FDS after Init show ok,but always waitting for ready
I  want to add FDS basedon  dimming_serve example ,However,after fds_init(); it  not jump to fds_evt_handler but stop wait .
The below is my code:
static void initialize(void)
    __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Dimming Server Demo -----\n");
    ERROR_CHECK(app_timer_init());
    hal_leds_init();
    ble_stack_init();
#if MESH_FEATURE_GATT_ENABLED
    gap_params_init();
    conn_params_init();
    //mesh_init();
    uint32_t status = app_pwm_init(&PWM0, &m_pwm0_config, NULL);
    APP_ERROR_CHECK(status);
    m_pwm0_max = app_pwm_cycle_ticks_get(&PWM0);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "PWM max ticks: %d\n", m_pwm0_max);
    #if 1
    //FDS
    /* Register first to receive an event when initialization is complete. */
    status=fds_register(fds_evt_handler);//(void) fds_register(fds_evt_handler);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Status fds register is : %d\n",status);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing fds...\n");
    status=fds_init();
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Status fds init is : %d\n",status);
    /* Wait for fds to initialize. */
    wait_for_fds_ready();
    #if 0
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Available commands:\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- print all\t\tprint records\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- print config\tprint configuration\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- update\t\tupdate configuration\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- stat\t\tshow statistics\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- write\t\twrite a new record\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- delete\t\tdelete a record\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- delete_all\tdelete all records\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "- gc\t\trun garbage collection\n");
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reading flash usage statistics...\n");
    fds_stat_t stat = {0};
    status = fds_stat(&stat);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Found %d valid records.\n", stat.valid_records);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Found %d dirty records (ready to be garbage collected).\n", stat.dirty_records);
    fds_record_desc_t desc = {0};
    fds_find_token_t  tok  = {0};
    status = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &desc, &tok);
    if (status == FDS_SUCCESS)
        /* A config file is in flash. Let's update it. */
        fds_flash_record_t config = {0};
        /* Open the record and read its contents. */
        status = fds_record_open(&desc, &config);
        /* Copy the configuration from flash into m_dummy_cfg. */
        memcpy(&m_dummy_cfg, config.p_data, sizeof(configuration_t));
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Config file found, updating boot count to %d\n", m_dummy_cfg.boot_count);
        /* Update boot count. */
        m_dummy_cfg.boot_count++;
        /* Close the record when done reading. */
        status = fds_record_close(&desc);
        /* Write the updated record to flash. */
        status = fds_record_update(&desc, &m_dummy_record);
        /* System config not found; write a new one. */
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Writing config file...\n");
        status = fds_record_write(&desc, &m_dummy_record);
And The Bellow is Log:
<t: 0>, main.c, 558, ----- BLE Mesh Dimming Server Demo -----
<t: 17925>, ble_softdevice_support.c, 124, RAM Start is 0x20002DA0
<t: 17945>, main.c, 575, PWM max ticks: 1600
<t: 17948>, main.c, 581, Status fds register is : 0
<t: 17950>, main.c, 583, Initializing fds...
How To solve this ? TKS in anvance.
Best Regards
Panda
    When adding fds (and fstorage) care should be taken to avoid overlapping the flash area occupied by the mesh flash manager module. We have a guide here about integrating Mesh into nRF5 SDK and vice versa.
    How do you configure the fds module ? and fstorage module ?
    Do you need to use fds or it's possible to use flash manager from mesh instead ?
  • Hi Hung,
       I have read the guide and The bellow is what i did:
          1)set the Heap Size to 8192 bytes in project option
          2)in nrf_mesh_config_app.h file add include and define
          3)for the "optional changes"and "Flash palcement project files"part ,the code has alreadly been existed.
      I have enable FDS_ENABLED 1 in file sdk_config.h
      My purpose is to storage data  which  power on again after user's setting.
     The new Log:
     0> <t:          0>, main.c,  597, ----- BLE Mesh Dimming Server Demo -----
     0> <t:       8648>, ble_softdevice_support.c,  133, RAM Start is 0x20002DA0
     0> <t:       9257>, main.c,  570, Initializing and adding models
     0> <t:      14086>, main.c,  614, PWM max ticks: 1600
     0> <t:      14089>, main.c,  620, Status fds register is : 0
     0> <t:      14091>, main.c,  622, Initializing fds...
     0> <t:      14107>, main.c,  625, Status fds init is : 0
     0> <t:       8656>, ble_softdevice_support.c,  133, RAM Start is 0x20002DA0
     0> <t:       9271>, main.c,  570, Initializing and adding models
     0> <t:      14092>, main.c,  614, PWM max ticks: 1600
     0> <t:      14095>, main.c,  620, Status fds register is : 0
     0> <t:      14097>, main.c,  622, Initializing fds...
     0> <t:       8649>, ble_softdevice_support.c,  133, RAM Start is 0x20002DA0
     0> <t:       9272>, main.c,  570, Initializing and adding models
     0> <t:      14107>, main.c,  614, PWM max ticks: 1600
     0> <t:      14109>, main.c,  620, Status fds register is : 0
     0> <t:      14111>, main.c,  622, Initializing fds...
     0> <t:      14114>, main.c,  266, Event: FDS_EVT_INIT received (FDS_SUCCESS)
     0> <t:      14116>, main.c,  625, Status fds init is : 0
     0> <t:      14119>, main.c,  642, Reading flash usage statistics...
     0> <t:      14121>, main.c,  649, Found 0 valid records.
     0> <t:      14123>, main.c,  650, Found 0 dirty records (ready to be garbage collected).
     0> <t:      14127>, main.c,  686, Writing config file...
     0> <t:      14131>, main.c,  689, Write Status is : 0
     0> <t:       9237>, main.c,  570, Initializing and adding models
     0> <t:      14067>, main.c,  614, PWM max ticks: 1600
     0> <t:      14069>, main.c,  620, Status fds register is : 0
     0> <t:      14071>, main.c,  622, Initializing fds...
     0> <t:      14074>, main.c,  266, Event: FDS_EVT_INIT received (FDS_SUCCESS)
     0> <t:      14077>, main.c,  625, Status fds init is : 0
     0> <t:      14079>, main.c,  642, Reading flash usage statistics...
     0> <t:      14082>, main.c,  649, Found 0 valid records.
     0> <t:      14084>, main.c,  650, Found 1 dirty records (ready to be garbage collected).
     0> <t:      14087>, main.c,  686, Writing config file...
     0> <t:      14092>, main.c,  689, Write Status is : 0
    I have pressed  RESET Button four times. The process stopped after 'fds_record_write' this time.
    Could you give me some advices.Thanks.
    Best Regars,
    Panda
  • Hi Panda,
    Could you provide the full project so I can test here ? I assume you are testing using SDK v3.2 ?
    Which value you used for FDS_PHY_PAGES ?
    Please make sure you erase full flash before testing.
    Which backend for fstorage you used ? NRF_FSTORAGE_SD or NRF_FSTORAGE_NVMC ?
  • Hi Hung,
       I send you main codedimming_server_DFU.rar   ,Just extract it and place path :...\nrf5_SDK_for_Mesh_v3.2.0_src\examples\experimental_dimming .
       nRF SDK:     nRF5_SDK_15.3.0_59ac345
       mseh SDK:  nrf5_SDK_for_Mesh_v3.2.0_src
       I used NRF_FSTORAGE_SD  fstorage (example default) .FDS_PHY_PAGES=3*1024/1024=3 (fds_internal_defs.h and sdk_config.h)
      If anything else is needed,Please tell me .Thank you for you help.
    Best Regards,
    Panda
  • Hi Panda,
    I think we found what's wrong with the code.  You forgot to include INITIALIZE_USER_SECTIONS in the preprocessor definition.
    Without that the section variable will not be initialized with the value defined in the section register.
