I am using the following code to implement a millisecond timer read function. In main, while loop, I do nothing but run a 1ms delay and measure the time in mill second before and after and print the difference with uart over serial terminal. The output I get is 1ms but after every 12 odd readings I get 984ms as output and this continues.
Is this due to the uart or is there some issue with the timer implementation. Would appreciate the help. Thanks.
#include <stdio.h>
#include "boards.h"
#include "app_uart.h"
#include "app_error.h"
#include "nrf_delay.h"
/*UART buffer size. */
#define UART_TX_BUF_SIZE 256
#define UART_RX_BUF_SIZE 1
uint32_t time;
#define MY_TIMER NRF_TIMER1
#define MY_TIMER_IRQn TIMER1_IRQn
#define MY_TIMER_IRQHandler TIMER1_IRQHandler
static uint32_t my_timer_seconds;
static void my_timer_start(void)
// Reset the second variable
my_timer_seconds = 0;
// Ensure the timer uses 24-bit bitmode or higher
MY_TIMER->BITMODE = TIMER_BITMODE_BITMODE_24Bit << TIMER_BITMODE_BITMODE_Pos;
// Set the prescaler to 4, for a timer interval of 1 us (16M / 2^4)
MY_TIMER->PRESCALER = 4;
// Set the CC[0] register to hit after 1 second
MY_TIMER->CC[0] = 1000000;
// Make sure the timer clears after reaching CC[0]
MY_TIMER->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Msk;
// Trigger the interrupt when reaching CC[0]
MY_TIMER->INTENSET = TIMER_INTENSET_COMPARE0_Msk;
// Set a low IRQ priority and enable interrupts for the timer module
NVIC_SetPriority(MY_TIMER_IRQn, 3);
NVIC_EnableIRQ(MY_TIMER_IRQn);
// Clear and start the timer
MY_TIMER->TASKS_CLEAR = 1;
MY_TIMER->TASKS_START = 1;
static uint32_t my_timer_get_ms(void)
// Store the current value of the timer in the CC[1] register, by triggering the capture task
MY_TIMER->TASKS_CAPTURE[1] = 1;
// Combine the state of the second variable with the current timer state, and return the result
return (my_timer_seconds * 1000) + (MY_TIMER->CC[1] / 1000);
static uint64_t my_timer_get_us(void)
return (uint64_t)my_timer_seconds * 1000000 + MY_TIMER->CC[1];
// Timer interrupt handler
void MY_TIMER_IRQHandler(void)
if(MY_TIMER->EVENTS_COMPARE[0])
MY_TIMER->EVENTS_COMPARE[0] = 0;
// Increment the second variable
my_timer_seconds++;
* @brief UART events handler.
static void uart_events_handler(app_uart_evt_t * p_event)
switch (p_event->evt_type)
case APP_UART_FIFO_ERROR:
* @brief UART initialization.
static void uart_config(void)
uint32_t err_code;
const app_uart_comm_params_t comm_params =
RX_PIN_NUMBER,
TX_PIN_NUMBER,
RTS_PIN_NUMBER,
CTS_PIN_NUMBER,
APP_UART_FLOW_CONTROL_DISABLED,
false,
UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_events_handler,
APP_IRQ_PRIORITY_LOW,
err_code);
uart_config();
my_timer_start();
uint8_t reg = 0;
ret_code_t err_code;
while(true)
time=my_timer_get_ms();
nrf_delay_ms(1);
printf("%i\n", my_timer_get_ms()-time);
