Can only write two bytes when length says 7 bytes
I'm trying to write 7 bytes (0x01 02 03 04 05 06 07) to my nrf51 Dongle with my own custom service running based on the Battery Service.
The problem is that I can only access the first two bytes 0x01 and 0x02 in the memory. But the length when I read p_evt_write->len is 7. I can read all the 7 bytes of my characteristic but I cannot write 7 bytes.
Is their maybe a MAX WRITE LENGTH I forgot?
This is my on_write function:
static void on_write(ble_sens_t * p_sens, ble_evt_t * p_ble_evt)
   ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
    if ((p_evt_write->handle == p_sens->config_handle.value_handle) && (p_sens->evt_handler != NULL))
        p_sens->evt_handler(p_sens, *p_evt_write);
This is my write handler: I already tried doing it with pointers and so on with the info from the other questions around this topic.
	 else if (p_evt_write.handle == p_sens->config_handle.value_handle && p_evt_write.len == 7)
			m_config.toggle_settings = p_evt_write.data[0];
		 	m_config.seconds = p_evt_write.data[1];
		 	m_config.minutes = p_evt_write.data[2];
		 	m_config.hours = p_evt_write.data[3];
		 	m_config.day = p_evt_write.data[4];
		 	m_config.month = p_evt_write.data[5];
		 	m_config.year = p_evt_write.data[6];
Thank you!
  • p_evt_write in on_write() is already pointer and you are passing pointer of the pointer to p_sens->evt_handler(). It is difficult to see from second part of the code how p_evt_write defined. If you call p_sens->evt_handler(p_sens, p_evt_write); without *, then inside the handler data can be accessible p_evt_write->data[0] but need to define p_evt_write correctly as well
  • That was indeed the problem thank you very much for helping me! This is how I solved it now:
    The on_write function is like this now:
    	 if(p_evt_write->handle == p_sens->config_handle.value_handle || p_evt_write->handle == p_sens->step_data_handle.value_handle)
    The evt_handler function is like this now:
    static void evt_handler(ble_sens_t * p_sens, ble_gatts_evt_write_t  * p_evt_write)
     if (p_evt_write->handle == p_sens->config_handle.value_handle )
    			m_config.toggle_settings = p_evt_write->data[0];
    		 	m_config.seconds = p_evt_write->data[1];
    		 	m_config.minutes = p_evt_write->data[2];
    		 	m_config.hours = p_evt_write->data[3];
    		 	m_config.day = p_evt_write->data[4];
    		 	m_config.month = p_evt_write->data[5];
    		 	m_config.year = p_evt_write->data[6];
    And the handler typedef is like this now:
    typedef void (*ble_sens_evt_handler_t) (ble_sens_t * p_sens, ble_gatts_evt_write_t * evt_write);
