pm_peer_data_bonding_load not finding the data (error code 5)
We have a device (in central mode) initiating a secure connection to a peripheral (slave) via the usage of `pm_conn_secure(conn_handle, false)`. This results in a `PM_EVT_CONN_SEC_SUCCEEDED` event being generated by the peer manager.
Checking the status of the bond in `p_evt->params.conn_sec_succeeded.data_stored` and `p_evt->params.conn_sec_succeeded.procedure` results in a true value and `PM_CONN_SEC_PROCEDURE_BONDING` respectively.
Furthermore when checking the status of the connection via `pm_conn_sec_status_get` the values returned are connected:true, encrypted:true, mitm_protection:false, bonded:true
At this point we try to retrieve the bonding information from the peer manager via `pm_peer_data_bonding_load` using `p_evt->peer_id` (which has a value 0, i.e. not invalid) however the `pm_peer_data_bonding_t` structure is filled with 0s and the return from the function is 5 (which I believe is NRF_ERROR_NOT_FOUND).
All of the calls are performed from within the callback from the peer_manager event handler associated with `PM_EVT_CONN_SEC_SUCCEEDED`.
What is the correct way to retrieve the stored bonding information?
I could not add tags for the following so mentioning the crucial versions here. We are using the following:
SDK 15.0.0
SoftDevice S132 V6.0.0
  • Hi Alex,
    When you received PM_EVT_CONN_SEC_SUCCEEDED event, what the peer_id was ?
    I'm not sure why you receive NOT_FOUND return, but could you try to do a read after some delay ? There could be a chance that the flash store command is not executed by the softdevice (even though data_stored = 1). You can try doing the bond read after the DISCONNECTED event, it should return the correct bond information.
  • As mentioned in the issue, the peer_id has the value 0 which is not the invalid peer_id value.
    Why would the bonding information be available on the disconnect event, but not before?
    I will try the delay and reading after disconnect, but our application really needs this to work at the point of the connection being secured.
    Is there a fix for this in later SDKs?
  • I have tested adding a delay before retrieving the bonding information and this does indeed eventually result in the bonding information being present.
    As per my previous comment is there a fix in a subsequent SDK/SoftDevice?
    Is there a reason the bonding information cannot be returned sooner?
  • Thanks for the update. The way the fds works is that fds has a queue and data_stored=1 in PM_EVT_CONN_SEC_SUCCEEDED only tell the the flash store command is queued, not executed.
    Could you try catching PM_EVT_PEER_DATA_UPDATE_SUCCEEDED event and read the bond information at that event instead ? I think it's the proper way of doing it. The event is valid for both updating peer data, and storing on the first time.
  • Does the PM_EVT_PEER_DATA_UPDATE_SUCCEEDED event get generated on the `pm_peer_new()` and `pm_peer_data_bonding_store()` calls?
1 2
