Peer Manager + Multirole NUS cannot get past PM_EVT_CONN_SEC_PARAMS_REQ
Quick Summary:
- Devices used: nRF52832, nRF52840, Android phone
- SDK used: v16.0.0
- Example based off: ble_app_multirole_lesc
- Primary problem: Central app code does not successfully pair with Peripheral app code
Hi all, the problem in the title is just my guess of what's gone wrong with my application, so I am sorry if it is incorrect.
I have been trying to setup an application using Peer Manager + NUS(_C) based on the `ble_app_multirole_lesc` example from the nRF5 SDK v16.0.0. I have replaced the HRS references with NUS and I'm pretty sure that part is working. I also disengaged the LESC part of the code for simplifying the initial proof of concept and have set the security parameters to match the "Pairing, no bonding" configuration as detailed in the SDK documentation.
Testing my application with both an nRF52832 eval board and another board with the nRF52840, the application is not working quite as expected. I have attached my main.c file for examination. Note that I am using preprocessor conditionals to maintain one code base for targeting my three target devices: central only, peripheral only, and multirole. It is a bit messy for the moment, so let me know if anything is confusing.
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief Application main file for the BLE multirole LE Secure Connections (LESC) example.
 * @detail This application demonstrates bonding with LE Secure Connections both as a peripheral and as a central.
 * LED layout:
 * LED 1: Central side is scanning.       LED 2: Central side is connected to a peripheral.
 * LED 3: Peripheral side is advertising. LED 4: Peripheral side is connected to a central.
 * @note: This application requires the use of an external ECC library for public key and shared secret calculation.
 *        Refer to the application's documentation for more details.
#include "sdk_config.h"
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "app_timer.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "app_util.h"
#include "ble_advdata.h"
#include "ble_nus_c.h"
#include "ble_nus.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_conn_state.h"
#include "fds.h"
#include "nrf_crypto.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define TARGET_MULTI_ROLE               0
#define TARGET_PERIPH_ROLE              1
#define TARGET_CENTRAL_ROLE             2
#define TARGET_ROLE                     TARGET_MULTI_ROLE
#if TARGET_ROLE == TARGET_MULTI_ROLE
#define GAP_NAME                        "MULT"
#elif TARGET_ROLE == TARGET_PERIPH_ROLE
#define GAP_NAME                        "PERI"
#elif TARGET_ROLE == TARGET_CENTRAL_ROLE
#define GAP_NAME                        "CENT"
#define LESC_DEBUG_MODE                 0                                               /**< Set to 1 to use the LESC debug keys. The debug mode allows you to use a sniffer to inspect traffic. */
#define LESC_MITM_NC                    0                                               /**< Use MITM (Numeric Comparison). */
/** @brief The maximum number of peripheral and central links combined. */
#define NRF_BLE_LINK_COUNT              (NRF_SDH_BLE_PERIPHERAL_LINK_COUNT + NRF_SDH_BLE_CENTRAL_LINK_COUNT)
#define APP_BLE_CONN_CFG_TAG            1                                               /**< Tag that identifies the SoftDevice BLE configuration. */
#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1
#define PERIPHERAL_ADVERTISING_LED      BSP_BOARD_LED_2
#define PERIPHERAL_CONNECTED_LED        BSP_BOARD_LED_3
#define SCAN_DURATION                   0x0000                                          /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
#define APP_ADV_DURATION                18000                                           /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define SEC_PARAMS_BOND                 1                                               /**< Perform bonding. */
#if LESC_MITM_NC
#define SEC_PARAMS_MITM                 1                                               /**< Man In The Middle protection required. */
#define SEC_PARAMS_IO_CAPABILITIES      BLE_GAP_IO_CAPS_DISPLAY_YESNO                   /**< Display Yes/No to force Numeric Comparison. */
#else
#define SEC_PARAMS_MITM                 0                                               /**< Man In The Middle protection required. */
#define SEC_PARAMS_IO_CAPABILITIES      BLE_GAP_IO_CAPS_NONE                            /**< No I/O caps. */
#define SEC_PARAMS_LESC                 0                                               /**< LE Secure Connections pairing required. */
#define SEC_PARAMS_KEYPRESS             0                                               /**< Keypress notifications not required. */
#define SEC_PARAMS_OOB                  0                                               /**< Out Of Band data not available. */
#define SEC_PARAMS_MIN_KEY_SIZE         7                                               /**< Minimum encryption key size in octets. */
#define SEC_PARAMS_MAX_KEY_SIZE         16                                              /**< Maximum encryption key size in octets. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                           /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                          /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                               /**< Number of attempts before giving up the connection parameter negotiation. */
#define UART_TX_BUF_SIZE                256
#define UART_RX_BUF_SIZE                256
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA          0                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
/**@brief   Priority of the application BLE event handler.
 * @note    There is no need to modify this value.
#define APP_BLE_OBSERVER_PRIO           3
typedef struct
    bool           is_connected;
    ble_gap_addr_t address;
} conn_peer_t;
NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                            /**< BLE GATT Queue instance. */
               NRF_SDH_BLE_CENTRAL_LINK_COUNT,
               NRF_BLE_GQ_QUEUE_SIZE);
/* Central role GATT Client */
//BLE_NUS_C_ARRAY_DEF(m_ble_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);
#if TARGET_ROLE != TARGET_PERIPH_ROLE
BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
#if TARGET_ROLE != TARGET_CENTRAL_ROLE
#if TARGET_ROLE == TARGET_PERIPH_ROLE
BLE_NUS_DEF(m_nus, 1);
#else
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_PERIPHERAL_LINK_COUNT);
NRF_BLE_GATT_DEF(m_gatt);                                                   /**< GATT module instance. */
NRF_BLE_QWRS_DEF(m_qwr, NRF_SDH_BLE_TOTAL_LINK_COUNT);                      /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                         /**< Advertising module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                            /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                                   /**< Scanning Module instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static uint16_t           m_conn_handle_nus_c                = BLE_CONN_HANDLE_INVALID;  /**< Connection handle for the NUS central application. */
static conn_peer_t        m_connected_peers[NRF_BLE_LINK_COUNT];                         /**< Array of connected peers. */
static char * roles_str[] =
    "INVALID_ROLE",
    "PERIPHERAL",
    "CENTRAL",
/**@brief Names that the central application scans for, and that are advertised by the peripherals.
 *  If these are set to empty strings, the UUIDs defined below are used.
static char m_target_periph_name[4] = "PERI";
/**@brief UUIDs that the central application scans for if the name above is set to an empty string,
 * and that are to be advertised by the peripherals.
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE,         BLE_UUID_TYPE_VENDOR_BEGIN}};
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is an example only and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling errors from the Connection Parameters module.
 * @param[in] nrf_error  Error code that contains information about what went wrong.
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the Nordic UART Service Client errors.
static void nus_error_handler(uint32_t nrf_error)
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        NRF_LOG_DEBUG("Receive the BLE UART data");
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                        err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                        if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                                NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        NRF_LOG_HEXDUMP_INFO(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
        ble_nus_data_send(&m_nus, (const uint8_t *)"GOT", (const uint16_t *)3,p_evt->conn_handle);
    else if (p_evt->type == BLE_NUS_EVT_COMM_STARTED)
        NRF_LOG_DEBUG("NUS : BLE_NUS_EVT_COMM_STARTED");
        ble_nus_data_send(&m_nus,(const uint8_t *)"HI",2,p_evt->conn_handle);
    else if (p_evt->type == BLE_NUS_EVT_COMM_STOPPED)
        NRF_LOG_DEBUG("NUS : BLE_NUS_EVT_COMM_STOPPED");
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
        } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    uint8_t final_target_name[4];
    memcpy((uint8_t *)final_target_name, (const uint8_t *)"PERI", 4);
    #else
    memcpy((uint8_t *)final_target_name, (const uint8_t *)"CENT", 4);
    if (strlen(m_target_periph_name) != 0)
        err_code = nrf_ble_scan_filter_set(&m_scan,
                                           SCAN_NAME_FILTER,
                                           final_target_name);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER,
                                           false);
/**@brief Function for initializing the scanning.
static void scan_start(void)
    err_code = nrf_ble_scan_start(&m_scan);
    NRF_LOG_INFO("Scanning for %s", nrf_log_push(m_target_periph_name));
/**@brief Function for initializing the advertising and the scanning.
static void adv_scan_start(void)
    scan_start();
    // Turn on the LED to signal scanning.
    bsp_board_led_on(CENTRAL_SCANNING_LED);
    // Start advertising.
    err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    NRF_LOG_INFO("Advertising as %s", nrf_log_push((const uint8_t *)GAP_NAME));
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            adv_scan_start();
/**@brief Function for changing filter settings after establishing the connection.
static void filter_settings_change(void)
    err_code = nrf_ble_scan_all_filter_remove(&m_scan);
                                           SCAN_NAME_FILTER,
                                           m_target_periph_name);
/**@brief Function for checking whether a link already exists with a newly connected peer.
 * @details This function checks whether the newly connected device is already connected.
 * @param[in]   p_connected_evt Bluetooth connected event.
 * @return                      True if the peer's address is found in the list of connected peers,
 *                              false otherwise.
static bool is_already_connected(ble_gap_addr_t const * p_connected_adr)
    for (uint32_t i = 0; i < NRF_BLE_LINK_COUNT; i++)
        if (m_connected_peers[i].is_connected)
            if (m_connected_peers[i].address.addr_type == p_connected_adr->addr_type)
                if (memcmp(m_connected_peers[i].address.addr,
                           p_connected_adr->addr,
                           sizeof(m_connected_peers[i].address.addr)) == 0)
                    return true;
    return false;
/**@brief Function for assigning new connection handle to the available instance of QWR module.
 * @param[in] conn_handle New connection handle.
static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
        if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID)
            ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], conn_handle);
/**@brief Function for handling BLE Stack events that are common to both the central and peripheral roles.
 * @param[in] conn_handle Connection Handle.
 * @param[in] p_ble_evt  Bluetooth stack event.
static void on_ble_evt(uint16_t conn_handle, ble_evt_t const * p_ble_evt)
    char        passkey[BLE_GAP_PASSKEY_LEN + 1];
    uint16_t    role = ble_conn_state_role(conn_handle);
    pm_handler_secure_on_connection(p_ble_evt);
        case BLE_GAP_EVT_CONNECTED:
            m_connected_peers[conn_handle].is_connected = true;
            m_connected_peers[conn_handle].address = p_ble_evt->evt.gap_evt.params.connected.peer_addr;
            multi_qwr_conn_handle_assign(conn_handle);
            NRF_LOG_INFO("BLE_GAP_EVT_CONNECTED");
            memset(&m_connected_peers[conn_handle], 0x00, sizeof(m_connected_peers[0]));
            NRF_LOG_INFO("%s: BLE_GAP_EVT_SEC_PARAMS_REQUEST", nrf_log_push(roles_str[role]));
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
            NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_KEY_REQUEST", nrf_log_push(roles_str[role]));
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            NRF_LOG_INFO("%s: BLE_GAP_EVT_LESC_DHKEY_REQUEST", nrf_log_push(roles_str[role]));
         case BLE_GAP_EVT_AUTH_STATUS:
             NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          nrf_log_push(roles_str[role]),
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
            ret_code_t err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys);
        } break;
            // No implementation needed.
            //NRF_LOG_INFO("EVT ID: %i", p_ble_evt->header.evt_id);
/**@brief Function for handling BLE Stack events that are related to central application.
 * @details This function keeps the connection handles of central application up-to-date. It
 * parses scanning reports, initiates a connection attempt to peripherals when a target UUID
 * is found, and manages connection parameter update requests. Additionally, it updates the status
 * of LEDs used to report the central application's activity.
 * @note        Since this function updates connection handles, @ref BLE_GAP_EVT_DISCONNECTED events
 *              must be dispatched to the target application before invoking this function.
static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral is connected (HR or RSC), initiate DB
        //  discovery, update LEDs status, and resume scanning, if necessary.
            NRF_LOG_INFO("CENTRAL: Connected, handle: %d.", p_gap_evt->conn_handle);
            // If no Nordic UART service is currently connected, try to find them on this peripheral.
            if (m_conn_handle_nus_c == BLE_CONN_HANDLE_INVALID)
                NRF_LOG_INFO("CENTRAL: Searching for NUS on conn_handle 0x%x", p_gap_evt->conn_handle);
                err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
            // Update status of LEDs.
            bsp_board_led_off(CENTRAL_SCANNING_LED);
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer that disconnected, update
        // the status of LEDs, and start scanning again.
            NRF_LOG_INFO("CENTRAL: Disconnected, handle: %d, reason: 0x%x",
                         p_gap_evt->conn_handle,
                       p_gap_evt->params.disconnected.reason);
            // Update the status of LEDs.
            bsp_board_led_off(CENTRAL_CONNECTED_LED);
            // TODO: reset scan filter here
            if (p_gap_evt->conn_handle == m_conn_handle_nus_c)
                                                   SCAN_NAME_FILTER,
            scan_start();
        } break; // BLE_GAP_EVT_DISCONNECTED
        case BLE_GAP_EVT_TIMEOUT:
            // Timeout for scanning is not specified, so only connection attemps can time out.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("CENTRAL: Connection Request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            NRF_LOG_DEBUG("CENTRAL: GATT Client Timeout.");
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_DEBUG("CENTRAL: GATT Server Timeout.");
/**@brief Function for handling BLE Stack events that involves peripheral applications. Manages the
 * LEDs used to report the status of the peripheral applications.
static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
            NRF_LOG_INFO("PERIPHERAL: Connected, handle %d.", p_ble_evt->evt.gap_evt.conn_handle);
            //bsp_board_led_off(PERIPHERAL_ADVERTISING_LED);
            //bsp_board_led_on(PERIPHERAL_CONNECTED_LED);
            char conn_msg[16] = "Hey it's periph";
            ble_nus_data_send(&m_nus,(const uint8_t *)conn_msg,(const uint8_t *)16, p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("PERIPHERAL: Disconnected, handle %d, reason 0x%x.",
                         p_ble_evt->evt.gap_evt.params.disconnected.reason);
            NRF_LOG_DEBUG("PERIPHERAL: GATT Client Timeout.");
            NRF_LOG_DEBUG("PERIPHERAL: GATT Server Timeout.");
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            bsp_board_led_on(PERIPHERAL_ADVERTISING_LED);
            bsp_board_led_off(PERIPHERAL_CONNECTED_LED);
        case BLE_ADV_EVT_IDLE:
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        } break;
    uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    if (    (p_ble_evt->header.evt_id == BLE_GAP_EVT_CONNECTED)
        &&  (is_already_connected(&p_ble_evt->evt.gap_evt.params.connected.peer_addr)))
        NRF_LOG_INFO("%s: Already connected to this device as %s (handle: %d), disconnecting.",
                     (role == BLE_GAP_ROLE_PERIPH) ? "PERIPHERAL" : "CENTRAL",
                     (role == BLE_GAP_ROLE_PERIPH) ? "CENTRAL"    : "PERIPHERAL",
                     conn_handle);
        (void)sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        // Do not process the event further.
        return;
    on_ble_evt(conn_handle, p_ble_evt);
    if (role == BLE_GAP_ROLE_PERIPH)
        on_ble_peripheral_evt(p_ble_evt);
    else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
        on_ble_central_evt(p_ble_evt);
 * @details Initializes the SoftDevice and the BLE event interrupts.
     // Configure the BLE stack by using the default settings.
    uint32_t ram_start = 0;
    ble_cfg_t ble_cfg;
    // Configure the GATTS attribute table.
    memset(&ble_cfg, 0x00, sizeof(ble_cfg));
    ble_cfg.gap_cfg.role_count_cfg.periph_role_count  = NRF_SDH_BLE_PERIPHERAL_LINK_COUNT;
    ble_cfg.gap_cfg.role_count_cfg.central_role_count = NRF_SDH_BLE_CENTRAL_LINK_COUNT;
    err_code = sd_ble_cfg_set(BLE_GAP_CFG_ROLE_COUNT, &ble_cfg, &ram_start);
    if (err_code != NRF_SUCCESS)
    NRF_LOG_ERROR("sd_ble_cfg_set() returned %s when attempting to set BLE_GAP_CFG_ROLE_COUNT.",
                  nrf_strerror_get(err_code));
    // Enable BLE stack.
/**@brief Function for initializing the Peer Manager. */
static void peer_manager_init(void)
    ble_gap_sec_params_t sec_params;
    err_code = pm_init();
    memset(&sec_params, 0, sizeof(ble_gap_sec_params_t));
    sec_params.bond           = false;
    sec_params.mitm           = false;
    sec_params.lesc           = 0;
    sec_params.keypress       = 0;
    sec_params.io_caps        = BLE_GAP_IO_CAPS_NONE;
    sec_params.oob            = false;
    sec_params.min_key_size   = 7;
    sec_params.max_key_size   = 16;
    sec_params.kdist_own.enc  = 0;
    sec_params.kdist_own.id   = 0;
    sec_params.kdist_peer.enc = 0;
    sec_params.kdist_peer.id  = 0;
    err_code = pm_sec_params_set(&sec_params);
/** @brief Delete all data stored for all peers. */
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_KEY_0:
      case BSP_EVENT_KEY_1:
/**@brief Function for initializing buttons and LEDs.
 * @param[out] p_erase_bonds  True if the clear bonding button is pressed to
 *                            wake the application up. False otherwise.
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for initializing the GAP.
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device, including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)GAP_NAME,
                                          strlen(GAP_NAME));
    gap_conn_params = m_scan.conn_params;
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @details A pointer to this function is passed to each service that may need to inform the
/**@brief Function for initializing the Queued Write instances.
static void qwr_init(void)
    nrf_ble_qwr_init_t qwr_init_obj = {0};
    qwr_init_obj.error_handler = nrf_qwr_error_handler;
        err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init_obj);
/**@brief Function for initializing the Connection Parameters module. */
    cp_init.start_on_notify_cccd_handle    = BLE_GATT_HANDLE_INVALID; // Start upon connection.
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;  // Ignore events.
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    return;
/**@brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
    ble_db_discovery_init_t db_init;
    memset(&db_init, 0, sizeof(db_init));
    db_init.evt_handler =  db_disc_handler;
    db_init.p_gatt_queue = &m_ble_gatt_queue;
    ret_code_t err_code = ble_db_discovery_init(&db_init);
/**@brief Function for initializing the advertising functionality. */
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_fast_interval = ADV_INTERVAL;
    init.config.ble_adv_fast_timeout  = 0;
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
 * @details This function takes a list of characters of length data_len and prints the characters out on UART.
 *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_INFO("Receiving data.");
    NRF_LOG_HEXDUMP_INFO(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
    if (ECHOBACK_BLE_UART_DATA)
        // Send data back to the peripheral.
        do
            ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= (m_ble_nus_max_data_len)))
                do
                    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            // Initiate bonding
            //err_code = pm_conn_secure(p_ble_nus_evt->conn_handle, false);
            //APP_ERROR_CHECK(err_code);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler   = ble_nus_c_evt_handler;
    init.error_handler = nus_error_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
static void nus_init(void)
    ble_nus_init_t nus_init;
    // Initialize NUS.
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the UART. */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
 * @details Handles any pending log or key operations, or both, then sleeps until the next event occurs.
    //err_code = nrf_ble_lesc_request_handler();
        nrf_pwr_mgmt_run();
    bool erase_bonds;
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    gap_params_init();
    gatt_init();
    conn_params_init();
    db_discovery_init();
    qwr_init();
    nus_c_init();
    nus_init();
    peer_manager_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("LE Secure Connections example started.");
    if (erase_bonds == true)
        delete_bonds();
        // Scanning and advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED.
        adv_scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
My results:
Connecting to both cases of peripheral roles (peripheral only and multirole's peripheral) from my Android phone, I see that the peer manager connection procedure succeeds with a log like this:
<00> info> app: LE Secure Connections example started.
00>
<00> info> app: Advertising
00>
<00> debug> peer_manager_handler: Connected, securing connection. conn_handle: 1
00>
<00> debug> peer_manager_handler: Event PM_EVT_CONN_SEC_PARAMS_REQ
00>
<00> debug> peer_manager_handler: Security parameter request
00>
<00> info> app: BLE_GAP_EVT_CONNECTED
00>
<00> info> app: PERIPHERAL: Connected, handle 1.
00>
<00> debug> peer_manager_handler: Event PM_EVT_CONN_SEC_START
00>
<00> debug> peer_manager_handler: Connection security procedure started: role: Peripheral, conn_handle: 1, procedure: Bonding
00>
00>
00>
<00> info> app: PERIPHERAL: BLE_GAP_EVT_SEC_PARAMS_REQUEST
00>
<00> debug> nrf_ble_gatt: Peer on connection 0x1 requested a data length of 27 bytes.
00>
<00> debug> nrf_ble_gatt: Updating data length to 27 on connection 0x1.
00>
<00> debug> nrf_ble_gatt: Data length updated to 27 on connection 0x1.
00>
<00> debug> nrf_ble_gatt: max_rx_octets: 27
00>
<00> debug> nrf_ble_gatt: max_tx_octets: 27
00>
<00> debug> nrf_ble_gatt: max_rx_time: 328
00>
<00> debug> nrf_ble_gatt: max_tx_time: 2120
00>
<00> debug> peer_manager_handler: Event PM_EVT_CONN_SEC_SUCCEEDED
00>
<00> info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 1, procedure: Pairing
00>
<00> info> app: PERIPHERAL: BLE_GAP_EVT_AUTH_STATUS: status=0x0 bond=0x0 lv4: 0 kdist_own:0x0 kdist_peer:0x0
00>
<00> info> app: PERIPHERAL: Disconnected, handle 1, reason 0x13.
00>
So this leads me to believe that the peer manager configuration is correct. However, when I try to do a test case with the nRF52832 eval board as a peripheral and the nRF52840 board as the multirole/central, this is the RTT Viewer output of the peripheral device:
<00> info> app_timer: RTC: initialized.
00>
00>
00>
00>
00>
00>
00>
00>
<00> info> app: PERIPHERAL: BLE_GAP_EVT_AUTH_STATUS: status=0x1 bond=0x0 lv4: 0 kdist_own:0x0 kdist_peer:0x0
00>
and the nRF52840 multirole device acting as a central device:
00>
<00> debug> ble_scan: Adding filter on PERI name
00>
00>
<00> debug> ble_scan: Scanning
00>
<00> info> app: Scanning
00>
00>
<00> debug> ble_scan: Connecting
00>
<00> debug> ble_scan: Connection status: 0
00>
00>
<00> info> app: CENTRAL: Connected, handle: 0.
00>
<00> info> app: CENTRAL: Searching for NUS on conn_handle 0x0
00>
<00> debug> nrf_ble_gq: Registering connection handle: 0x0000
00>
<00> debug> ble_db_disc: Starting discovery of service with UUID 0x1 on connection handle 0x0.
00>
<00> debug> nrf_ble_gq: Adding item to the request queue
00>
<00> debug> nrf_ble_gq: GATTC Primary Services Discovery Request
00>
<00> debug> nrf_ble_gq: SD GATT procedure (2) succeeded on connection handle: 0.
00>
00>
00>
<00> debug> peer_manager_handler: Event PM_EVT_SLAVE_SECURITY_REQ
00>
<00> debug> peer_manager_handler: Security Request received from peer.
00>
00>
00>
<00> debug> ble_db_disc: Found service UUID 0x1.
00>
00>
<00> debug> nrf_ble_gq: GATTC Characteristic Discovery Request
00>
<00> debug> nrf_ble_gq: SD GATT procedure (3) succeeded on connection handle: 0.
00>
<00> debug> nrf_ble_gq: Processing the request queue...
00>
00>
00>
00>
00>
00>
00>
00>
00>
00>
<00> debug> nrf_ble_gq: GATTC Characteristic Descriptor Request
00>
<00> debug> nrf_ble_gq: SD GATT procedure (4) succeeded on connection handle: 0.
00>
00>
00>
00>
<00> debug> ble_db_disc: Discovery of service with UUID 0x1 completed with success on connection handle 0x0.
00>
<00> info> app: Discovery complete.
00>
00>
<00> debug> nrf_ble_gq: GATTC Write Request
00>
<00> debug> nrf_ble_gq: SD GATT procedure (1) succeeded on connection handle: 0.
00>
<00> info> app: Connected to device with Nordic UART Service.
00>
00>
00>
00>
00>
00>
As you can see, the peripheral log output is significantly different compared to when my phone is connecting to it. We do get a BLE_GAP_EVT_CONNECTED event as well as a successful NUS discovery/connection. In addition to that, when the Peripheral device is lost (in my case, turned off), the application errors out with this:
<00> error> peer_manager_sm: Could not perform security procedure. smd_params_reply() or smd_link_secure() returned Unknown error code. conn_handle: 0
00>
<00> debug> peer_manager_handler: Event PM_EVT_ERROR_UNEXPECTED
00>
<00> error> peer_manager_handler: Unexpected fatal error occurred: error: Unknown error code
00>
<00> error> peer_manager_handler: Asserting.
00>
<00> error> app: End of error report
00>
My conclusion is that my Central side code is not performing certain functionality that is needed to complete the pairing. The thing that stands out to me are the abundant PM_EVT_CONN_SEC_PARAMS_REQ events. I am not too familiar with proper peer manager procedure, but looking at the "working" Android Central -> Application Peripheral log, I see that it moves past that event. Specifically, I do not see PM_EVT_CONN_SEC_START, which I am expecting.
Could anyone point me in the right direction of what I am missing, misunderstanding, or configuring wrong?
Thanks
  • I have shown a way you can find examples that support LESC (or not) here:
    https://devzone.nordicsemi.com/f/nordic-q-a/47518/secure-connections-with-no-keyboard-and-no-display/223238#223238
    A good start may be to use:
    \ble_central\ble_app_hrs_c\
    \ble_peripheral\ble_app_hrs\
    Those two will work out of the box, and I suggest to modify those to fit your need before going to other examples.
    To find exactly what fail in your setup an on-air sniffer log would be useful, for instance using Ellisys or Frontline BLE sniffers. Late this week we will also release a new nRF sniffer that likely can be used to debug what is causing it to fail in more specific during bonding/pairing.
    You may find this useful, since it show the lower level interaction with the softdevice during central and peripheral security procedures:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.s132.api.v7.0.1/group___b_l_e___g_a_p___m_s_c.html
    Disconnect reason 0x13 means BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION (see here for an understanding).
  • Hi Kenneth, thanks for your reply.
    I know you suggested to start building off of the HRS examples, and I will now after some further investigation/debugging I did. I read up on the Message Sequence Charts (very helpful) to understand better what was happening and I made changes to my code so that only the Central (and therefore multirole) app starts a secure connection process instead of both the Central and Peripheral app. I did it this way because that is how the Message Sequence Chart for Central pairing is presented. This helped me figure out that the call to sd_ble_gap_authenticate() in security_dispatcher.c is actually returning NRF_ERROR_NO_MEM.
    According to the comment in link_secure_authenticate(), sd_ble_gap_authenticate() returning NRF_ERROR_NO_MEM means that too many other sec procedures are running. The function then propagates the error code as NRF_ERROR_BUSY along the function call stack until security_manager.c::link_secure(), where it arbitrarily (?) changes the error code again, this time to NRF_SUCCESS. Right before doing this, it changes some flags with:
                ble_conn_state_user_flag_set(conn_handle, m_flag_link_secure_null_params, null_params);
                ble_conn_state_user_flag_set(conn_handle, m_flag_link_secure_force_repairing, force_repairing);
    A few questions:
    • How can I fix sd_ble_gap_authenticate() returning NRF_ERROR_NO_MEM? I cannot see any other SoftDevice operations happening at the time of this call that would impede it. I even tried something along the lines of retrying the link secure functionality while the err code is NRF_ERROR_BUSY, and this just lead to an infinite loop; this implies that the SoftDevice is never free or able to do sd_ble_gap_authenticate(). This does not seem right.
    • Why does the Security Manager module decide to ignore the NRF_ERROR_BUSY error and return it as NRF_SUCCESS instead? It makes it so the error is never handled properly from my understanding.
    If my understanding is correct, then it makes sense that the peripheral never gets a BLE_GAP_EVT_SEC_PARAMS_REQUEST, since sd_ble_gap_authenticate() can't succeed. This would of course stall the entire peer manager/connection securing procedure.
  • I believe it should be possible to adjust the number of concurrent security operations by increasing:
    ble_cfg.gap_cfg.role_count_cfg.central_sec_count before calling sd_ble_cfg_set().
    Have you tried that?
  • I got it to work!
    Setting central_sec_count to 1, the application started a crash loop where it complains about insufficient RAM for the SoftDevice. There is also a suggestion to increase the RAM start address by 0x10. Changing the RAM start address was enough to then start getting the entire peer manager secure connection procedure to work.
    I'm not sure why the multirole LESC example does not  set central_sec_count by default (it does set periph_role_count and central_role_count), and I still don't understand why NRF_ERROR_NO_MEM does not get returned as NRF_ERROR_NO_MEM from sd_ble_gap_authenticate(). Maybe the example code should be doing this?
    In any case, thank you very much for your help! I knew I was very close to getting my application working and it was something small. All this debugging has helped me understand peer manager a lot more too. Now maybe I can stop dreaming about peer manager when I am sleeping Stuck out tongue
