Receiving data from UART via a peripheral device
Hi
I am working with a Nordic nrf52840dk using segge and sdk 16.
I am using the nordic UART example in examples/peripheral/uart.
The issue I am having is that my data being sent to this device can not be read from the nordic board.
Below is an example of the code going into my Putty terminal from my UART peripheral device.
1,1183,1,1169
1,1183,1,1169
1,1183,1,1169
1,1183,1,1169
1,1183,1,1169
1,1183,1,1169
This device has 4 wire connections RX,TX,CTS and RTS. My connections are listed below:
Note this is the default.
#define RX_PIN_NUMBER  8
#define TX_PIN_NUMBER  6
#define CTS_PIN_NUMBER 7
#define RTS_PIN_NUMBER 5
The first thing i tried was running the code with no change to see if app_uart_get(&cr) would pull this data. Unfortunately it did not. It does however, pull data that i type into the terminal.
What I want to do is to take this data from the UART(Sensor data) and store it as a variable for handling later on.
I which to know how I can pull this data from the serial connection.
Side note when the device (UART) is plugged in printing from putty does not run. If I unplug the device then printing works fine.  Below is my main code (from example).
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          UART_HWFC,
          false,
#if defined (UARTE_PRESENT)
          NRF_UARTE_BAUDRATE_115200
#else
#if defined (UART_PRESENT)
          NRF_UART_BAUDRATE_115200
#else
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_HIGH,
                         //APP_IRQ_PRIORITY_LOWEST,
                         err_code);
#ifndef ENABLE_LOOPBACK_TEST
    printf("\r\nUART example started.\r\n");
    while (true)
        uint8_t cr;
        while (app_uart_get(&cr) != NRF_SUCCESS);
        while (app_uart_put(cr) != NRF_SUCCESS);
        if (cr == 'q' || cr == 'Q')
            printf(" \r\nExit!\r\n");
            while (true)
                // Do nothing.
#else
    // This part of the example is just for testing the loopback .
    while (true)
        uart_loopback_test();
  • Hi Einar,
    Sorry for the confusion I do not need to use the terminal.
    • So i need to disable logging in the sdk_config.h?
    • Move the UART pin definitions from 5-8
    • Then I should be able to use the app_uart_get(&cr) to get the data?
    Also what #define is for the logging module?
    I also presume I need to make this 0.
    Yes, that is correct. Set NRF_LOG_ENABLED to 0 (if it is not already). That will disable UART logging. And use other (non-used) GPIO pins. That should be all Slight smile
  • Ok I've changed my pin outs to below:
    #define RX_PIN_NUMBER  NRF_GPIO_PIN_MAP(0,13)//8
    #define TX_PIN_NUMBER  NRF_GPIO_PIN_MAP(0,11)//6
    #define CTS_PIN_NUMBER NRF_GPIO_PIN_MAP(0,12)//7
    #define RTS_PIN_NUMBER NRF_GPIO_PIN_MAP(0,10)//5
    I have then migrated my pin connections from my UART device to this.
    However, when I run though the debugger and have a break point on:
    It never runs. Therefore, I am not reading this data. What am I doing wrong?
  • I cannot say without knowing more. Can you share your code? At least the UART related? What state is the device in when it does not reach your breakpoint? have you tried stepping (will not work well with the SoftDevice enabled).
  • I have tried stepping through the code and it holds on:
    My main code is:
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup uart_example_main main.c
     * @ingroup uart_example
     * @brief UART Example Application main file.
     * This file contains the source code for a sample application using UART.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #include "nrf_uart.h"
    #include "nrf_uarte.h"
    //#define ENABLE_LOOPBACK_TEST  /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
    #define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. 256*/
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. 256*/
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    #ifdef ENABLE_LOOPBACK_TEST
    /* Use flow control in loopback test. */
    #define UART_HWFC APP_UART_FLOW_CONTROL_ENABLED
    /** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
    static void show_error(void)
        bsp_board_leds_on();
        while (true)
            // Do nothing.
    /** @brief Function for testing UART loop back.
     *  @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
     *  @note  @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
    static void uart_loopback_test()
        uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
        uint8_t   rx_data;
        // Start sending one byte and see if you get the same
        for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
            uint32_t err_code;
            while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
            nrf_delay_ms(10);
            err_code = app_uart_get(&rx_data);
            if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
                show_error();
        return;
    #else
    /* When UART is used for communication with the host do not use flow control.*/
    #define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
        uint32_t err_code;
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
    #else
    #else
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             err_code);
        //printf("\r\nUART example started.\r\n");
        while (true)
            uint8_t cr;
            if (cr == 't' || cr == 't')
                printf("\r\n Test passed\r\n");
                while (true)
                    // Do nothing.
    #else
        while (true)
    I cant share the config code its too large.
    Using sdk 16 NRF52840 pca10056.
    Also my peripheral device posts data once per second to the Nordic board.
    Below is showing my connection setup (physically).
