"Time-boxing"/limiting active portion of BLE connection interval?
Assume a BLE connection has been established between a master and slave.  The device in question could be either the master or the slave (if it matters).
I have an application with tight timing requirements that cannot allow the active/transmitting portion (including T_IFS periods) of a BLE connection interval to bleed into other periodic processing and radio usage.  That is, I need to be able to reliably shut off all BLE activity/resource (e.g. RADIO) except for a small "duty cycle" at the beginning of the BLE connection interval.  I guess I am trying to design the application to be more deterministic and round-robin, not so much RTOS/pre-emptive.
As I currently understand, the BLE stack (which is opaque in the case of Nordic SoftDevice and iOS) is required to perform retransmits in the case of lost packets.  As far as I am aware, the BLE spec does not make any requirements on how many retransmit attempts are required within a connection interval.  On the other hand, I am not aware of any adjustable parameters in SoftDevice or smartphone BLE implementations that allow for forcefully ending the connection interval or specifying the maximum number of frames/packets per connection interval from the application level.  Is this possible?  (Here is a similar question: https://devzone.nordicsemi.com/f/nordic-q-a/2541/number-of-ble-packets-per-connection-interval)
I am also aware of the timeslot API, but it's not clear if the timeslot is reliably "given", or if the BLE could take precedence in the case of a large number of re-transmits.  Can the timeslot API provide a guaranteed periodic window (of <100ms) without any BLE processor/radio usage?  If so, does that require the radio to shut off even earlier than the timeslot period to perform necessary "post-processing", or would I have to empirically measure the "on time" of the SoftDevice and make the timeslot duration reasonably accommodating based on that?
I have read that SoftDevice or the smartphone stack have built-in limits on the number of packets/frames that can be sent/received per connection event due to buffer size (e.g. "6" in the case of recent SoftDevice libraries).  But does that limit re-transmits?  In any case, I don't feel that hoping my current version of SoftDevice or the current smartphone OS version limits the used connection interval portion to an acceptable amount is a strong enough guarantee.
Edit: So I went through a SoftDevice spec (S132_SDS_v6.0), and saw the following in section 10.4: "By default, connections are set to have an event length of 3.75 ms".  Therefore, I'm hoping all SoftDevice's have a similar "hard limit" on event length time even in the case of no successful transmits (assuming event length extension disabled)?
I also saw in Table 30 that all SoftDevice BLE connection activity occurs at the same or higher priority than timeslot API events.  Therefore, I must "trust" that the SoftDevice will hand over control after it's event length period (+ post-processing time?).  Section 15.9 says the timeslot API timeslots could be taken over by SoftDevice if necessary, so that is what I'm concerned of given its higher priority.
Also, I'm assuming that to avoid peer clock drift shifting the BLE connection event in time, the device running the application in question should be configured in central/master mode.  If this is not required (i.e. there is a way to still regularly space out timeslot API events after possibly drifting peripheral/slave connection events), that would be good to know.
Thanks
