DFU with OTA
anyone help me.
I am facing the issue during DFU with OTA. the steps are listed which had I done,
here trying to update softdevice.
1. Erase all.
2.flashed softdevice.
3.complied and programmed the bootloader which has included with SDK example(dfu_ble_dual_bank_s110).
4. the target device start to advertise as  "DfuTarg" with LED status.
5. Open nRF connect on my phone and scanner then found the target device and connected successfully.
6. click the DFU button on the nRF connect mobile app. it displays 4 options.
7. I chose distributed back. and try to upload the zip file. app showing "starting DFU" and then disconnected
zip files preparation:
1. got the softdevice from the example folder.
2. using nrfutil.exe, the file has made as "xxx.zip". the zip file consists of xxx.bin file, xxx.dat, manifest file.
3. hut here I did n't use any private key like yyy.pem.
note:-
bootloader example: dfu_ble_dual_bank_s110, version 7.2.0.
SDK version 7.2.0
softdevice: s110, version 7.1.0
target device: custom board, nrf51822 QFAA, 16kb ram, 256kb flash memory.
Keil v5.
please correct where I have made a mistake and guide me on what I have to do exactly.
  • Tried with NRF51822QFAA 16KB 256KB specification:
    I used the above settings and tried to build but I got an error like,
    Error: L6406E: No space in execution regions with.ANY selector matching arm_startup_nrf51.o(STACK).
    Error: L6407E: Sections of aggregate size 0x800 bytes could not fit into.ANY selector(s).
    and I searched in the forum and found one solution for this,
    in that forum, they suggested reducing the stack size from 2048 to 255 in amr_startup_nrf51.s file.
    Now the build was done successfully. I can flash into the target device. started advertising and connected with nRconnect chosen DFU option loaded zip file into the app. then the app started to upload the file to the target device. but failed.
    please guide me if had done any mistake.
     Was this the application or the bootloader project?
     Did you get any error code in the app ? Anything in the log that might identify the issue?
  • That is a boot loader project. Please correct me if I made any mistake in the configuration settings
  • Is there any incompatible with the target device hardware specification?
  • please find the logs file. Here I have tried updating softdevice and got the error.
    nRF Connect, 2019-12-11
    DfuTarg (FC:11:CC:F5:BE:5B)
    V	11:44:59.750	Connecting to FC:11:CC:F5:BE:5B...
    D	11:44:59.751	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	11:44:59.977	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	11:44:59.977	Connected to FC:11:CC:F5:BE:5B
    V	11:45:00.002	Discovering services...
    D	11:45:00.002	gatt.discoverServices()
    D	11:45:00.004	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    I	11:45:00.378	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	11:45:00.592	[Callback] Services discovered with status: 0
    I	11:45:00.592	Services discovered
    V	11:45:00.619	Generic Access (0x1800)
    - Device Name [R W] (0x2A00)
    - Appearance [R] (0x2A01)
    - Peripheral Preferred Connection Parameters [R] (0x2A04)
    Generic Attribute (0x1801)
    Device Firmware Update Service (00001530-1212-efde-1523-785feabcd123)
    - DFU Packet [WNR] (00001532-1212-efde-1523-785feabcd123)
    - DFU Control Point [N W] (00001531-1212-efde-1523-785feabcd123)
       Client Characteristic Configuration (0x2902)
    - DFU Version [R] (00001534-1212-efde-1523-785feabcd123)
    I	11:45:00.652	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 4000ms)
    I	11:45:00.957	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 4000ms)
    V	11:45:14.092	[DFU] DFU service started
    V	11:45:14.092	[DFU] Opening file...
    I	11:45:14.098	[DFU] Firmware file opened successfully
    V	11:45:14.098	[DFU] Connecting to DFU target...
    D	11:45:14.099	[DFU] gatt = device.connectGatt(autoConnect = false)
    I	11:45:14.114	[DFU] Connected to FC:11:CC:F5:BE:5B
    V	11:45:14.114	[DFU] Discovering services...
    D	11:45:14.114	[DFU] gatt.discoverServices()
    I	11:45:14.123	[DFU] Services discovered
    D	11:45:14.147	[DFU] wait(1000)
    V	11:45:15.183	[DFU] Reading DFU version number...
    D	11:45:15.183	[DFU] gatt.readCharacteristic(00001534-1212-efde-1523-785feabcd123)
    I	11:45:15.183	[DFU] Read Response received from 00001534-1212-efde-1523-785feabcd123, value (0x): 05-00
    A	11:45:15.183	[DFU] Version number read: 0.5
    D	11:45:15.183	[DFU] wait(1000)
    V	11:45:16.169	[DFU] Enabling notifications for 00001531-1212-efde-1523-785feabcd123
    D	11:45:16.169	[DFU] gatt.setCharacteristicNotification(00001531-1212-efde-1523-785feabcd123, true)
    D	11:45:16.173	[DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
    I	11:45:16.235	[DFU] Data written to descr.00001531-1212-efde-1523-785feabcd123, value (0x): 01-00
    V	11:45:16.235	[DFU] Notifications enabled for 00001531-1212-efde-1523-785feabcd123
    A	11:45:16.235	[DFU] Notifications enabled
    D	11:45:16.235	[DFU] wait(1000)
    V	11:45:17.214	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
    D	11:45:17.214	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
    I	11:45:17.246	[DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 01-01
    A	11:45:17.247	[DFU] DFU Start sent (Op Code = 1, Upload Mode = 1)
    V	11:45:17.247	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
    D	11:45:17.247	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
    I	11:45:17.251	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): 0C-42-01-00-00-00-00-00-00-00-00-00
    A	11:45:17.253	[DFU] Firmware image size sent (82444b, 0b, 0b)
    I	11:45:18.553	[DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-01-01
    A	11:45:18.553	[DFU] Response received (Op Code = 1 Status = 1)
    A	11:45:18.553	[DFU] Writing Initialize DFU Parameters...
    V	11:45:18.554	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
    D	11:45:18.554	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
    I	11:45:18.581	[DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 02-00
    V	11:45:18.582	[DFU] Writing to characteristic 00001532-1212-efde-1523-785feabcd123
    D	11:45:18.582	[DFU] gatt.writeCharacteristic(00001532-1212-efde-1523-785feabcd123)
    I	11:45:18.586	[DFU] Data written to 00001532-1212-efde-1523-785feabcd123, value (0x): FF-FF-FF-FF-FF-FF-FF-FF-01-00-5A-00-7D-C6
    V	11:45:18.586	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
    D	11:45:18.586	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
    I	11:45:18.657	[DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 02-01
    I	11:45:18.659	[DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-02-01
    A	11:45:18.659	[DFU] Initialize DFU Parameters completed
    A	11:45:18.659	[DFU] Response received (Op Code = 2, Status = 1)
    V	11:45:18.659	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
    D	11:45:18.660	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
    I	11:45:18.701	[DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 08-0A-00
    A	11:45:18.702	[DFU] Packet Receipt Notif Req (Op Code = 8) sent (Value = 10)
    V	11:45:18.702	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
    D	11:45:18.702	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
    I	11:45:18.731	[DFU] Data written to 00001531-1212-efde-1523-785feabcd123, value (0x): 03
    A	11:45:18.732	[DFU] Receive Firmware Image request sent
    A	11:45:18.778	[DFU] Uploading firmware...
    V	11:45:18.778	[DFU] Sending firmware to characteristic 00001532-1212-efde-1523-785feabcd123...
    I	11:45:18.927	[DFU] Notification received from 00001531-1212-efde-1523-785feabcd123, value (0x): 10-03-06
    A	11:45:18.927	[DFU] Response received (Op Code = 3, Status = 6)
    E	11:45:18.929	[DFU] Remote DFU error: OPERATION FAILED
    V	11:45:18.929	[DFU] Writing to characteristic 00001531-1212-efde-1523-785feabcd123
    D	11:45:18.929	[DFU] gatt.writeCharacteristic(00001531-1212-efde-1523-785feabcd123)
    A	11:45:22.968	[DFU] Reset request sent
    V	11:45:22.969	[DFU] Disconnecting...
    D	11:45:22.970	[Callback] Connection state changed with status: 8 and new state: DISCONNECTED (0)
    E	11:45:22.970	Error 8 (0x8): GATT CONN TIMEOUT
    I	11:45:22.970	Disconnected
    D	11:45:23.014	[DFU] gatt.disconnect()
    I	11:45:23.014	[DFU] Disconnected
    D	11:45:23.014	[DFU] gatt.refresh() (hidden)
    D	11:45:23.014	[DFU] gatt.close()
    D	11:45:23.025	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D	11:45:23.025	[DFU] wait(600)
    D	11:45:23.049	[DFU] [Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
    D	11:45:23.635	gatt.close()
    D	11:45:23.640	wait(200)
    V	11:45:23.844	Connecting to FC:11:CC:F5:BE:5B...
    D	11:45:23.845	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
    D	11:45:24.117	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
    I	11:45:24.117	Connected to FC:11:CC:F5:BE:5B
    D	11:45:24.159	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
    V	11:45:24.167	Discovering services...
    D	11:45:24.167	gatt.discoverServices()
    I	11:45:24.508	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
    D	11:45:24.726	[Callback] Services discovered with status: 0
    I	11:45:24.726	Services discovered
    V	11:45:24.754	Generic Access (0x1800)
    I	11:45:24.793	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 4000ms)
    I	11:45:25.078	Connection parameters updated (interval: 15.0ms, latency: 0, timeout: 4000ms)
