DFU Bootloader Requires Reintialization of SD after Soft Reset
In the DFU code provided by nordic is explicitly states that.
"Soft reset from application must not reinitialize the SoftDevice."
In my application I do not have a button to force the device into DFU mode (inside the bootloader). I have implemented the jump from my application into the bootloader DFU using using the following code:
	err_code = sd_power_gpregret_clr(0xFF);
	err_code = sd_power_gpregret_set(BOOTLOADER_DFU_START);
	NVIC_SystemReset();
Basically, when a certain bluetooth write event is recieved by my application it executes the above code and sends the device into the bootloader where it starts the DFU service. However, I had to make a change to the bootloader to get it to work.
I had to explicitly reintialize the softdevice after my application performs a soft reset. That is accomplished using the following code.
    // If stack is present then continue initialization of bootloader.
    ble_stack_init(0x01);
    scheduler_init();
Previously the code read
    ble_stack_init(!app_reset);
    scheduler_init();
This confused me because the bootloader has a comment that explicitly says not to do this.
Am I doing something wrong should I not have to reintialize the softdevice? Everything is working i'm just curious why I had to violate the directions of the original bootloader.
