The problem of Uploading Zip file with DFU
Hi there.
board : MBN52832
SDK : 15.3.0
Softdevice : S132, Ver 6.1.1
example file : ....\examples\dfu\bootloader_secure_ble
(refer) Nordic Documents : https://infocenter.nordicsemi.com/index.jsp , Nordic Blog : //devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/getting-started-with-nordics-secure-dfu-bootloader)
my command are :
1.Generate Keys : nrfutil keys generate ...\Desktop\pip\private_key.pem
2.Generate Public Keys : nrfutil keys display --key pk --format code ...\Desktop\pip\private_key.pem --out_file private_key.c
3.Build bootloader :
GNU Make ver 3.81 - Make the eUCC Library. there are two file(...\SDK 15.3.0\external\micro-ecc), nrf52hf_keil and nrf52nf_keil,  i used nrf52hf_keil.
and delete example key and replace private_key.c and build.
4. Generate DFU zip packet : nrfutil pkg generate --hw-version 52 --application-version 0 --application ...\Desktop\pip\nrf52832_xxaa.hex --sd-req 0xB7 --key-file ...\Desktop\pip\private_key.pem App_DFU_Test.zip (nrf52832_xxaa.hex is the uart example)
5.Test DFU : Flash bootloader and softdevice using nRF connect, and copy the zip file in my phone. and upload zipfile.
but uploading is file.
what should i do?
this is the log file.
nRF Connect, 2019-11-26
DfuTarg (EF:DD:61:C2:A6:C7)
V	21:30:02.807	Connecting to EF:DD:61:C2:A6:C7...
D	21:30:02.807	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	21:30:02.878	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	21:30:02.889	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	21:30:02.889	Connected to EF:DD:61:C2:A6:C7
V	21:30:02.903	Discovering services...
D	21:30:02.903	gatt.discoverServices()
I	21:30:03.670	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
I	21:30:03.802	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
D	21:30:03.819	[Callback] Services discovered with status: 0
I	21:30:03.819	Services discovered
V	21:30:03.825	Generic Access (0x1800)
- Device Name [R W] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
- Central Address Resolution [R] (0x2AA6)
Generic Attribute (0x1801)
Secure DFU Service (0xFE59)
- DFU Packet [WNR] (8ec90002-f315-4f60-9fb8-838830daea50)
- DFU Control Point [N W] (8ec90001-f315-4f60-9fb8-838830daea50)
   Client Characteristic Configuration (0x2902)
I	21:30:03.872	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
V	21:30:11.989	[DFU] DFU service started
V	21:30:11.989	[DFU] Opening file...
I	21:30:12.778	[DFU] Firmware file opened successfully
V	21:30:12.778	[DFU] Connecting to DFU target...
D	21:30:12.779	[DFU] gatt = device.connectGatt(autoConnect = false)
I	21:30:12.786	[DFU] Connected to EF:DD:61:C2:A6:C7
V	21:30:12.786	[DFU] Discovering services...
D	21:30:12.786	[DFU] gatt.discoverServices()
I	21:30:12.792	[DFU] Services discovered
D	21:30:12.817	[DFU] wait(1000)
V	21:30:13.798	[DFU] Requesting new MTU...
D	21:30:13.798	[DFU] gatt.requestMtu(517)
I	21:30:13.832	[DFU] MTU changed to: 247
V	21:30:13.834	[DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:13.834	[DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
D	21:30:13.835	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	21:30:13.891	[DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00
V	21:30:13.891	[DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50
A	21:30:13.891	[DFU] Notifications enabled
D	21:30:13.891	[DFU] wait(1000)
V	21:30:14.892	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:14.892	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:14.925	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 06-01
I	21:30:14.927	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-00-02-00-00-00-00-00-00-00-00-00-00
A	21:30:14.928	[DFU] Command object info received (Max size = 512, Offset = 0, CRC = 00000000)
V	21:30:14.928	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:14.928	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:14.956	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 02-00-00
I	21:30:14.957	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01
A	21:30:14.957	[DFU] Packet Receipt Notif disabled (Op Code = 2, Value = 0)
V	21:30:14.957	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:14.957	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:14.988	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-01-8D-00-00-00
I	21:30:14.990	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01
A	21:30:14.990	[DFU] Command object created
V	21:30:14.990	[DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
D	21:30:14.990	[DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
I	21:30:14.993	[DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): 12-8A-01-0A-44-08-01-12-40-08-02-10-34-1A-02-B7-01-20-00-28-00-30-00-38-A0-D5-01-42-24-08-03-12-20-38-E1-A1-38-56-49-37-E6-10-91-18-48-BC-0F-91-92-27-D3-79-A2-42-97-85-58-F6-09-46-03-CF-D2-93-2A-48-00-52-04-08-01-12-00-10-00-1A-40-2E-6A-2E-0D-3B-09-EE-CD-A0-B2-20-90-DB-C6-2B-CA-01-B8-D0-A5-1F-27-52-45-27-61-2F-0D-CA-B4-1A-1C-3E-05-74-C2-41-4A-E5-77-DF-1F-B6-02-D7-4D-E5-63-0C-9E-B6-1E-22-F0-F1-1E-ED-56-7B-15-1B-8C-84-B9
A	21:30:14.994	[DFU] Command object sent (CRC = 336BAE4D)
V	21:30:14.994	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:14.994	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:15.015	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 03
I	21:30:15.016	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-8D-00-00-00-4D-AE-6B-33
A	21:30:15.016	[DFU] Checksum received (Offset = 141, CRC = 336BAE4D)
V	21:30:15.017	[DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D	21:30:15.017	[DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I	21:30:15.048	[DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 04
I	21:30:15.166	[DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-04-05
E	21:30:15.167	[DFU] Remote DFU error: INVALID OBJECT
V	21:30:15.167	[DFU] Disconnecting...
D	21:30:15.183	[DFU] gatt.disconnect()
I	21:30:15.192	[DFU] Disconnected
D	21:30:15.193	[DFU] gatt.refresh() (hidden)
D	21:30:15.194	[DFU] gatt.close()
D	21:30:15.202	[DFU] wait(600)
I	21:30:15.305	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
I	21:30:15.492	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 6000ms)
  • i met this issue for several days. still not fix it.....do you have any suggest ???
    Could you try follow my step by step guide here and check if you have the same issue ?
    Could you try setting application version to 1 instead of 0 ?
  • yes, I tried more than 20 times, with different solution base on official guide and others.
    I can't figure out what is the problem eventually.
    my test bed is
    1. IAR 8.30.1
    2. nRF5_SDK_15.3.0
    3. Chip: NRF52832
    4.version of make is 3.81
    5. version of urfutil is 6.0.0a1
    7. version of mergehex is 8.5.0
    8. and version of arm-none-eabi-gcc is 9.2.1
    I compiled bootloader project in foler "examples\dfu\secure_bootloader\pca10040_ble" and the debug version.
    and the app is come from "examples\ble_peripheral\ble_app_buttonless_dfu\pca10040".
    at the previous several times, I didn't change anything of these project to verify the dfu and OTA.
    all my test are failed at the end.
    but, only the example target file in folder “examples\dfu\secure_dfu_test_images\ble\nrf52832”  can be OTA 。
    I don't whether it is the issue related with "micro-ecc" .  but there is no any error reported during my test.
    And I found the example bootloader proect called the ecc lib of the folder "external\micro-ecc\nrf52hf_iar\armgcc\micro_ecc_lib_nrf52.a".  Help document from sdk said it is currect if I enable hardware FPU.
    And i also solved the issue "-short-char' related with "wchar_t" is 16bit or 32bit.
    besides, i tried with different application version and  --bl-settings-version, no one can give me a success result.
    i also checked the help of nrfutil,  --bl-settings-version should be 2 for SDK15.3.0,  and --sd-req should 0xB7. So I think my script might be no problem.
    I also tried the buttonless example with different version and other app example such as uart or hrs.but  no one can be successfully ota.
    here is my script related this process. I really don't know where I was wrong.
    ::step1 generateo private key-file
    nrfutil keys generate private.pem
    nrfutil keys display --key pk --format code private.pem
    ::step2
    nrfutil settings generate --family NRF52 --application app_ota.hex --application-version-string 0.0.0 --bootloader-version 0 --bl-settings-version 2 settings.hex
    ::step3
    mergehex.exe --merge s132_nrf52_6.1.1_softdevice.hex bootloader.hex   --output ota_sd_boot.hex
    mergehex.exe --merge app_ota.hex ota_sd_boot.hex settings.hex         --output ota_all.hex
    del /f ota_sd_boot.hex
    ::step4
    nrfjprog.exe --family NRF52 --eraseall
    nrfjprog.exe --family NRF52 --program ota_all.hex --verify
    nrfjprog.exe --family NRF52 --reset
    ::step5
    nrfutil pkg generate --hw-version 52 --sd-req 0xB7 --application-version 1 --application app_ota.hex --key-file private.pem app_ota.zip
    here is error message form IOS and android during OTA.
    IOS error report
    android error report.
  • Hi CUI,
    We need to debug the bootloader to check what went wrong here.
    Please try testing with the bootloader _debug version where you can have the RTT log.
    Make sure the log level is set to DEBUG in sdk_config.h
    There are several reasons the DFU return INVALID_OBJECT. One of them is the signature is not correct , see nrf_dfu_validation_signature_check() in nrf_dfu_validation.c .
    Another option could be that the init packet was corrupted.
    There are about 5-6 places where NRF_DFU_RES_CODE_INVALID_OBJECT returned. If the logging doesn't help, you can add breakpoints at those place to check what returned.
    Since you mentioned that  "only the example target file in folder “examples\dfu\secure_dfu_test_images\ble\nrf52832”  can be OTA " , most likely you haven't updated the bootloader with your own PUBLIC key.
    In this line, you should generate an output public key file: nrfutil keys display --key pk --format code private.pem
    For example:
    nrfutil keys display --key pk --format code private.key --out_file public_key.c
    Then you include the public_key.c in your bootloader, replacing the dfu_public_key.c default in the bootloader.
  • Yep, it was solved.
    i dont know why the wrong .c key file appear, when i use the command nrfutil(nrfutil keys display --key pk --format code ...\Desktop\pip\private_key.pem --out_file private_key.c)
    the problem is wrong .c key file.
    so, what should you check the key between .c file and generated code (it can show through command "nrfutil keys display --key pk --format hex ...\Desktop\pip\private_key.pem" in cmd)
