Increasing the size of attribute table
I'm using SDK v15.3.0 which has s132 6.1.1 to program an nRF521832. I had a single custom service on my stack and that was working well. I added a second service and I got ERROR 4 [NRF_ERROR_NO_MEM]. I understand that this is caused by the attribute table size not being large enough. so I increased it from the default - BLE_GATTS_ATTR_TAB_SIZE_DEFAULT = 1408 - to 3000 - approximately more than the double as a starting point. This is definitely an overkill as my second custom service has less characteristics than the first. This is what I did to increase the size of the attribute table - line 18 was added:
    ret_code_t err_code;
    uint32_t ram_start = 0;
    ble_cfg_t ble_cfg;
    memset(&ble_cfg, 0, sizeof ble_cfg);
    ble_cfg.conn_cfg.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
    ble_cfg.conn_cfg.params.gatts_conn_cfg.hvn_tx_queue_size = 13;
    ble_cfg.gatts_cfg.attr_tab_size.attr_tab_size = 3000;
    err_code = sd_ble_cfg_set(BLE_CONN_CFG_GATTS, &ble_cfg, ram_start);
    // Enable BLE stack.
I learned that I also have to increase both RAM_START and RAM_SIZE - according to this thread.
Those are the linker macros I had defined before increasing them, and they were working fine for a single service:
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x80000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x10000
FLASH_START=0x26000
FLASH_SIZE=0x5a000
RAM_START=0x20002b90
RAM_SIZE=0xd470
And this is after I added 1600 to RAM_START and RAM_SIZE:
FLASH_PH_START=0x0
RAM_PH_SIZE=0x10000
FLASH_START=0x26000
FLASH_SIZE=0x5a000
RAM_START=0x200031D0
RAM_SIZE=0xdab0
I'm not sure what else I'm missing, but I still get the same error.
One other interesting thing I'm getting is that if I set ble_cfg.gatts_cfg.attr_tab_size.attr_tab_size = 2816, I get Error 7 (invalid parameter). I can only seem to be able to use values that are multiples of 100. Is it meant to be this way?
Thanks
  • Hi
    Please check out this case, which explains how to properly set the attribute table size. The BLE_GATTS_ATTR_TAB_SIZE_DEFAULT define is from a SoftDevice header and does not change anything if you redefine it to another value.
    Simon
  • I'm not redefining BLE_GATTS_ATTR_TAB_SIZE_DEFAULT. I'm using sd_ble_cfg_set() to set the attribute table size. I do it after using nrf_sdh_ble_default_cfg_set and it has been working well for me in configuring queue size. I figured I was not passing the correct config ID to sd_ble_cfg_set and I changed it to BLE_GATTS_CFG_ATTR_TAB_SIZE but still no luck. This is my ble_stack_init function after the fixes:
        ble_cfg_t ble_cfg;
        err_code = sd_ble_cfg_set(BLE_GATTS_CFG_ATTR_TAB_SIZE, &ble_cfg, ram_start);
    I don't think that attribute table size of 3000 is not enough. The second service is smaller than the first as I mentioned previously, and 3000 is more than the double of the previous size.
    For reference, I tried only changing BLE_GATTS_ATTR_TAB_SIZE_DEFAULT in sdk_config.h but still no luck - same ERROR 4.
  • I just figured that ERROR 4 is being returned upon calling sd_ble_uuid_vs_add
  • I Fixed the problem by changing NRF_SDH_BLE_VS_UUID_COUNT to 2.
    Now I'm getting ERROR 12 upon calling ble_advertising_init. I understand that this is caused by exceeding the advertising packet max payload of 31 bytes. What options do I have to solve this? Is there a way to increase it?
    Please note that I don't need to be transmitting all services and characteristics at the same time, so maybe I could activate and deactivate services/characteristics accordingly.
  • Hi
    Can you please create a new ticket on this, as we strive to keep each ticket to one specific subject here on DevZone.
    Simon
