Increasing the size of attribute table
I'm using SDK v15.3.0 which has s132 6.1.1 to program an nRF521832. I had a single custom service on my stack and that was working well. I added a second service and I got ERROR 4 [NRF_ERROR_NO_MEM]. I understand that this is caused by the attribute table size not being large enough. so I increased it from the default - BLE_GATTS_ATTR_TAB_SIZE_DEFAULT = 1408 - to 3000 - approximately more than the double as a starting point. This is definitely an overkill as my second custom service has less characteristics than the first. This is what I did to increase the size of the attribute table - line 18 was added:
    ret_code_t err_code;
    uint32_t ram_start = 0;
    ble_cfg_t ble_cfg;
    memset(&ble_cfg, 0, sizeof ble_cfg);
    ble_cfg.conn_cfg.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
    ble_cfg.conn_cfg.params.gatts_conn_cfg.hvn_tx_queue_size = 13;
    ble_cfg.gatts_cfg.attr_tab_size.attr_tab_size = 3000;
    err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATTS, &ble_cfg, ram_start);
    // Enable BLE stack.
I learned that I also have to increase both RAM_START and RAM_SIZE - according to this thread
Those are the linker macros I had defined before increasing them, and they were working fine for a single service:
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x80000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x10000
FLASH_START=0x26000
FLASH_SIZE=0x5a000
RAM_START=0x20002b90
RAM_SIZE=0xd470
And this is after I added 1600 to RAM_START and RAM_SIZE:
FLASH_PH_START=0x0
RAM_PH_SIZE=0x10000
FLASH_START=0x26000
FLASH_SIZE=0x5a000
RAM_START=0x200031D0
RAM_SIZE=0xdab0
I'm not sure what else I'm missing, but I still get the same error.
One other interesting thing I'm getting is that if I set ble_cfg.gatts_cfg.attr_tab_size.attr_tab_size = 2816, I get Error 7 (invalid parameter). I can only seem to be able to use values that are multiples of 100. Is it meant to be this way?
Thanks
