Error by compiling zephyr "No such file or directory"
I am always getting the same issue on each sample I try to build. Not only on this "lte_lc.h". This error is also shown with several files or on the code lines....
Checking project status
Project out of date
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/driver-validation.h’
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_list.h’
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_macros.h’
Building ‘zephyr/CMakeFiles/syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
1> Compiling ‘offsets.c’
1> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu.h:16:0,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/arch.h:246,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/cpu.h:17,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel_includes.h:34,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:17,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/kernel/include/kernel_structs.h:10,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/arch/arm/core/offsets/offsets.c:26:
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:60:1: warning: multi-line comment [-Wcomment]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:123:3: warning: multi-line comment [-Wcomment]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:144:3: warning: multi-line comment [-Wcomment]
1> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/arch.h:246:0,
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu.h:43:3: warning: multi-line comment [-Wcomment]
1> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/kernel/include/kernel_structs.h:10:0,
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:268:16: warning: 'k_object_access_grant' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:283:16: warning: 'k_object_release' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:318:17: warning: 'k_object_alloc' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:720:19: warning: 'k_thread_create' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:805:17: warning: 'k_sleep' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:821:17: warning: 'k_usleep' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:831:16: warning: 'k_busy_wait' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:843:16: warning: 'k_yield' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:857:16: warning: 'k_wakeup' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:866:19: warning: 'k_current_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:883:16: warning: 'k_thread_abort' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:896:16: warning: 'k_thread_start' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:994:15: warning: 'k_thread_priority_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1024:16: warning: 'k_thread_priority_set' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1151:16: warning: 'k_thread_suspend' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1166:16: warning: 'k_thread_resume' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1234:15: warning: 'k_is_preempt_thread' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1291:16: warning: 'k_thread_custom_data_set' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1301:17: warning: 'k_thread_custom_data_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1316:15: warning: 'k_thread_name_set' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1339:15: warning: 'k_thread_name_copy' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1569:16: warning: 'k_timer_start' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1588:16: warning: 'k_timer_stop' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1602:17: warning: 'k_timer_status_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1621:17: warning: 'k_timer_status_sync' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1635:17: warning: 'k_timer_remaining_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1657:16: warning: 'k_timer_user_data_set' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1675:17: warning: 'k_timer_user_data_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1704:17: warning: 'k_uptime_get' used but never defined
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1873:16: warning: 'k_queue_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1890:16: warning: 'k_queue_cancel_wait' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1924:17: warning: 'k_queue_alloc_append' used but never defined
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1958:17: warning: 'k_queue_alloc_prepend' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2026:17: warning: 'k_queue_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2088:15: warning: 'k_queue_is_empty' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2104:17: warning: 'k_queue_peek_head' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2120:17: warning: 'k_queue_peek_tail' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2613:17: warning: 'k_stack_alloc_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2641:16: warning: 'k_stack_push' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2661:15: warning: 'k_stack_pop' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3255:16: warning: 'k_mutex_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3276:15: warning: 'k_mutex_lock' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3293:16: warning: 'k_mutex_unlock' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3345:16: warning: 'k_sem_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3370:15: warning: 'k_sem_take' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3385:16: warning: 'k_sem_give' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3397:16: warning: 'k_sem_reset' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3417:24: warning: 'k_sem_count_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3575:15: warning: 'k_msgq_alloc_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3598:15: warning: 'k_msgq_put' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3618:15: warning: 'k_msgq_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3635:15: warning: 'k_msgq_peek' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3649:16: warning: 'k_msgq_purge' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3662:17: warning: 'k_msgq_num_free_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3675:17: warning: 'k_msgq_get_attrs' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3693:17: warning: 'k_msgq_num_used_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4041:15: warning: 'k_pipe_alloc_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4063:15: warning: 'k_pipe_put' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4087:15: warning: 'k_pipe_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4668:15: warning: 'k_poll' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4682:16: warning: 'k_poll_signal_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4690:16: warning: 'k_poll_signal_reset' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4708:16: warning: 'k_poll_signal_check' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4736:15: warning: 'k_poll_signal_raise' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:5163:16: warning: 'k_str_out' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:5189:15: warning: 'k_float_disable' declared 'static' but never defined [-Wunused-function]
1> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/kernel/include/kernel_offsets.h:6:0,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/arch/arm/core/offsets/offsets.c:27:
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/device.h:295:26: warning: 'device_get_binding' declared 'static' but never defined [-Wunused-function]
Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/offsets.h’
Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__cortex_m’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__cortex_m__mpu’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__serial’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_kernel’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_lib__libc__newlib’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_lib__posix’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_subsys__net’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_subsys__net__ip’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_zephyr’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/linker.cmd’
Building ‘zephyr/CMakeFiles/linker_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’
Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
2> Compiling ‘main.c’
2> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu.h:16:0,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/arch.h:246,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/cpu.h:17,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel_includes.h:34,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:17,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/zephyr.h:18,
2>                  from ../src/main.c:7:
2> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:60:1: warning: multi-line comment [-Wcomment]
2> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:123:3: warning: multi-line comment [-Wcomment]
2> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:144:3: warning: multi-line comment [-Wcomment]
2> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/arch.h:246:0,
2> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu.h:43:3: warning: multi-line comment [-Wcomment]
2> ../src/main.c:12:10: fatal error: lte_lc.h: No such file or directory
2> compilation terminated.
Build failed
  • I have deleted all the repository and started the process from Getting Started Assistant again. I have installed west (through Proxy) without issue and now when I follow the next step
    west init -m github.com/.../fw-nrfconnect-nrf
    This is the output:
    $ west init -m github.com/.../fw-nrfconnect-nrf
    === Initializing in c:\users\alcala_an\documents\test\ncs
    --- Cloning manifest repository from github.com/.../fw-nrfconnect-nrf, rev. master
    Initialized empty Git repository in c:/Users/alcala_an/documents/test/ncs/.west/manifest-tmp/.git/
    remote: Enumerating objects: 2, done.
    remote: Counting objects: 100% (2/2), done.
    remote: Compressing objects: 100% (2/2), done.
    remote: Total 20775 (delta 0), reused 0 (delta 0), pack-reused 20773
    Receiving objects: 100% (20775/20775), 8.35 MiB | 7.72 MiB/s, done.
    Resolving deltas: 100% (14234/14234), done.
    From github.com/.../fw-nrfconnect-nrf
     * branch            master      -> FETCH_HEAD
     * [new branch]      backport-1282-to-v1.1-branch -> origin/backport-1282-to-v1.1-branch
     * [new branch]      backport-1320-to-v1.1-branch -> origin/backport-1320-to-v1.1-branch
     * [new branch]      backport-1343-to-v1.1-branch -> origin/backport-1343-to-v1.1-branch
     * [new branch]      backport-1345-to-v1.1-branch -> origin/backport-1345-to-v1.1-branch
     * [new branch]      backport-1349-to-v1.1-branch -> origin/backport-1349-to-v1.1-branch
     * [new branch]      backport-1351-to-v1.1-branch -> origin/backport-1351-to-v1.1-branch
     * [new branch]      backport-1356-to-v1.1-branch -> origin/backport-1356-to-v1.1-branch
     * [new branch]      backport-1357-to-v1.1-branch -> origin/backport-1357-to-v1.1-branch
     * [new branch]      backport-1358-to-v1.1-branch -> origin/backport-1358-to-v1.1-branch
     * [new branch]      backport-1361-to-v1.1-branch -> origin/backport-1361-to-v1.1-branch
     * [new branch]      backport-1375-to-v1.1-branch -> origin/backport-1375-to-v1.1-branch
     * [new branch]      backport-1380-to-v1.1-branch -> origin/backport-1380-to-v1.1-branch
     * [new branch]      backport-1383-to-v1.1-branch -> origin/backport-1383-to-v1.1-branch
     * [new branch]      backport-1386-to-v1.1-branch -> origin/backport-1386-to-v1.1-branch
     * [new branch]      backport-1392-to-v1.1-branch -> origin/backport-1392-to-v1.1-branch
     * [new branch]      backport-1395-to-v1.1-branch -> origin/backport-1395-to-v1.1-branch
     * [new branch]      backport-1409-to-v1.1-branch -> origin/backport-1409-to-v1.1-branch
     * [new branch]      backport-1412-to-v1.1-branch -> origin/backport-1412-to-v1.1-branch
     * [new branch]      backport-1420-to-v1.1-branch -> origin/backport-1420-to-v1.1-branch
     * [new branch]      backport-1421-to-v1.1-branch -> origin/backport-1421-to-v1.1-branch
     * [new branch]      backport-1433-to-v1.1-branch -> origin/backport-1433-to-v1.1-branch
     * [new branch]      backport-1434-to-v1.1-branch -> origin/backport-1434-to-v1.1-branch
     * [new branch]      backport-1443-to-v1.1-branch -> origin/backport-1443-to-v1.1-branch
     * [new branch]      backport-1448-to-v1.1-branch -> origin/backport-1448-to-v1.1-branch
     * [new branch]      backport-1450-to-v1.1-branch -> origin/backport-1450-to-v1.1-branch
     * [new branch]      backport-1455-to-v1.1-branch -> origin/backport-1455-to-v1.1-branch
     * [new branch]      backport-1461-to-v1.1-branch -> origin/backport-1461-to-v1.1-branch
     * [new branch]      backport-1474-to-v1.1-branch -> origin/backport-1474-to-v1.1-branch
     * [new branch]      backport-1478-to-v1.1-branch -> origin/backport-1478-to-v1.1-branch
     * [new branch]      backport-1484-to-v1.1-branch -> origin/backport-1484-to-v1.1-branch
     * [new branch]      backport-1487-to-v1.1-branch -> origin/backport-1487-to-v1.1-branch
     * [new branch]      backport-1489-to-v1.1-branch -> origin/backport-1489-to-v1.1-branch
     * [new branch]      backport-1491-to-v1.1-branch -> origin/backport-1491-to-v1.1-branch
     * [new branch]      backport-1502-to-v1.1-branch -> origin/backport-1502-to-v1.1-branch
     * [new branch]      backport-1504-to-v1.1-branch -> origin/backport-1504-to-v1.1-branch
     * [new branch]      backport-1505-to-v1.1-branch -> origin/backport-1505-to-v1.1-branch
     * [new branch]      cherry-pick-backport-1253-to-v1.1-branch-256971b7-90d6-4963-a9d6-748f191594ab -> origin/cherry-pick-backport-1253-to-v1.1-branch-256971b7-90d6-4963-a9d6-748f191594ab
     * [new branch]      master      -> origin/master
     * [new branch]      v1.0-branch -> origin/v1.0-branch
     * [new branch]      v1.1-branch -> origin/v1.1-branch
     * [new tag]         v0.1.0      -> v0.1.0
     * [new tag]         v0.1.0-rc1  -> v0.1.0-rc1
     * [new tag]         v0.3.0      -> v0.3.0
     * [new tag]         v0.3.0-rc1  -> v0.3.0-rc1
     * [new tag]         v0.3.0-rc2  -> v0.3.0-rc2
     * [new tag]         v0.4.0      -> v0.4.0
     * [new tag]         v0.4.0-rc1  -> v0.4.0-rc1
     * [new tag]         v0.4.0-rc2  -> v0.4.0-rc2
     * [new tag]         v1.0.0      -> v1.0.0
     * [new tag]         v1.0.0-rc1  -> v1.0.0-rc1
     * [new tag]         v1.0.0-rc2  -> v1.0.0-rc2
     * [new tag]         v1.0.0-rc3  -> v1.0.0-rc3
     * [new tag]         v1.0.0-rc4  -> v1.0.0-rc4
     * [new tag]         v1.1.0      -> v1.1.0
     * [new tag]         v1.1.0-rc1  -> v1.1.0-rc1
     * [new tag]         v1.1.0-rc2  -> v1.1.0-rc2
     * [new tag]         v1.1.0-rc3  -> v1.1.0-rc3
    03fe9283f35ea5fec2e09eb0be6dbdc171744086 refs/remotes/origin/master
    Updating files: 100% (1321/1321), done.
    Already on 'master'
    Branch 'master' set up to track remote branch 'master' from 'origin'.
      File "c:\python38\lib\shutil.py", line 780, in move
        os.rename(src, real_dst)
    PermissionError: [WinError 5] Zugriff verweigert: 'c:\\users\\alcala_an\\documents\\test\\ncs\\.west\\manifest-tmp' -> 'c:\\users\\alcala_an\\documents\\test\\ncs\\nrf'
    During handling of the above exception, another exception occurred:
      File "c:\python38\lib\runpy.py", line 192, in _run_module_as_main
        return _run_code(code, main_globals, None,
      File "c:\python38\lib\runpy.py", line 85, in _run_code
        exec(code, run_globals)
      File "C:\Python38\Scripts\west.exe\__main__.py", line 9, in <module>
      File "c:\python38\lib\site-packages\west\main.py", line 583, in main
        args.handler(args, unknown)
      File "c:\python38\lib\site-packages\west\main.py", line 300, in command_handler
        command.run(known_args, unknown_args, topdir, manifest=manifest)
      File "c:\python38\lib\site-packages\west\commands\__init__.py", line 118, in run
        self.do_run(args, unknown)
      File "c:\python38\lib\site-packages\west\commands\project.py", line 207, in do_run
        projects, manifest_dir = self.bootstrap(args)
      File "c:\python38\lib\site-packages\west\commands\project.py", line 278, in bootstrap
        shutil.move(tempdir, manifest_abspath)
      File "c:\python38\lib\shutil.py", line 792, in move
        rmtree(src)
      File "c:\python38\lib\shutil.py", line 730, in rmtree
        return _rmtree_unsafe(path, onerror)
      File "c:\python38\lib\shutil.py", line 603, in _rmtree_unsafe
        _rmtree_unsafe(fullname, onerror)
      File "c:\python38\lib\shutil.py", line 608, in _rmtree_unsafe
        onerror(os.unlink, fullname, sys.exc_info())
      File "c:\python38\lib\shutil.py", line 606, in _rmtree_unsafe
        os.unlink(fullname)
    PermissionError: [WinError 5] Zugriff verweigert: 'c:\\users\\alcala_an\\documents\\test\\ncs\\.west\\manifest-tmp\\.git\\objects\\pack\\pack-0b24670acea09404f486e62b21a6c5a8785441f6.idx'
    by west update here is the output:
     west update
    WARNING: Can't set ZEPHYR_BASE: parsing of manifest file failed during command update : no "manifest.path" config option is set
    FATAL ERROR: can't run west update; it requires the manifest, which was not available. Try "west manifest --validate" to debug.
  • Could you try checking out the repo in a shorter path? For instance c:\sdk\ncs
    I think you're exceeding the windows max. character length in a path on some of the checked out files.
    Håkon
  • That is great to hear, Ana! Let us know if you run into any other issues
    Cheers,
    Håkon
