Thingy91: LTE BLE Gateway with Modem Info
I have been closely following this thread (https://devzone.nordicsemi.com/f/nordic-q-a/52689/nrf9160-lte-sensor-gateway-on-thingy-91/217018) to provide support for the LTE BLE Gateway sample on the Thingy91. The patch provided in the thread is working and I am able to scan and receive nearby BLE devices.
My question is, now that I have the BLE gateway working on the Thingy91, I am looking to enable modem info via the modem_info library - is this a supported configuration?
When I attempt to enable the modem info library I get the following error message:
[00:00:00.233,947] <err> at_host: Cannot bind UART_0
[00:00:00.334,045] <err> at_host: UART could not be initialized: -22
I am assuming it has something to do with the UART configuration needed for the HCI bluetooth interface, any assistant would be helpful.
  • I was able to enable the modem info library in the lte_ble_gateway example on the Thingy:91. Could you test the example I provided and see if it works for you?
    merged.hex
    lte_ble_gateway.zip
    Simon
  • Thank you Simon, I believe it was simply a misconfiguration of the prj.conf file - using the sample project you provided I was able to bisect the issue. I have now moved on to implementing FOTA and running into additional issues, would you like me to open a new issue or should I add it to this one?
  • Hi Simon,
    I have flashed the above image "merged.hex", to get the BLE values on thingy91 (nrf9160_pca20035ns).
    Before this, I have flashed respective hci_uart on nrf52840 (PCA20035)
    I followed the " https://devzone.nordicsemi.com/f/nordic-q-a/52689/nrf9160-lte-sensor-gateway-on-thingy-91/217018 "
    But unfortunately, the kernel is panicked, Please find the below RTT viewer logs.
    /******************************  LOGS  ************************************/
    # SEGGER J-Link RTT Viewer V6.54c Terminal Log File
    # Compiled: 17:04:11 on Nov 7 2019
    # Logging started @ 12 Dec 2019 20:54:08
    00> Application started
    00>
    00> Initializing Bluetooth..
    00>
    00> Establishing LTE link (this may take some time) ...
    00>
    00> ASSERTION FAIL [err == 0] @ C:/Nordic/nRFConnectSDK/whatever/ncs/zephyr/subsys/bluetooth/host/hci_core.c:340
    00>
    00> k_sem_take failed with err -11
    00>
    00> [00:00:10.473,144] <err> os: r0/a1: 0x00000004 r1/a2: 0x00000154 r2/a3: 0x00000002
    00> [00:00:10.473,1400> [00:00:10.473,144] <err> os: r3/a4: 0x20020cb8 r12/ip: 0x00000000 r14/lr: 0x000174f7
    00> [00:00:10.473,144] <err> os: xpsr: 0x4100> [00:00:10.473,144] <err> os: xpsr: 0x41000000
    00> [00:00:10.473,175] <err> os: s[0]: 0x00000000 s[1]: 0x00000000 s[2]: 0x00000000 s[3]: 0x00000000
    00>
    00> [00:00:10.473,175] <err> 00> [00:00:10.473,175] <err> os: s[4]: 0x00000000 s[5]: 0x00000000 s[6]: 0x00000000 s[7]: 0x00000000
    00>
    00> [00:00:10.473,205] <err> os: s[8]: 0x00000000 s[9]: 0x00000000 s[10]:00> [00:00:10.473,205] <err> os: s[8]: 0x00000000 s[9]: 0x00000000 s[10]: 0x00000000 s[11]: 0x00000000
    00>
    00> [00:00:10.473,205] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 00> [00:00:10.473,205] <err> os: s[12]: 0x00000000 s[13]: 0x00000000 s[14]: 0x00000000 s[15]: 0x00000000
    00>
    00> [00:00:10.473,236] <err> os: fpscr: 0x00018b15
    00>
    00> [00:00:10.473,266] <err> os: Faulting instruction address (r15/pc): 0x00000> [00:00:10.473,266] <err> os: Faulting instruction address (r15/pc): 0x00039ad6
    00> [00:00:10.473,266] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic
    00> [00:00:10.473,266] <err> os: Current thre00> [00:00:10.473,266] <err> os: Current thread: 0x200283a4 (unknown)
    00> [00:00:10.876,190] <err> os: Halting system
    # Logging stopped @ 12 Dec 2019 20:55:14
     /*****************************      End of Logs       **********************************/
    Please let me know if I am missing anything, to the BLE values on Thingy91 (PCA20035), as its blocking the production.
    Thank you for your help.
    Any luck with the below issue.
    Recently we are facing the below issue as well, after porting above configuration changes.
    ***** Booting Zephyr OS version 2.1.0-rc1 *****
    00>
    00> [00:00:00.462,219] <err> at_host: UART check failed: 12. Dropping buffer and retrying.
    and
    [00:00:01.395,111] <err> at_host: Cannot bind UART_0
    [00:00:01.494,323] <err> at_host: UART could not be initialized: -22
    Please help us, as this is blocking our production.
    Thank you for your time.
