pc-ble-driver-py multi peripheral problem
Hi.
I'm testing multi peripheral using pc-ble-driver-py.
I tested one peripheral device using heart_rate_collector.py.
It was ok.
But, when I try connecting two peripheral device in one central device, I got exception: Failed to ble_gap_connect. Error code: 18.
Is it impossible to connect two peripheral?
This is my code.
I just changed CONNECTIONS and device name.
# Copyright (c) 2016 Nordic Semiconductor ASA
# All rights reserved.
# Redistribution and use in source and binary forms, with or without modification,
# are permitted provided that the following conditions are met:
#   1. Redistributions of source code must retain the above copyright notice, this
#   list of conditions and the following disclaimer.
#   2. Redistributions in binary form must reproduce the above copyright notice, this
#   list of conditions and the following disclaimer in the documentation and/or
#   other materials provided with the distribution.
#   3. Neither the name of Nordic Semiconductor ASA nor the names of other
#   contributors to this software may be used to endorse or promote products
#   derived from this software without specific prior written permission.
#   4. This software must only be used in or with a processor manufactured by Nordic
#   Semiconductor ASA, or in or with a processor manufactured by a third party that
#   is used in combination with a processor manufactured by Nordic Semiconductor.
#   5. Any software provided in binary or object form under this license must not be
#   reverse engineered, decompiled, modified and/or disassembled.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
# DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
# ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
# ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
import sys
import time
from queue import Queue
from pc_ble_driver_py.observers import *
TARGET_DEV_NAME = "Nordic_HRM"
CONNECTIONS = 2
CFG_TAG = 1
def init(conn_ic_id):
    # noinspection PyGlobalUndefined
    global config, BLEDriver, BLEAdvData, BLEEvtID, BLEAdapter, BLEEnableParams, BLEGapTimeoutSrc, BLEUUID, BLEConfigCommon, BLEConfig, BLEConfigConnGatt
    from pc_ble_driver_py import config
    config.__conn_ic_id__ = conn_ic_id
    # noinspection PyUnresolvedReferences
    from pc_ble_driver_py.ble_driver import (
        BLEDriver,
        BLEAdvData,
        BLEEvtID,
        BLEEnableParams,
        BLEGapTimeoutSrc,
        BLEUUID,
        BLEConfigCommon,
        BLEConfig,
        BLEConfigConnGatt,
    from pc_ble_driver_py.ble_adapter import BLEAdapter
    global nrf_sd_ble_api_ver
    nrf_sd_ble_api_ver = config.sd_api_ver_get()
class HRCollector(BLEDriverObserver, BLEAdapterObserver):
    def __init__(self, adapter):
        super(HRCollector, self).__init__()
        self.adapter = adapter
        self.conn_q = Queue()
        self.adapter.observer_register(self)
        self.adapter.driver.observer_register(self)
        self.adapter.default_mtu = 250
    def open(self):
        self.adapter.driver.open()
        if config.__conn_ic_id__ == "NRF51":
            self.adapter.driver.ble_enable(
                BLEEnableParams(
                    vs_uuid_count=1,
                    service_changed=0,
                    periph_conn_count=0,
                    central_conn_count=1,
                    central_sec_count=0,
        elif config.__conn_ic_id__ == "NRF52":
            gatt_cfg = BLEConfigConnGatt()
            gatt_cfg.att_mtu = self.adapter.default_mtu
            gatt_cfg.tag = CFG_TAG
            self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
            self.adapter.driver.ble_enable()
    def close(self):
        self.adapter.driver.close()
    def connect_and_discover(self):
        self.adapter.driver.ble_gap_scan_start()
        new_conn = self.conn_q.get(timeout=5)
        self.adapter.service_discovery(new_conn)
        self.adapter.enable_notification(
            new_conn, BLEUUID(BLEUUID.Standard.battery_level)
        self.adapter.enable_notification(new_conn, BLEUUID(BLEUUID.Standard.heart_rate))
        return new_conn
    def on_gap_evt_connected(
        self, ble_driver, conn_handle, peer_addr, role, conn_params
        print("New connection: {}".format(conn_handle))
        self.conn_q.put(conn_handle)
    def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
        print("Disconnected: {} {}".format(conn_handle, reason))
    def on_gap_evt_timeout(self, ble_driver, conn_handle, src):
        if src == BLEGapTimeoutSrc.scan:
            ble_driver.ble_gap_scan_start()
    def on_gap_evt_adv_report(
        self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data
        if BLEAdvData.Types.complete_local_name in adv_data.records:
            dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
        elif BLEAdvData.Types.short_local_name in adv_data.records:
            dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
        else:
            return
        dev_name = "".join(chr(e) for e in dev_name_list)
        address_string = "".join("{0:02X}".format(b) for b in peer_addr.addr)
        print(
            "Received advertisment report, address: 0x{}, device_name: {}".format(
                address_string, dev_name
        if dev_name == TARGET_DEV_NAME or dev_name == 'HEH001 9F:0D' or dev_name == 'HEH001 EE:62':
            self.adapter.connect(peer_addr, tag=CFG_TAG)
    def on_notification(self, ble_adapter, conn_handle, uuid, data):
        if len(data) > 32:
            data = "({}...)".format(data[0:10])
        print("Connection: {}, {} = {}".format(conn_handle, uuid, data))
def main(selected_serial_port):
    print("Serial port used: {}".format(selected_serial_port))
    driver = BLEDriver(
        serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000
    adapter = BLEAdapter(driver)
    collector = HRCollector(adapter)
    collector.open()
    for i in range(CONNECTIONS):
        collector.connect_and_discover()
    time.sleep(10)
    print("Closing")
    collector.close()
def item_choose(item_list):
    for i, it in enumerate(item_list):
        print("\t{} : {}".format(i, it))
    print(" ")
    while True:
        try:
            choice = int(raw_input("Enter your choice: "))
            if (choice >= 0) and (choice < len(item_list)):
                break
        except Exception:
            pass
        print("\tTry again...")
    return choice
if __name__ == "__main__":
    serial_port = None
    if len(sys.argv) < 2:
        print("Please specify connectivity IC identifier (NRF51, NRF52)")
        exit(1)
    init(sys.argv[1])
    if len(sys.argv) == 3:
        serial_port = sys.argv[2]
    else:
        descs = BLEDriver.enum_serial_ports()
        choices = ["{}: {}".format(d.port, d.serial_number) for d in descs]
        choice = item_choose(choices)
        serial_port = descs[choice].port
    main(serial_port)
    quit()
