debugging under linux [solved]
Hi All,
I can compile and flash examples with my nrf51822 SDK on linux. I would like to use Code::Blocks as IDE. Code::Blocks is transparent to run debugger. I try to use it with the following configuration:
  1. start JLinkGDBServer: konsole -e "JLinkGDBServer -device nrf51822 -if swd -speed 1000 -device nrf51822 -if swd -speed 1000 -port 2331"
It starts and works well.
  1. I try to start gdb under codeblocks: Starting debugger: /usr/bin/arm-none-eabi-gdb -nx -fullname -quiet -args /home/zamek/bluetooth/work/radiotransmit/build/radiotransmit
additional commands before connected:
target remote localhost:2331
monitor interface SWD
monitor endian little
monitor reset 0
monitor flash device=nrf51822
monitor speed 1000
load ./build/nrf51422_xxac.out
monitor reset
in the status window I see the following message:
Connecting to remote target
Setting breakpoints
Debugger name and version: GNU gdb (7.7.1+dfsg-1+6) 7.7.1
Connected
The program is not being run.
Debugger finished with status 0
What is the correct gdb parameters for debugging?
thx a lot Zamek
