Error by compiling zephyr "No such file or directory"
I am always getting the same issue on each sample I try to build. Not only on this "lte_lc.h". This error is also shown with several files or on the code lines....
Checking project status
Project out of date
Building ‘zephyr/include/generated/driver-validation.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/driver-validation.h’
Building ‘zephyr/CMakeFiles/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/driver_validation_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/kobj-types-enum.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/kobj-types-enum.h’
Building ‘zephyr/include/generated/otype-to-str.h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/kobj_types_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/misc/generated/syscalls.json’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/misc/generated/syscalls.json’
Building ‘zephyr/include/generated/syscall_list.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_list.h’
Building ‘zephyr/CMakeFiles/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_dispatch.c’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_list_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/syscall_macros.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/syscall_macros.h’
Building ‘zephyr/CMakeFiles/syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/syscall_macros_h_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj’ from solution ‘build’ in configuration ‘Common’
1> Compiling ‘offsets.c’
1> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu.h:16:0,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/arch.h:246,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/cpu.h:17,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel_includes.h:34,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:17,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/kernel/include/kernel_structs.h:10,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/arch/arm/core/offsets/offsets.c:26:
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:60:1: warning: multi-line comment [-Wcomment]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:123:3: warning: multi-line comment [-Wcomment]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:144:3: warning: multi-line comment [-Wcomment]
1> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/arch.h:246:0,
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu.h:43:3: warning: multi-line comment [-Wcomment]
1> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/kernel/include/kernel_structs.h:10:0,
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:268:16: warning: 'k_object_access_grant' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:283:16: warning: 'k_object_release' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:318:17: warning: 'k_object_alloc' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:720:19: warning: 'k_thread_create' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:805:17: warning: 'k_sleep' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:821:17: warning: 'k_usleep' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:831:16: warning: 'k_busy_wait' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:843:16: warning: 'k_yield' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:857:16: warning: 'k_wakeup' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:866:19: warning: 'k_current_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:883:16: warning: 'k_thread_abort' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:896:16: warning: 'k_thread_start' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:994:15: warning: 'k_thread_priority_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1024:16: warning: 'k_thread_priority_set' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1151:16: warning: 'k_thread_suspend' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1166:16: warning: 'k_thread_resume' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1234:15: warning: 'k_is_preempt_thread' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1291:16: warning: 'k_thread_custom_data_set' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1301:17: warning: 'k_thread_custom_data_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1316:15: warning: 'k_thread_name_set' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1339:15: warning: 'k_thread_name_copy' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1569:16: warning: 'k_timer_start' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1588:16: warning: 'k_timer_stop' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1602:17: warning: 'k_timer_status_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1621:17: warning: 'k_timer_status_sync' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1635:17: warning: 'k_timer_remaining_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1657:16: warning: 'k_timer_user_data_set' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1675:17: warning: 'k_timer_user_data_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1704:17: warning: 'k_uptime_get' used but never defined
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1873:16: warning: 'k_queue_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1890:16: warning: 'k_queue_cancel_wait' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1924:17: warning: 'k_queue_alloc_append' used but never defined
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:1958:17: warning: 'k_queue_alloc_prepend' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2026:17: warning: 'k_queue_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2088:15: warning: 'k_queue_is_empty' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2104:17: warning: 'k_queue_peek_head' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2120:17: warning: 'k_queue_peek_tail' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2613:17: warning: 'k_stack_alloc_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2641:16: warning: 'k_stack_push' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:2661:15: warning: 'k_stack_pop' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3255:16: warning: 'k_mutex_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3276:15: warning: 'k_mutex_lock' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3293:16: warning: 'k_mutex_unlock' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3345:16: warning: 'k_sem_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3370:15: warning: 'k_sem_take' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3385:16: warning: 'k_sem_give' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3397:16: warning: 'k_sem_reset' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3417:24: warning: 'k_sem_count_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3575:15: warning: 'k_msgq_alloc_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3598:15: warning: 'k_msgq_put' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3618:15: warning: 'k_msgq_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3635:15: warning: 'k_msgq_peek' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3649:16: warning: 'k_msgq_purge' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3662:17: warning: 'k_msgq_num_free_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3675:17: warning: 'k_msgq_get_attrs' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:3693:17: warning: 'k_msgq_num_used_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4041:15: warning: 'k_pipe_alloc_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4063:15: warning: 'k_pipe_put' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4087:15: warning: 'k_pipe_get' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4668:15: warning: 'k_poll' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4682:16: warning: 'k_poll_signal_init' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4690:16: warning: 'k_poll_signal_reset' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4708:16: warning: 'k_poll_signal_check' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:4736:15: warning: 'k_poll_signal_raise' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:5163:16: warning: 'k_str_out' declared 'static' but never defined [-Wunused-function]
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:5189:15: warning: 'k_float_disable' declared 'static' but never defined [-Wunused-function]
1> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/kernel/include/kernel_offsets.h:6:0,
1>                  from C:/Users/alcala_an/Documents/ncs/zephyr/arch/arm/core/offsets/offsets.c:27:
1> C:/Users/alcala_an/Documents/ncs/zephyr/include/device.h:295:26: warning: 'device_get_binding' declared 'static' but never defined [-Wunused-function]
Building ‘zephyr/offsets’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/include/generated/offsets.h’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/include/generated/offsets.h’
Building ‘zephyr/CMakeFiles/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/offsets_h’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_app’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__cortex_m’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_arch__arm__core__cortex_m__mpu’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_drivers__serial’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_kernel’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_lib__libc__newlib’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_lib__posix’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_subsys__net’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_subsys__net__ip’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_zephyr’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker.cmd’ from solution ‘build’ in configuration ‘Common’
1> Combining ‘zephyr/linker.cmd’
Building ‘zephyr/CMakeFiles/linker_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘zephyr/linker_script_target’ from solution ‘build’ in configuration ‘Common’
Building ‘cmake_object_order_depends_target_zephyr_prebuilt’ from solution ‘build’ in configuration ‘Common’
Building ‘app/libapp.a’ from solution ‘build’ in configuration ‘Common’
2> Compiling ‘main.c’
2> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu.h:16:0,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/arch.h:246,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/cpu.h:17,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel_includes.h:34,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/kernel.h:17,
2>                  from C:/Users/alcala_an/Documents/ncs/zephyr/include/zephyr.h:18,
2>                  from ../src/main.c:7:
2> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:60:1: warning: multi-line comment [-Wcomment]
2> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:123:3: warning: multi-line comment [-Wcomment]
2> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu_v8m.h:144:3: warning: multi-line comment [-Wcomment]
2> In file included from C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/arch.h:246:0,
2> C:/Users/alcala_an/Documents/ncs/zephyr/include/arch/arm/cortex_m/mpu/arm_mpu.h:43:3: warning: multi-line comment [-Wcomment]
2> ../src/main.c:12:10: fatal error: lte_lc.h: No such file or directory
2> compilation terminated.
Build failed
    What example are you compiling?
    Have you checked out the repositories with west? "cd /path/to/ncs/nrf && west update" - this should update all the repositories to match your checked out "nrf" revision.
    PS: also try to delete your build directory, then re-importing the project.
    Håkon
  • It is happening with all the samples, I tried with AT_CLIENT, SPI,udp_with_psm ....I deleted and re-importing the project from Github twice and the issues are still there... May I clone all without using west? maybe it works..
    Thanks & Regards,
    Ana
  • Have you ensured that "west update" has been called from the "nrf" directory? If this fails, please show the output.
  • yes,  I called west update from nrf and tried again, did not work...
    C:\Users\alcala_an\Documents\ncs\nrf>west update
    === updating hal_atmel (modules\hal\atmel):
    --- hal_atmel: checked out 04ff67a0826a51041e51034faf8fc4d3eeacd846 as detached
    HEAD
    === updating ci-tools (tools\ci-tools):
    --- ci-tools: checked out e01f3bce2a94847253369efb9a081f5c0e9ec882 as detached H
    EAD
    === updating civetweb (modules\lib\civetweb):
    --- civetweb: checked out 99129c5efc907ea613c4b73ccff07581feb58a7a as detached H
    EAD
    === updating esp-idf (modules\hal\esp-idf):
    --- esp-idf: checked out 6835bfc741bf15e98fb7971293913f770df6081f as detached HE
    AD
    === updating fatfs (modules\fs\fatfs):
    --- fatfs: checked out df96914dd989907f3a5de4cb95b116c2f305820d as detached HEAD
    === updating hal_cypress (modules\hal\cypress):
    --- hal_cypress: checked out a12d92816a53a521d79cefcf5c38b9dc8a4fed6e as detache
    d HEAD
    === updating hal_nordic (modules\hal\nordic):
    --- hal_nordic: checked out 1b14177ff2176a1d17f3dd5e7e217f44337255db as detached
     HEAD
    === updating hal_openisa (modules\hal\openisa):
    --- hal_openisa: checked out be5c01f86c96500def5079bcc58d2baefdffb6c8 as detache
    d HEAD
    === updating hal_microchip (modules\hal\microchip):
    --- hal_microchip: checked out 85302959c0c659311cf90ac51d133e5ce19c9288 as detac
    hed HEAD
    === updating hal_silabs (modules\hal\silabs):
    --- hal_silabs: checked out 9151e614c23997074acd1096a3e8a9e5c255d5b9 as detached
     HEAD
    === updating hal_st (modules\hal\st):
    --- hal_st: checked out 0ec40aed8087f26bd9ac1b70fb5a6c326a6451aa as detached HEA
    D
    === updating hal_stm32 (modules\hal\stm32):
    --- hal_stm32: checked out 886636e6db209abe6a05a95be5ec7b85a3dd7237 as detached
    HEAD
    === updating hal_ti (modules\hal\ti):
    --- hal_ti: checked out 7a82e93e14766ef6e42df9915ea2ab8e3b952a8b as detached HEA
    D
    === updating libmetal (modules\hal\libmetal):
    --- libmetal: checked out 45e630d6152824f807d3f919958605c4626cbdff as detached H
    EAD
    === updating lvgl (modules\lib\gui\lvgl):
    --- lvgl: checked out d4708d0a432e95f51bdc712591ba5295b751140c as detached HEAD
    === updating mbedtls (modules\crypto\mbedtls):
    --- mbedtls: checked out bbcb1b14285ac1b694d8c7e47c2f139c80b7fc4c as detached HE
    AD
    === updating mcumgr (modules\lib\mcumgr):
    --- mcumgr: checked out 84934959d2d1722a23b7e7e200191ae4a6f96168 as detached HEA
    D
    === updating net-tools (tools\net-tools):
    --- net-tools: checked out 30b7efa827b04d2e47840716b0372737fe7d6c92 as detached
    HEAD
    === updating nffs (modules\fs\nffs):
    --- nffs: checked out bc62a2fa9d98ddb5d633c932ea199bc68e10f194 as detached HEAD
    === updating hal_nxp (modules\hal\nxp):
    --- hal_nxp: checked out 97265a5396edc6a9de5f2fb643d505f37064e606 as detached HE
    AD
    === updating open-amp (modules\lib\open-amp):
    --- open-amp: checked out 9b591b289e1f37339bd038b5a1f0e6c8ad39c63a as detached H
    EAD
    === updating openthread (modules\lib\openthread):
    --- openthread: checked out 3c32244f098f8daf8741efe0a2ad839b67f8567f as detached
     HEAD
    === updating segger (modules\debug\segger):
    --- segger: checked out 6fcf61606d6012d2c44129edc033f59331e268bc as detached HEA
    D
    === updating tinycbor (modules\lib\tinycbor):
    --- tinycbor: checked out 6966f6140cb870b792330a5186020eb1f4151f3e as detached H
    EAD
    === updating littlefs (modules\fs\littlefs):
    --- littlefs: checked out fe9572dd5a9fcf93a249daa4233012692bd2881d as detached H
    EAD
  • That west.yaml looks to be fetching the incorrect repositories.
    What does "git remote -v" give as the output in your case? It almost looks like you are using the upstream zephyr?
    You seem to lack zephyr and other repo's that are to be updated by "nrf/west.yaml". As reference; here's my output of west update in the ncs/nrf folder:
    $ west update
    === updating zephyr (zephyr):
    --- zephyr: checked out b687d5d02214db82e5bd224e73b8050742a234e0 as detached HEAD
    === updating nffs (modules/fs/nffs):
    === updating segger (modules/debug/segger):
    --- segger: checked out 6fcf61606d6012d2c44129edc033f59331e268bc as detached HEAD
    === updating mbedtls (modules/crypto/mbedtls):
    --- mbedtls: checked out 9d56815aa4abf99a6e96af6ed035968add4b8cab as detached HEAD
    === updating mcuboot (mcuboot):
    --- mcuboot: checked out 891d18dc8e897292c78f9f1ae650e494770a8cd8 as detached HEAD
    === updating mcumgr (modules/lib/mcumgr):
    --- mcumgr: checked out f663988d35da559a37f263d369842dbce309d1fa as detached HEAD
    === updating tinycbor (modules/lib/tinycbor):
    --- tinycbor: checked out 86d5ed5dd544b107d2d0882961a19c2c6cb06572 as detached HEAD
    === updating ci-tools (tools/ci-tools):
    --- ci-tools: checked out 20aa511fbd302ba8429a9ab04ee96c201b547743 as detached HEAD
    === updating net-tools (tools/net-tools):
    --- net-tools: checked out 30b7efa827b04d2e47840716b0372737fe7d6c92 as detached HEAD
    === updating nrfxlib (nrfxlib):
    --- nrfxlib: checked out dc9e1fbd146f5032fd3651b1e7705d8b3258ecc2 as detached HEAD
    === updating cmock (test/cmock):
    --- cmock: checked out c243b9a7a7b3c471023193992b46cf1bd1910450 as detached HEAD
    === updating unity (test/cmock/vendor/unity):
    --- unity: checked out 031f3bbe45f8adf504ca3d13e6f093869920b091 as detached HEAD
    === updating mbedtls-nrf (mbedtls):
    --- mbedtls-nrf: checked out 04a049bda1ceca48060b57bc4bcf5203ce591421 as detached HEAD
    === updating civetweb (modules/lib/civetweb):
    --- civetweb: checked out 99129c5efc907ea613c4b73ccff07581feb58a7a as detached HEAD
    === updating fatfs (modules/fs/fatfs):
    === updating hal_nordic (modules/hal/nordic):
    --- hal_nordic: checked out 080d1dff4a07b5798ab979fde40dde8da452b854 as detached HEAD
    === updating hal_st (modules/hal/st):
    --- hal_st: checked out fa481784b3c49780f18d50bafe00390ccb62b2ec as detached HEAD
    === updating libmetal (modules/hal/libmetal):
    --- libmetal: checked out 45e630d6152824f807d3f919958605c4626cbdff as detached HEAD
    === updating lvgl (modules/lib/gui/lvgl):
    === updating open-amp (modules/lib/open-amp):
    --- open-amp: checked out 9b591b289e1f37339bd038b5a1f0e6c8ad39c63a as detached HEAD
    === updating openthread (modules/lib/openthread):
    --- openthread: checked out 882e7074b5986027b85cb4f3ba1dc563a11ca013 as detached HEAD
    === updating littlefs (modules/fs/littlefs):
    --- littlefs: checked out fe9572dd5a9fcf93a249daa4233012692bd2881d as detached HEAD
    === updating mipi-sys-t (modules/debug/mipi-sys-t):
    --- mipi-sys-t: checked out baf51863f19f009b92e762115ba5572a5b996b92 as detached HEAD
    Håkon
