Using FDS to save a Struct (Structure) and also reading it
I am trying to save and read a structure using FDS, how do I go about it?
I have the structure:
typedef struct
    uint8_t led_blink; //was bool
    uint8_t initial_adv_disable; //was bool
    uint8_t enable_ibeacon_Packet; //was bool
    uint8_t enable_cbeacon1_Health_Packet; //was bool
    uint8_t enable_cbeacon2_Proximity_Packet;  //was bool
    uint8_t enable_ibeacon_SOS_Packet; //was bool
    uint8_t enable_Mems; //was bool
}beacon_packet_struct;
My custom function for saving is:
int fds_write_struct(uint16_t file_id, uint16_t flash_key)
    ret_code_t ret;
    fds_record_t        record;
    fds_record_desc_t   record_desc;
    fds_record_desc_t desc = {0};
    fds_find_token_t  tok  = {0};
	if (flash_key == BEACON_STATE_KEY)
        record.file_id              = FILE_ID;
        record.key                  = BEACON_STATE_KEY;
        record.data.p_data          = &beacon_flags;  //&beacon_flags;
        record.data.length_words    = ( sizeof(beacon_packet_struct) + 3 ) / sizeof(uint32_t);
        ret_code_t rc = fds_record_find(FILE_ID, BEACON_STATE_KEY , &desc, &tok);  //Search for record. Update if found else write a new one
        if (rc == FDS_SUCCESS)
            NRF_LOG_INFO("Similar BEACON STATE Variables Record was found thus it is being updated");
            rc = fds_record_update(&desc, &record);
            APP_ERROR_CHECK(rc);
            ret_code_t ret = fds_record_write(&record_desc, &record);
            APP_ERROR_CHECK(ret);
            NRF_LOG_INFO("First time writing BEACON STATE record");
        return 1;
I call the function using below:
fds_write_struct(FILE_ID,BEACON_STATE_KEY);
But I get error 0x03 at:
Suggestions would be greatly appreciated Slight smile
