bsdlib recoverable error: 3
This error always stop the "mqtt_simple" application.
I have tried modem versions 1.0.1 and 1.1.0, SDK versions v1.0.0 and v1.1.0 and added this code to system_nrf9160.c - but nothing seem to fix this bug.
I am running towards a local mqtt server that I have had in operation for years.
    SystemCoreClockUpdate();
	#if defined(NRF_TRUSTZONE_NONSECURE)
        *(volatile uint32_t *)0x40005C04 = 0x02ul;
Typically, the code runs for a while - completing fine a few transactions, and then suddenly error 3 stops it.
The topic the application subscribes to is updated every 5 minutes.
Could it be related to the PSM mode failure with iBasis SIM in Telenor network?
Regards Per
Terminal output below:
***** Booting Zephyr OS v1.14.99-ncs2 *****
The MQTT simple sample started
LTE Link Connecting ...
LTE Link Connected!
IPv4 Address found 84.52.247.193
[mqtt_evt_handler:166] MQTT client connected!
Subscribing to: r35/temperaturer/ute/UteTemp len 28
[mqtt_evt_handler:216] SUBACK packet id: 1234
[mqtt_evt_handler:181] MQTT PUBLISH result=0 len=3
Received: 0.7
Publishing: 0.7
to topic: r35/iotpubPer/topic len: 19
[mqtt_evt_handler:206] PUBACK packet id: 38950
Received: 1.4
Publishing: 1.4
[mqtt_evt_handler:206] PUBACK packet id: 54806
Received: 0.8
Publishing: 0.8
[mqtt_evt_handler:206] PUBACK packet id: 4317
Received: 0.7
Publishing: 0.7
[mqtt_evt_handler:206] PUBACK packet id: 42946
