRF_LOG_FLUSH();
bsp_board_led_invert(BSP_BOARD_LED_0);
when i set the spi mode to mode1, mode2, it works。
when i set the spi mode to mode0, mode3, the error occurs。
I donot known why
