The problem of Uploading Zip file with DFU
Hi there.
board : MBN52832
SDK : 15.3.0
Softdevice : S132, Ver 6.1.1
example file : ....\examples\dfu\bootloader_secure_ble
(refer) Nordic Documents : https://infocenter.nordicsemi.com/index.jsp , Nordic Blog : //devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/getting-started-with-nordics-secure-dfu-bootloader)
my command are :
1.Generate Keys : nrfutil keys generate ...\Desktop\pip\private_key.pem
2.Generate Public Keys : nrfutil keys display --key pk --format code ...\Desktop\pip\private_key.pem --out_file private_key.c
3.Build bootloader :
GNU Make ver 3.81 - Make the eUCC Library. there are two file(...\SDK 15.3.0\external\micro-ecc), nrf52hf_keil and nrf52nf_keil,  i used nrf52hf_keil.
and delete example key and replace private_key.c and build.
4. Generate DFU zip packet : nrfutil pkg generate --hw-version 52 --application-version 0 --application ...\Desktop\pip\nrf52832_xxaa.hex --sd-req 0xB7 --key-file ...\Desktop\pip\private_key.pem App_DFU_Test.zip (nrf52832_xxaa.hex is the uart example)
5.Test DFU : Flash bootloader and softdevice using nRF connect, and copy the zip file in my phone. and upload zipfile.
but uploading is file.
what should i do?
this is the log file.
nRF Connect, 2019-11-26
DfuTarg (EF:DD:61:C2:A6:C7)
V	21:30:02.807	Connecting to EF:DD:61:C2:A6:C7...
D	21:30:02.807	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	21:30:02.878	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	21:30:02.889	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	21:30:02.889	Connected to EF:DD:61:C2:A6:C7
V	21:30:02.903	Discovering services...
D	21:30:02.903	gatt.discoverServices()
I	21:30:03.670	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
I	21:30:03.802	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D	21:30:03.819	[Callback] Services discovered with status: 0
I	21:30:03.819	Services discovered
V	21:30:03.825	Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
- Central Address Resolution [R] (0x2AA6)
Generic Attribute (0x1801)
Secure DFU Service (0xFE59)
- DFU Packet [WNR] (8ec90002-f315-4f60-9fb8-838830daea50)
- DFU Control Point [N W] (8ec90001-f315-4f60-9fb8-838830daea50)
   Client Characteristic Configuration (0x2902)
I	21:30:03.872	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
V	21:30:11.989	[DFU] DFU service started
V	21:30:11.989	[DFU] Opening file...
I	21:30:12.778	[DFU] Firmware file opened successfully
V	21:30:12.778	[DFU] Connecting to DFU target...
D	21:30:12.779	[DFU] gatt = device.connectGatt(autoConnect = false)
I	21:30:12.786	[DFU] Connected to EF:DD:61:C2:A6:C7
V	21:30:12.786	[DFU] Discovering services...
D	21:30:12.786	[DFU] gatt.discoverServices()
I	21:30:12.792	[DFU] Services discovered
D	21:30:12.817	[DFU] wait(1000)
V	21:30:13.798	[DFU] Requesting new MTU...
D	21:30:13.798	[DFU] gatt.requestMtu(517)
I	21:30:13.832	[DFU] MTU changed to: 247
V	21:30:13.834	[DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:13.834	[DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
D	21:30:13.835	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	21:30:13.891	[DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00
V	21:30:13.891	[DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50
A	21:30:13.891	[DFU] Notifications enabled
D	21:30:13.891	[DFU] wait(1000)
V	21:30:14.892	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:14.892	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:14.925	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 06-01
I	21:30:14.927	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-02-00-00-00-00-00-00-00-00-00-00
A	21:30:14.928	[DFU] Command object info received (Max size = 512, Offset = 0, CRC = 00000000)
V	21:30:14.928	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:14.928	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:14.956	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 02-00-00
I	21:30:14.957	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01
A	21:30:14.957	[DFU] Packet Receipt Notif disabled (Op Code = 2, Value = 0)
V	21:30:14.957	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:14.957	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:14.988	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-01-8D-00-00-00
I	21:30:14.990	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
A	21:30:14.990	[DFU] Command object created
V	21:30:14.990	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
D	21:30:14.990	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
I	21:30:14.993	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): 12-8A-01-0A-44-08-01-12-40-08-02-10-34-1A-02-B7-01-20-00-28-00-30-00-38-A0-D5-01-42-24-08-03-12-20-38-E1-A1-38-56-49-37-E6-10-91-18-48-BC-0F-91-92-27-D3-79-A2-42-97-85-58-F6-09-46-03-CF-D2-93-2A-48-00-52-04-08-01-12-00-10-00-1A-40-2E-6A-2E-0D-3B-09-EE-CD-A0-B2-20-90-DB-C6-2B-CA-01-B8-D0-A5-1F-27-52-45-27-61-2F-0D-CA-B4-1A-1C-3E-05-74-C2-41-4A-E5-77-DF-1F-B6-02-D7-4D-E5-63-0C-9E-B6-1E-22-F0-F1-1E-ED-56-7B-15-1B-8C-84-B9
A	21:30:14.994	[DFU] Command object sent (CRC = 336BAE4D)
V	21:30:14.994	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:14.994	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:15.015	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
I	21:30:15.016	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-8D-00-00-00-4D-AE-6B-33
A	21:30:15.016	[DFU] Checksum received (Offset = 141, CRC = 336BAE4D)
V	21:30:15.017	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:15.017	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:15.048	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
I	21:30:15.166	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-05
E	21:30:15.167	[DFU] Remote DFU error: INVALID OBJECT
V	21:30:15.167	[DFU] Disconnecting...
D	21:30:15.183	[DFU] gatt.disconnect()
I	21:30:15.192	[DFU] Disconnected
D	21:30:15.193	[DFU] gatt.refresh() (hidden)
D	21:30:15.194	[DFU] gatt.close()
D	21:30:15.202	[DFU] wait(600)
I	21:30:15.305	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
I	21:30:15.492	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
