FDS after Init show ok,but always waitting for ready
I  want to add FDS basedon  dimming_serve example ,However,after fds_init(); it  not jump to fds_evt_handler but stop wait .
The below is my code:
static void initialize(void)
    __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Dimming Server Demo -----\n");
    ERROR_CHECK(app_timer_init());
    hal_leds_init();
    ble_stack_init();
#if MESH_FEATURE_GATT_ENABLED
    gap_params_init();
    conn_params_init();
    //mesh_init();
    uint32_t status = app_pwm_init(&PWM0, &m_pwm0_config, NULL);
    APP_ERROR_CHECK(status);
    m_pwm0_max = app_pwm_cycle_ticks_get(&PWM0);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "PWM max ticks: %d\n", m_pwm0_max);
    #if 1
    //FDS
    /* Register first to receive an event when initialization is complete. */
    status=fds_register(fds_evt_handler);//(void) fds_register(fds_evt_handler);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Status fds register is : %d\n",status);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing fds...\n");
    status=fds_init();
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Status fds init is : %d\n",status);
    /* Wait for fds to initialize. */
    wait_for_fds_ready();
    #if 0
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Available commands:\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- print all\t\tprint records\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- print config\tprint configuration\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- update\t\tupdate configuration\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- stat\t\tshow statistics\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- write\t\twrite a new record\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- delete\t\tdelete a record\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- delete_all\tdelete all records\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- gc\t\trun garbage collection\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reading flash usage statistics...\n");
    fds_stat_t stat = {0};
    status = fds_stat(&stat);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Found %d valid records.\n", stat.valid_records);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Found %d dirty records (ready to be garbage collected).\n", stat.dirty_records);
    fds_record_desc_t desc = {0};
    fds_find_token_t  tok  = {0};
    status = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &desc, &tok);
    if (status == FDS_SUCCESS)
        /* A config file is in flash. Let's update it. */
        fds_flash_record_t config = {0};
        /* Open the record and read its contents. */
        status = fds_record_open(&desc, &config);
        /* Copy the configuration from flash into m_dummy_cfg. */
        memcpy(&m_dummy_cfg, config.p_data, sizeof(configuration_t));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Config file found, updating boot count to %d\n", m_dummy_cfg.boot_count);
        /* Update boot count. */
        m_dummy_cfg.boot_count++;
        /* Close the record when done reading. */
        status = fds_record_close(&desc);
        /* Write the updated record to flash. */
        status = fds_record_update(&desc, &m_dummy_record);
        /* System config not found; write a new one. */
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Writing config file...\n");
        status = fds_record_write(&desc, &m_dummy_record);
And The Bellow is Log:
<t: 0>, main.c, 558, ----- BLE Mesh Dimming Server Demo -----
<t: 17925>, ble_softdevice_support.c, 124, RAM Start is 0x20002DA0
<t: 17945>, main.c, 575, PWM max ticks: 1600
<t: 17948>, main.c, 581, Status fds register is : 0
<t: 17950>, main.c, 583, Initializing fds...
How To solve this ? TKS in anvance.
Best Regards
Panda
  • Hi Hung,
        I do as you said to include INITIALIZE_USER_SECTIONS , But it does not work ,the result just like before .Could you return back full project work well your side? Thanks in advance.
    Best Regards,
    Panda
  • Hi Panda,
    Please find the .zip here. Make sure you trigger a reset after programming.
    dimming_server_DFU.zip
  • Hi Hung,
      I tried just now .It sames that FDS write not ready..the log is bellow.
      RTT View:
     0> <t:          0>, main.c,  597, ----- BLE Mesh Dimming Server Demo -----
     0> <t:      12957>, ble_softdevice_support.c,  133, RAM Start is 0x20002DA0
     0> <t:      13494>, main.c,  570, Initializing and adding models
     0> <t:      18360>, main.c,  620, Status fds register is : 0
     0> <t:      18363>, main.c,  622, Initializing fds...
     0> <t:      18384>, main.c,  625, Status fds init is : 0
     0> <t:       8406>, ble_softdevice_support.c,  133, RAM Start is 0x20002DA0
     0> <t:       8949>, main.c,  570, Initializing and adding models
     0> <t:      13812>, main.c,  620, Status fds register is : 0
     0> <t:      13815>, main.c,  622, Initializing fds...
     0> <t:      13831>, main.c,  625, Status fds init is : 0
     0> <t:       8408>, ble_softdevice_support.c,  133, RAM Start is 0x20002DA0
     0> <t:       8941>, main.c,  570, Initializing and adding models
     0> <t:      13808>, main.c,  620, Status fds register is : 0
     0> <t:      13811>, main.c,  622, Initializing fds...
     0> <t:      13821>, main.c,  625, Status fds init is : 0
     0> <t:       8955>, main.c,  570, Initializing and adding models
     0> <t:      13810>, main.c,  620, Status fds register is : 0
     0> <t:      13812>, main.c,  622, Initializing fds...
     0> <t:      13815>, main.c,  266, Event: FDS_EVT_INIT received (FDS_SUCCESS)
     0> <t:      13818>, main.c,  625, Status fds init is : 0
     0> <t:      13820>, main.c,  642, Reading flash usage statistics...
     0> <t:      13823>, main.c,  649, Found 0 valid records.
     0> <t:      13825>, main.c,  650, Found 0 dirty records (ready to be garbage collected).
     0> <t:      13828>, main.c,  686, Writing config file...
     0> <t:      13833>, main.c,  689, Write Status is : 0
       I try another example using Keil5 IDE,It does work.However ,My project is based on SES ,So I have to solve it.Could you help me to find any other issues maybe without attention? Thank You.
     Best Regards,
    Panda
  • Hi Panda,
    Did you test with the light_switch_dimming_server_DFU_nrf52832_xxAA_s132_6_1_1.emProject project ?
    I suspect there could be an issue that your ses doesn't use the flash_placement.xml for section. Could you try erasing the file and check if it built ?
    I attached the .hex file please try testing this hex. Please make sure to do an erase all (nrfjprog --eraseall) before testing
    light_switch_dimming_server_DFU_nrf52832_xxAA_s132_6.1.1.hex
  • Hi Hung,
      I Used your giving hex file to program with nrfutil tool as follow:
     Then I pressed reset button two times,The Log shows it works ok.
     0> <t:      13096>, main.c,  570, Initializing and adding models
     0> <t:      17869>, main.c,  620, Status fds register is : 0
     0> <t:      17872>, main.c,  622, Initializing fds...
     0> <t:      17893>, main.c,  625, Status fds init is : 0
     0> <t:      17939>, main.c,  266, Event: FDS_EVT_INIT received (FDS_SUCCESS)
     0> <t:       8743>, main.c,  570, Initializing and adding models
     0> <t:      13522>, main.c,  620, Status fds register is : 0
     0> <t:      13525>, main.c,  622, Initializing fds...
     0> <t:      13527>, main.c,  266, Event: FDS_EVT_INIT received (FDS_SUCCESS)
     0> <t:      13530>, main.c,  625, Status fds init is : 0
     0> <t:      13533>, main.c,  642, Reading flash usage statistics...
     0> <t:      13535>, main.c,  649, Found 0 valid records.
     0> <t:      13538>, main.c,  650, Found 0 dirty records (ready to be garbage collected).
     0> <t:      13541>, main.c,  686, Writing config file...
     0> <t:      13546>, main.c,  689, Write Status is : 0
     0> <t:      13611>, main.c,  266, Event: FDS_EVT_WRITE received (FDS_SUCCESS)
     0> <t:      13614>, main.c,  286, Record ID:	0x0001<t:      13616>, main.c,  287, File ID:	0xF010<t:      13618>, main.c,  288, Record key:	0x7010<t:          0>, main.c,  597, ----- BLE Mesh Dimming Server Demo -----
     0> <t:       8734>, main.c,  570, Initializing and adding models
     0> <t:      13506>, main.c,  620, Status fds register is : 0
     0> <t:      13508>, main.c,  622, Initializing fds...
     0> <t:      13511>, main.c,  266, Event: FDS_EVT_INIT received (FDS_SUCCESS)
     0> <t:      13514>, main.c,  625, Status fds init is : 0
     0> <t:      13516>, main.c,  642, Reading flash usage statistics...
     0> <t:      13519>, main.c,  649, Found 1 valid records.
     0> <t:      13521>, main.c,  650, Found 0 dirty records (ready to be garbage collected).
     0> <t:      13525>, main.c,  669, Config file found, updating boot count to 0
     0> <t:      13618>, main.c,  266, Event: FDS_EVT_UPDATE received (FDS_SUCCESS)
       However,when I rebuild the project you return back with above method using rebuild hex and test again ,It does not work right even i change the flash_placement.xml/flash_placement1.xml .
       I check my SEGGER Embedded Studio ,the version is 3.12  .Does it matter?
      If there are anyother advises,please tell me. Thank you.
    Best Regards,
    Panda
