Hello All,
I am working on nrf52810 board
Using sdk 14.2
I am trying to modify some bytes of advertising packet .
I am referring the previous post as link given below
https://devzone.nordicsemi.com/f/nordic-q-a/8854/fully-custom-advertisement-data
I have modified the advertising init function as per the above link.
But i am getting warning like incompatible type.
how to solve this issue with proper advertising .
What modification is required in the code..?
Please reply if anyone having solution for this issue.
I am attaching the my main.c file please verify and let me know any changes required.
* Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
* @brief Blinky Sample Application main file.
* This file contains the source code for a sample server application using the LED Button service.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "boards.h"
#include "app_timer.h"
#include "app_button.h"
#include "ble_lbs.h"
#include "nrf_ble_gatt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "bsp.h"
#define APP_FEATURE_NOT_SUPPORTED BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2 /**< Reply when unsupported features are requested. */
#define ADVERTISING_LED BSP_BOARD_LED_3 /**< Is on when device is advertising. */
#define CONNECTED_LED BSP_BOARD_LED_1 /**< Is on when device has connected. */
#define LEDBUTTON_LED BSP_BOARD_LED_2 /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON BSP_BUTTON_0 /**< Button that will trigger the notification event with the LED Button Service */
#define DEVICE_NAME "FIND_91" /**< Name of device. Will be included in the advertising data. */
#define DEVICE_NAME_P "FinD_91" /**< Name of device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL 80 //500 /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(20000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define Single_click_INTERVAL APP_TIMER_TICKS(1000)
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_LBS_DEF(m_lbs); /**< LED Button Service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
APP_TIMER_DEF(long_button_action);
APP_TIMER_DEF(single_button_action);
APP_TIMER_DEF(Double_button_action);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint32_t cnt = 0, temp = 0, advertising_flag = 0;
static uint8_t press_cnt = 0, temp_click = 0;
//static uint32_t cnt = 0;
/**@brief Function for assert macro callback.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for the LEDs initialization.
* @details Initializes all LEDs used by the application.
static void leds_init(void)
bsp_board_leds_init();
/**@brief Function for the Timer initialization.
* @details Initializes the timer module.
static void timers_init(void)
// Initialize timer module, making it use the scheduler
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ret_code_t err_code;
ble_gap_conn_params_t gap_conn_params;
if (advertising_flag == 1) //for normal advert
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
else if (advertising_flag == 2) //for panic advert
(const uint8_t *)DEVICE_NAME_P,
strlen(DEVICE_NAME_P));
// err_code = sd_ble_gap_device_name_set(&sec_mode,
// (const uint8_t *)DEVICE_NAME,
// strlen(DEVICE_NAME));
// APP_ERROR_CHECK(err_code);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
static uint8_t adata[31];
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
// ble_advdata_t advdata;
// ble_advdata_t srdata;
// ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
// // Build and set advertising data
// memset(&advdata, 0, sizeof(advdata));
// advdata.name_type = BLE_ADVDATA_FULL_NAME;
// advdata.include_appearance = true;
// advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
// memset(&srdata, 0, sizeof(srdata));
// srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
// srdata.uuids_complete.p_uuids = adv_uuids;
// err_code = ble_advdata_set(&advdata, &srdata);
//uint8_t adata[31];
//int i;
// memset(adata, 0x00, sizeof(adata));
// adata[0] = 30;
// adata[1] = BLE_GAP_AD_TYPE_MANUFACTURER_SPECIFIC_DATA;
// // now fill the 29 bytes with whatever you want
// for(i = 2; i < sizeof(adata); i++)
// adata[i] = i;
// err_code = sd_ble_gap_adv_data_set(adata, sizeof(adata), NULL, 0);
// ret_code_t err_code;
// Build advertising data struct to pass into @ref ble_advertising_init.
// ble_adv_modes_config_t options = {0};
// options.ble_adv_fast_enabled = BLE_ADV_FAST_ENABLED;
// options.ble_adv_fast_interval = APP_ADV_INTERVAL;
// options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
// err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
uint8_t adv_data[13] = {0};
uint8_t sr_data[20] = {0};
// flags for discoverable/connectable
adv_data[0] = 0x02; // ad field length = 2 bytes
adv_data[1] = 0x01; // ad field type = 0x01 [Flags)
adv_data[2] = 0x06; // flags = 0x06, connectable/undirected
// tx power field advertisement, iOS apps may need this
adv_data[3] = 0x02; // ad field length = 2 bytes
adv_data[4] = 0x0a; // ad field type = 0x0A [TX Power)
adv_data[5] = 0x03; // TX power in dBm
// NOTE: TX power is a signed 8-bit value, and is not changed automatically
// when using "hardware_set_txpower[<power>)". This may be anywhere from -23
// to +3 based on your settings. Negative values may be converted to two's
// complement form by adding 256, so for example -23 dBm would be 233 or 0xE9.
// custom manufacturer
adv_data[6] = 0x06; // ad field length = 5 bytes [arbitrary, maybe more or less but minimum 3)
adv_data[7] = 0xff; // ad field type = 0xFF [Manufacturer Specific Data)
adv_data[8] = 0xff; // unknown/prototype Company Identifier Code - octet 2
adv_data[9] = 0xff; // unknown/prototype Company Identifier Code - octet 1
adv_data[10] = 0xb1; // custom data byte //1 [can be anything)
adv_data[11] = 0xb2; // custom data byte //2 [can be anything)
adv_data[12] = 0xb3; // custom data byte //3 (can be anything)
// NOTE: manufacturer data fields should contain the Company Identifier Code
// in order to stay within BT 4.0 spec. You should also ideally obtain an
// an official Company Identifier Code, but 0xFFFF is suitable for development.
// (this is why the minimum ad field length for this is 3, so the CIC fits)
// More bytes are possible here, but not necessary for this demo.
// Compare with automatically generated ad packets from other
// demo projects to see what else you might put here, or read
// the relevant portions of the Bluetooth 4.0 Core Spec document
// for greater detail.
// build custom scan response data
// get Bluetooth MAC address of this device (NOTE: this is little-endian!)
sr_data[0] = 0x13; // ad field length = 19 bytes (0x13)
sr_data[1] = 0x09; // ad field type = 0x09 (Complete local name)
sr_data[2] = 0x06; // 'M'
sr_data[3] = 0x79; // 'y'
sr_data[4] = 0x20; // ' '
sr_data[5] = 0x57; // 'W'
sr_data[6] = 0x69; // 'i'
sr_data[7] = 0x64; // 'd'
sr_data[8] = 0x67; // 'g'
sr_data[9] = 0x65; // 'e'
sr_data[10] = 0x74; // 't'
sr_data[11] = 0x20; // ' '
sr_data[12] = 0x01;
sr_data[13] = 0x02;
sr_data[14] = 0x03;
sr_data[15] = 0x04;
sr_data[16] = 0x05;
sr_data[17] = 0x06;
sr_data[18] = 0x07;
sr_data[19] = 0x08;
// uint32_t err_code;
err_code = sd_ble_gap_adv_data_set(adv_data, 13, sr_data, 20);
err_code = sd_ble_gap_adv_start(adv_data, 1);
bsp_board_led_on(ADVERTISING_LED);
bsp_board_led_off(ADVERTISING_LED);
/**@brief Function for handling write events to the LED characteristic.
* @param[in] p_lbs Instance of LED Button Service to which the write applies.
* @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
if (led_state)
bsp_board_led_on(LEDBUTTON_LED);
NRF_LOG_INFO("Received LED ON!");
bsp_board_led_off(LEDBUTTON_LED);
NRF_LOG_INFO("Received LED OFF!");
ble_lbs_init_t init;
init.led_write_handler = led_write_handler;
err_code = ble_lbs_init(&m_lbs, &init);
///**@brief Function for handling advertising events.
// * @details This function will be called for advertising events which are passed to the application.
// * @param[in] ble_adv_evt Advertising event.
//static void on_adv_evt(ble_adv_evt_t ble_adv_evt)
// switch (ble_adv_evt)
// case BLE_ADV_EVT_FAST:
// err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
// break;
// case BLE_ADV_EVT_IDLE:
// sleep_mode_enter();
// break;
// default:
// break;
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module that
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// ble_gap_adv_params_t adv_params;
// // Start advertising
// memset(&adv_params, 0, sizeof(adv_params));
// adv_params.type = BLE_GAP_ADV_TYPE_ADV_IND;
// adv_params.p_peer_addr = NULL;
// adv_params.fp = BLE_GAP_ADV_FP_ANY;
// adv_params.interval = APP_ADV_INTERVAL;
// adv_params.timeout = APP_ADV_TIMEOUT_IN_SECONDS;
// err_code = sd_ble_gap_adv_start(&adv_data, APP_BLE_CONN_CFG_TAG);
// bsp_board_led_on(ADVERTISING_LED);
// bsp_board_led_off(ADVERTISING_LED);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
bsp_board_led_on(CONNECTED_LED);
err_code = app_button_enable();
NRF_LOG_INFO("Disconnected");
bsp_board_led_off(CONNECTED_LED);
// err_code = app_button_disable();
advertising_start();
// Pairing not supported
err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
NULL,
NULL);
#ifndef S140
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_EVT_USER_MEM_REQUEST:
err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
ble_gatts_evt_rw_authorize_request_t req;
ble_gatts_rw_authorize_reply_params_t auth_reply;
req = p_ble_evt->evt.gatts_evt.params.authorize_request;
if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ) ||
(req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
(req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
&auth_reply);
} break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
#define BT0_SHORT_PUSH BSP_EVENT_KEY_0
#define BT0_LONG_PUSH BSP_EVENT_KEY_1
//#define BT0_double_PUSH BSP_EVENT_KEY_0
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BT0_SHORT_PUSH:
NRF_LOG_INFO("Short button press");
case BT0_LONG_PUSH:
NRF_LOG_INFO("Long button press");
// case BT0_double_PUSH:
// NRF_LOG_INFO("double button press");
// break;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_PUSH, BT0_SHORT_PUSH);
err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_LONG_PUSH, BT0_LONG_PUSH);
/*err_code = bsp_btn_ble_init(NULL, &startup_event);
*p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);*/
/**@brief Function for handling events from the button handler module.
* @param[in] pin_no The pin that the event applies to.
* @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
switch (pin_no)
case LEDBUTTON_BUTTON:
NRF_LOG_INFO("Send button state change.");
err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
if (err_code != NRF_SUCCESS &&
err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
err_code != NRF_ERROR_INVALID_STATE &&
err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(pin_no);
/**@brief Function for the Power Manager.
static void power_manage(void)
ret_code_t err_code = sd_app_evt_wait();
#if USE_BSP == 0
#define PIN_0 0
#define BUTTON_STATE_POLL_INTERVAL_MS 10UL
#define D_BUTTON_STATE_POLL_INTERVAL_MS 50UL
#define LONG_PRESS(MS) (uint32_t)(MS)/BUTTON_STATE_POLL_INTERVAL_MS
void single_click_timeout_handler(void * p_context)
uint32_t err_code;
if(press_cnt == 2)
NRF_LOG_INFO("double Button press");
press_cnt=0;
err_code = sd_ble_gap_adv_stop(); //stop advertising
advertising_flag = 2;
gap_params_init();
advertising_init();
advertising_start(); //panic normal advertising
press_cnt = 0;
if( temp_click == 0)
temp_click = 1;
NRF_LOG_INFO("single button press");
app_timer_stop(single_button_action);
advertising_flag = 1;
gap_params_init();
advertising_init();
advertising_start(); //start normal advertising
return;
/**@brief Function for the button handler module.
void button_press_timeout_handler(void * p_context)
uint32_t err_code;
static uint32_t cnt;
if (app_button_is_pushed(0))
cnt++;
if ( cnt >= LONG_PRESS(2000))
cnt = 0;
temp_click = 0;
NRF_LOG_INFO("Long Button press");
err_code = app_timer_start(long_button_action,
APP_TIMER_TICKS(BUTTON_STATE_POLL_INTERVAL_MS),
NULL);
cnt = 0 ;
press_cnt++;
if(press_cnt==1)
err_code = app_timer_start(single_button_action,
Single_click_INTERVAL,
NULL);
return;
void button_callback(uint8_t pin_no, uint8_t button_action)
uint32_t err_code;
if ((pin_no == BUTTON_1) && (button_action == APP_BUTTON_PUSH))
NULL);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
uint32_t err_code;
static app_button_cfg_t button_cfg;
button_cfg.pin_no = BUTTON_1;
button_cfg.button_handler = button_callback;
button_cfg.pull_cfg = NRF_GPIO_PIN_PULLUP;
button_cfg.active_state = APP_BUTTON_ACTIVE_LOW;
err_code = app_button_init(&button_cfg, 1, 100);
/*Enable an app timer instance to detect long button press*/
err_code = app_timer_create(&long_button_action, APP_TIMER_MODE_SINGLE_SHOT, button_press_timeout_handler);
err_code = app_timer_create(&single_button_action, APP_TIMER_MODE_SINGLE_SHOT, single_click_timeout_handler);
#endif //USE_BSP
static void log_init(void)
/**@brief Function for application main entry.
// Initialize.
leds_init();
timers_init();
log_init();
#if USE_BSP == 0
buttons_init();
#else
//buttons_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
NRF_LOG_INFO("FIND test example started.");
//advertising_start();
// Enter main loop.
for (;;)
//buttons_init();
power_manage();
Waiting for reply..
Rohit
