Hello
I am writing a peripheral emulator application on android.
My peripherals include 2 services and 4 characteristics. I tested my application with nRF Connect on the computer, it didn't get any errors.
My central device, works very well with a peripheral using nRF52832.
When I tried to connect the application and the central device, the connection was successful. I have enabled the notification flags. But I cannot write data from the central device to the application via any characteristic. I set the breakpoint in the onCharacteristicWriteRequest event, but without anything going on, the application still runs while I send data. With nRF Connect, the onCharacteristicWriteRequest event is still normal.
Please answer and give me solution, thanks
i'm using SDK 15.3, SoC: nRF52832, SD: 6.1.1 and Android 9
Central code:
Write data to characteristic
uint32_t ble_smk_info_write(ble_smk_t * p_smk, uint8_t * data, uint16_t length)
VERIFY_PARAM_NOT_NULL(p_smk);
if (p_smk->conn_handle == BLE_CONN_HANDLE_INVALID)
ble_gattc_write_params_t const write_params = {.write_op = BLE_GATT_OP_WRITE_CMD,
.flags = BLE_GATT_EXEC_WRITE_FLAG_PREPARED_WRITE,
.handle = p_smk->peer_info_db.char_handle,
.offset = 0,
.len = length,
.p_value = data};
return sd_ble_gattc_write(p_smk->conn_handle, &write_params);
Android code:
Setup service and characteristic
mCharKey = new BluetoothGattCharacteristic(VNET_CHAR_KEY, BluetoothGattCharacteristic.PROPERTY_NOTIFY, 1);
BluetoothGattDescriptor descriptor = new BluetoothGattDescriptor(CLIENT_CHARACTERISTIC_CONFIGURATION_UUID,
(BluetoothGattDescriptor.PERMISSION_READ | BluetoothGattDescriptor.PERMISSION_WRITE));
descriptor.setValue(new byte[]{0, 0});
mCharKey.addDescriptor(descriptor);
mCharInfo = new BluetoothGattCharacteristic(VNET_CHAR_INFO,BluetoothGattCharacteristic.PROPERTY_WRITE, BluetoothGattCharacteristic.PERMISSION_WRITE);
mCharInfo.setValue(new byte[] {0, 0, 0, 0, 0, 0, 0, 0, 0});
mServiceKey = new BluetoothGattService(VNET_SERVICE_KEY, BluetoothGattService.SERVICE_TYPE_PRIMARY);
mServiceKey.addCharacteristic(mCharKey);
mServiceKey.addCharacteristic(mCharInfo);
mCharCmd = new BluetoothGattCharacteristic(VNET_CHAR_CMD, BluetoothGattCharacteristic.PROPERTY_NOTIFY, 1);
BluetoothGattDescriptor descriptor1 = new BluetoothGattDescriptor(CLIENT_CHARACTERISTIC_CONFIGURATION_UUID,
descriptor1.setValue(new byte[]{0, 0});
mCharCmd.addDescriptor(descriptor1);
mCharResp = new BluetoothGattCharacteristic(VNET_CHAR_RESP, BluetoothGattCharacteristic.PROPERTY_WRITE, BluetoothGattCharacteristic.PERMISSION_WRITE);
mCharResp.setValue(new byte[] {0, 0, 0, 0, 0, 0, 0, 0, 0});
mServicePhone = new BluetoothGattService(VNET_SERVICE_PHONE, BluetoothGattService.SERVICE_TYPE_PRIMARY);
mServicePhone.addCharacteristic(mCharCmd);
mServicePhone.addCharacteristic(mCharResp);
Callback
@Override
public void onCharacteristicWriteRequest(BluetoothDevice device, int requestId, BluetoothGattCharacteristic characteristic, boolean preparedWrite, boolean responseNeeded, int offset, byte[] value) {
super.onCharacteristicWriteRequest(device, requestId, characteristic, preparedWrite, responseNeeded, offset, value);
String s = "";
for (byte vl: value) {
s = String.format("%02X ", vl);
Log.v(TAG, "Char: " + characteristic.getUuid().toString() + " offset " + offset + " Value " + s);
if(tmp == mCurrentServiceFragment.getCharacteristicUUID().get(1))
mGattServer.sendResponse(device, requestId, BluetoothGatt.GATT_SUCCESS, 0, null);
