<Environment>
- nRF9160 DK v0.8.5
- nrf tag: 1.1.0
- modem version: 1.1.0
- using an external GPS antenna, SW12 => CON
I'm attempting to use udp_gps, but doesn't work out with the new firmware. Any tip?
https://github.com/Rallare/fw-nrfconnect-nrf/tree/nrf9160_samples/samples/nrf9160/udp_gps
"gps" program works fine and gives nmea data.
***** Booting Zephyr OS build v2.0.99-ncs1 ***** EXPERIMENTAL: UDP test with GPS Connecting to LTE network. This may take several minutes. [00:00:00.350,250] <dbg> nrf9160_gps.init: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1574,1577 [00:00:00.350,738] <dbg> nrf9160_gps.init: COEX0 set: AT%XCOEX0=1,1,1570,1580 [00:00:00.367,218] <dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=1,0,0,0 +CEREG: 2,........ [00:01:06.762,054] <dbg> lte_lc.parse_nw_reg_status: Network registration status: 2 +CEREG: 5,......... Connected to LTE network PSM bits: 001 PSM Interval: 01010 GPS initialized +CEREG: 5,........... [00:01:15.486,083] <dbg> lte_lc.parse_nw_reg_status: Network registration status: 5 Enabling PSM PSM enabled Failed starting GPS! GPS could not be started, error: -5 [00:01:17.515,930] <dbg> nrf9160_gps.enable_gps: GPS mode is not enabled, attempting to enable it [00:01:17.516,052] <dbg> nrf9160_gps.enable_gps: Sending AT command: AT%XSYSTEMMODE=0,1,0,1 [00:01:17.516,571] <err> nrf9160_gps: Could not enable GPS mode, error: -8 [00:01:17.516,571] <err> nrf9160_gps: Failed to enable GPS
--- update ---
I erase previous program by "nrfjprog -e" everytime I flash a new one, and delete an old build folder before building a new program
