DFU with OTA
anyone help me.
I am facing the issue during DFU with OTA. the steps are listed which had I done,
here trying to update softdevice.
1. Erase all.
2.flashed softdevice.
3.complied and programmed the bootloader which has included with SDK example(dfu_ble_dual_bank_s110).
4. the target device start to advertise as  "DfuTarg" with LED status.
5. Open nRF connect on my phone and scanner then found the target device and connected successfully.
6. click the DFU button on the nRF connect mobile app. it displays 4 options.
7. I chose distributed back. and try to upload the zip file. app showing "starting DFU" and then disconnected
zip files preparation:
1. got the softdevice from the example folder.
2. using nrfutil.exe, the file has made as "xxx.zip". the zip file consists of xxx.bin file, xxx.dat, manifest file.
3. hut here I did n't use any private key like yyy.pem.
note:-
bootloader example: dfu_ble_dual_bank_s110, version 7.2.0.
SDK version 7.2.0
softdevice: s110, version 7.1.0
target device: custom board, nrf51822 QFAA, 16kb ram, 256kb flash memory.
Keil v5.
please correct where I have made a mistake and guide me on what I have to do exactly.
  • Satheeshkumar said:
    Here I have tried updating softdevice
    What SoftDevice version are you updating from and to ?
    Can you post the nrfutil command you used to generate the zipfile package ?
    Is application DFU working ?
  • I have already posted the nrfutil command. Please check in the image of the previous post.
    The target device has flashed with s110_7.1.0_softdevice.hex and bootloader firmware.
    Updating firmware got from test_ble_dual_bank folder in dfu example folder. I think the updating firmware file version is 0xFFFE.
    Bootloader firmware atarted to advertise that named as ""DfuTarg".
  • here I have attached the full example source which I am using currently.
    1. bootloader source file.
    2. actual softdevice file(s110_nrf51822_7.1.0_softdevice.hex).
    3. test softdevice firmware(dfu_test_softdevice_b.hex) that need to update via ble.
    4. this is the nrfutil command (nrfutil dfu genpkg --softdevice softdevice.hex --dev-type 0xffff --dev-revision 0xffff --sd-req 0x5a softdevice.zip).
    I used a custom board with nrf51822 QFAA(16kb ram, 256 kb).
    here's my attachment.
    8244.dfu.zip
    please give me the solution.
    Satheeshkumar said:
    in that forum, they suggested reducing the stack size from 2048 to 255 in amr_startup_nrf51.s file.
     You should set this back to 2048.
    Since you are using S110, you can instead adjust the IRAM1 value. Instead of start 0x20002C00, try start 0x20002000 and Size 0x1f80:
    IRAM1 Start: 0x20002000
    IRAM1 Size: 0x1f80
    Also check that you have this buffer configuration (hci_mem_pool_internal.h):
    #ifndef MEM_POOL_INTERNAL_H__
    #define MEM_POOL_INTERNAL_H__
    #define TX_BUF_SIZE       4u    /**< TX buffer size in bytes. */
    #define RX_BUF_SIZE       32u   /**< RX buffer size in bytes. */
    #define RX_BUF_QUEUE_SIZE 8u    /**< RX buffer element size. */
    #endif // MEM_POOL_INTERNAL_H__
  • hey man, thank you so much. it is working.
    #define TX_BUF_SIZE 4u //600u /**< TX buffer size in bytes. */
    #define RX_BUF_SIZE 32u //TX_BUF_SIZE /**< RX buffer size in bytes. */
    #define RX_BUF_QUEUE_SIZE 8u//4u /**< RX buffer element size. */
    I changed as you mentioned in the latest post. so It had been a buffer size issue. now I can able update the application and softdevice.
