Is the timer an interrupt process? Is the function called by the timer executed as an interrupt process?
Hello!
I'm trying to handle an interrupt using a timer.
Is it okay to write something like the following?
 * @brief Handler for timer events.
void timer_twi_event_handler(nrf_timer_event_t event_type, void* p_context)
    switch (event_type)
        case NRF_TIMER_EVENT_COMPARE1:
            flags = true;
            time++;
            //data_handler();
            //Do nothing.
//timer init
err_code = nrf_drv_timer_init(&TIMER, &timer_cfg, timer_twi_event_handler);
time_ticks = nrf_drv_timer_us_to_ticks(&TIMER, time_us);
nrf_drv_timer_extended_compare(
     &TIMER, NRF_TIMER_CC_CHANNEL1, time_ticks, NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true);
nrf_drv_timer_enable(&TIMER);
Also, if this is called every 1ms as interrupt processing, will it be interrupt processing if you call the function you want to execute in "timer_twi_event_handler"?
void receive_data(){//receive mpu9250 20byte data -> mpu_buf[]
    ret_code_t ret = nrf_drv_spi_xfer(&spi,&xfer_spi,flags);//Function for starting the SPI data transfer with additional option flags
    if(ret == NRF_SUCCESS)
        uint32_t start_tsk_addr = nrf_drv_spi_start_task_get(&spi);
int j = 0;
uint8_t buf[10000] = {0};
uint8_t buf2[10000] = {0};
void put_in_array(uint8_t array[10000]){
    for(int a = 0; a <20;a++)
        array[j*21+a] = mpu_buf[a];
    array[j*21+20] = time;
/*void data_handler()
    receive_data();
    put_in_array(buf);
bool flag_buf = true;
bool flag_buf2= false;
    switch (event_type)
            flags = true;
            time++;
            receive_data();
            if(flag_buf == true){
              put_in_array(buf);
            }else if(flag_buf2 == true){
              put_in_array(buf2);
            j++;
            //data_handler();
            //Do nothing.
Thank you!
