I am using NRF52832 Development board, SDK(nRF5_SDK_15.3.0_59ac345) from this i am using (/nRF5_SDK_15.3.0_59ac345 (4)/examples/ble_peripheral/ble_app_uart) example and i wanted to change base uuid of the NUS Service from
{{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}} /**< Used vendor specific UUID. */
To
{{0xFB, 0x34, 0x9B, 0x5F, 0x80, 0x00, 0x00, 0x80, 0x10, 0x00, 0x00, 0xF0, 0x0A, 0x00, 0x00}}
now the issue is when i change this uuid i am unable to broadcast.
here i am attaching the main.c, and custom_ble_service.c, custom_ble_service.h and sdk_config.h files
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "custom_ble_service.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
BLE_CUS_DEF(m_cus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
//static void nus_data_handler(ble_nus_evt_t * p_evt)
// if (p_evt->type == BLE_NUS_EVT_RX_DATA)
// uint32_t err_code;
// NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on UART.");
// NRF_LOG_HEXDUMP_DEBUG(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
// for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
// do
// err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
// if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
// NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
// APP_ERROR_CHECK(err_code);
// } while (err_code == NRF_ERROR_BUSY);
// if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
// while (app_uart_put('\n') == NRF_ERROR_BUSY);
volatile bool is_cus_notification_enabled = false;
static void cus_data_handler(ble_cus_evt_t * p_evt)
uint32_t err_code;
switch(p_evt->type)
case BLE_CUS_EVT_RX_DATA:
printf("Received data from BLE NUS. Writing data on UART: ");
printf("%s-------------------->%d", (char *)p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
do
case BLE_CUS_EVT_COMM_STARTED:
is_cus_notification_enabled = true;
case BLE_CUS_EVT_COMM_STOPPED:
uint32_t err_code;
ble_cus_init_t cus_init;
// Initialize NUS.
memset(&cus_init, 0, sizeof(cus_init));
cus_init.data_handler = cus_data_handler;
err_code = ble_cus_init(&m_cus, &cus_init);
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= m_ble_nus_max_data_len))
if (index > 1)
do
err_code = ble_cus_data_send(&m_cus, data_array, &length, m_conn_handle);
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
advertising_start();
// Enter main loop.
for (;;)
idle_state_handle();
__WFE();
// if(is_cus_notification_enabled)
* custom_ble_service.c
* Created on: Nov 27, 2019
* Author: imran
* Copyright (c) 2012 - 2019, Nordic Semiconductor ASA
#include "sdk_common.h"
#include "ble.h"
#include "ble_srv_common.h"
#define BLE_UUID_CUS_TX_CHARACTERISTIC 0x0af7 /**< The UUID of the TX Characteristic. */
#define BLE_UUID_CUS_RX_CHARACTERISTIC 0x0af6 /**< The UUID of the RX Characteristic. */
#define BLE_CUS_MAX_RX_CHAR_LEN 20 /**< Maximum length of the RX Characteristic (in bytes). */
#define BLE_CUS_MAX_TX_CHAR_LEN 20 /**< Maximum length of the TX Characteristic (in bytes). */
// 0xfb, 0x34, 0x9b, 0x5f, 0x80, 0x00, 0x00, 0x80,
// 0x00, 0x10, 0x00, 0x00, 0xf0, 0x0a, 0x00, 0x00
#define CUS_BASE_UUID {0xFB, 0x34, 0x9B, 0x5F, 0x80, 0x00, 0x00, 0x80, \
0x00, 0x10, 0x00, 0x00, 0xF0, 0x0A, 0x00, 0x01}
/**@brief Function for handling the @ref BLE_GAP_EVT_CONNECTED event from the SoftDevice.
* @param[in] p_nus Nordic UART Service structure.
* @param[in] p_ble_evt Pointer to the event received from BLE stack.
static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
ble_cus_evt_t evt;
ble_gatts_value_t gatts_val;
uint8_t cccd_value[2];
ble_cus_client_context_t * p_client = NULL;
err_code = blcm_link_ctx_get(p_cus->p_link_ctx_storage,
p_ble_evt->evt.gap_evt.conn_handle,
(void *) &p_client);
if (err_code != NRF_SUCCESS)
NRF_LOG_ERROR("Link context for 0x%02X connection handle could not be fetched.",
p_ble_evt->evt.gap_evt.conn_handle);
/* Check the hosts CCCD value to inform of readiness to send data using the RX characteristic */
memset(&gatts_val, 0, sizeof(ble_gatts_value_t));
gatts_val.p_value = cccd_value;
gatts_val.len = sizeof(cccd_value);
gatts_val.offset = 0;
err_code = sd_ble_gatts_value_get(p_ble_evt->evt.gap_evt.conn_handle,
p_cus->rx_handles.cccd_handle,
&gatts_val);
if ((err_code == NRF_SUCCESS) &&
(p_cus->data_handler != NULL) &&
ble_srv_is_notification_enabled(gatts_val.p_value))
if (p_client != NULL)
p_client->is_notification_enabled = true;
memset(&evt, 0, sizeof(ble_cus_evt_t));
evt.type = BLE_CUS_EVT_COMM_STARTED;
evt.p_cus = p_cus;
evt.conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
evt.p_link_ctx = p_client;
p_cus->data_handler(&evt);
/**@brief Function for handling the @ref BLE_GATTS_EVT_WRITE event from the SoftDevice.
static void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
ble_cus_evt_t evt;
ble_cus_client_context_t * p_client;
ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
p_ble_evt->evt.gatts_evt.conn_handle,
p_ble_evt->evt.gatts_evt.conn_handle);
evt.p_cus = p_cus;
evt.conn_handle = p_ble_evt->evt.gatts_evt.conn_handle;
if ((p_evt_write->handle == p_cus->tx_handles.cccd_handle) &&
(p_evt_write->len == 2))
if (ble_srv_is_notification_enabled(p_evt_write->data))
p_client->is_notification_enabled = false;
evt.type = BLE_CUS_EVT_COMM_STOPPED;
if (p_cus->data_handler != NULL)
else if ((p_evt_write->handle == p_cus->rx_handles.value_handle) &&
(p_cus->data_handler != NULL))
evt.type = BLE_CUS_EVT_RX_DATA;
evt.params.rx_data.p_data = p_evt_write->data;
evt.params.rx_data.length = p_evt_write->len;
// Do Nothing. This event is not relevant for this service.
/**@brief Function for handling the @ref BLE_GATTS_EVT_HVN_TX_COMPLETE event from the SoftDevice.
static void on_hvx_tx_complete(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
ble_cus_evt_t evt;
return;
if (p_client->is_notification_enabled)
evt.type = BLE_CUS_EVT_TX_RDY;
evt.p_cus = p_cus;
void ble_cus_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
if ((p_context == NULL) || (p_ble_evt == NULL))
return;
ble_cus_t * p_cus = (ble_cus_t *)p_context;
on_connect(p_cus, p_ble_evt);
case BLE_GATTS_EVT_WRITE:
on_write(p_cus, p_ble_evt);
case BLE_GATTS_EVT_HVN_TX_COMPLETE:
on_hvx_tx_complete(p_cus, p_ble_evt);
uint32_t ble_cus_init(ble_cus_t * p_cus, ble_cus_init_t const * p_cus_init)
ble_uuid_t ble_uuid;
ble_uuid128_t cus_base_uuid = {CUS_BASE_UUID};
ble_add_char_params_t add_char_params;
VERIFY_PARAM_NOT_NULL(p_cus);
VERIFY_PARAM_NOT_NULL(p_cus_init);
// Initialize the service structure.
p_cus->data_handler = p_cus_init->data_handler;
/**@snippet [Adding proprietary Service to the SoftDevice] */
// Add a custom base UUID.
err_code = sd_ble_uuid_vs_add(&cus_base_uuid, &p_cus->uuid_type);
VERIFY_SUCCESS(err_code);
ble_uuid.type = p_cus->uuid_type;
ble_uuid.uuid = BLE_UUID_CUS_SERVICE;
// Add the service.
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
&ble_uuid,
&p_cus->service_handle);
// Add the RX Characteristic.
memset(&add_char_params, 0, sizeof(add_char_params));
add_char_params.uuid = BLE_UUID_CUS_RX_CHARACTERISTIC;
add_char_params.uuid_type = p_cus->uuid_type;
add_char_params.max_len = BLE_CUS_MAX_RX_CHAR_LEN;
add_char_params.init_len = sizeof(uint8_t);
add_char_params.is_var_len = true;
add_char_params.char_props.write = 1;
add_char_params.char_props.read = 1;
add_char_params.read_access = SEC_OPEN;
add_char_params.write_access = SEC_OPEN;
err_code = characteristic_add(p_cus->service_handle, &add_char_params, &p_cus->rx_handles);
return err_code;
// Add the TX Characteristic.
/**@snippet [Adding proprietary characteristic to the SoftDevice] */
add_char_params.uuid = BLE_UUID_CUS_TX_CHARACTERISTIC;
add_char_params.max_len = BLE_CUS_MAX_TX_CHAR_LEN;
add_char_params.char_props.notify = 1;
add_char_params.cccd_write_access = SEC_OPEN;
return characteristic_add(p_cus->service_handle, &add_char_params, &p_cus->tx_handles);
uint32_t ble_cus_data_send(ble_cus_t * p_cus,
uint8_t * p_data,
uint16_t * p_length,
uint16_t conn_handle)
ble_gatts_hvx_params_t hvx_params;
err_code = blcm_link_ctx_get(p_cus->p_link_ctx_storage, conn_handle, (void *) &p_client);
if ((conn_handle == BLE_CONN_HANDLE_INVALID) || (p_client == NULL))
return NRF_ERROR_NOT_FOUND;
if (!p_client->is_notification_enabled)
if (*p_length > BLE_CUS_MAX_DATA_LEN)
return NRF_ERROR_INVALID_PARAM;
memset(&hvx_params, 0, sizeof(hvx_params));
hvx_params.handle = p_cus->tx_handles.value_handle;
hvx_params.p_data = p_data;
hvx_params.p_len = p_length;
hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
return sd_ble_gatts_hvx(conn_handle, &hvx_params);
please help me out this.
thank you.
