Hello All,
I am trying to add DFU service in the small example with the custom service.
But is not working, facing issues.
I am working on the nrf52810 board with SDK 14.2.
Please guide/provide procedure to how add DFU service with existing code along with Custom service.
Please check my main.c file below.
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_app_template_main main.c
* @ingroup ble_sdk_app_template
* @brief Template project main file.
* This file contains a template for creating a new application. It has the code necessary to wakeup
* from button, advertise, get a connection restart advertising on disconnect and if no new
* connection created go back to system-off mode.
* It can easily be used as a starting point for creating a new application, the comments identified
* with 'YOUR_JOB' indicates where and how you can customize.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ble_cus.h"
#include "ble_tps.h"
/*** Used for testing FDS ***/
static volatile uint8_t write_flag_fds_test = 0;
#define FILE_ID_FDS_TEST 0x1111
#define REC_KEY_FDS_TEST 0x2222
#define DEVICE_NAME "FIND_81" /**< Name of device. Will be included in the advertising data. */
#define DEVICE_NAME2 "FIND_01" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 80 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED //18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define NOTIFICATION_INTERVAL APP_TIMER_TICKS(1000)
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define TX_POWER_LEVEL (-40) /**< TX Power Level value. This will be set both in the TX Power service, in the advertising data, and also used to set the radio transmit power. */
#define TX_POWER_LEVEL1 (0) /**< TX Power Level value. This will be set both in the TX Power service, in the advertising data, and also used to set the radio transmit power. */
#define TX_POWER_LEVEL2 (-8) /**< TX Power Level value. This will be set both in the TX Power service, in the advertising data, and also used to set the radio transmit power. */
#define TX_POWER_LEVEL3 (-8) /**< TX Power Level value. This will be set both in the TX Power service, in the advertising data, and also used to set the radio transmit power. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
NRF_BLE_GATT_DEF(m_gatt);
NRF_BLE_QWR_DEF(m_qwr); /**< GATT module instance. */
BLE_CUS_DEF(m_cus);
BLE_TPS_DEF(m_tps); // tx power
/**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_notification_timer_id);
static uint8_t m_custom_value = 0;
uint32_t varitemp = 0;
//int temp_name_id;
unsigned char DEVICE_NAME1[]={};
static uint8_t m_deadbeef[8] = {0xA1,0x00,0xA3,0xA4,00,00,00,00};
static uint8_t tempbuff[8];
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
/* YOUR_JOB: Declare all services structure your application is using
* BLE_XYZ_DEF(m_xyz);
// YOUR_JOB: Use UUIDs for service(s) used in your application.
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN },
{BLE_UUID_TX_POWER_SERVICE, BLE_UUID_TYPE_BLE}
static void advertising_start(bool erase_bonds);
static ret_code_t fds_read(void);
static ret_code_t fds_test_write(void);
static ret_code_t fds_test_init (void);
static ret_code_t fds_test_find_and_delete (void);
/**@brief Function for handling File Data Storage events.
* @param[in] p_evt Peer Manager event.
* @param[in] cmd
static void fds_evt_handler(fds_evt_t const * const p_evt)
if (p_evt->id == FDS_EVT_GC)
NRF_LOG_DEBUG("GC completed\n");
/**@brief Function for initializing the TX Power Service.
static void tps_init(void)
ret_code_t err_code;
ble_tps_init_t tps_init_obj;
memset(&tps_init_obj, 0, sizeof(tps_init_obj));
tps_init_obj.initial_tx_power_level = TX_POWER_LEVEL3;
tps_init_obj.tpl_rd_sec = SEC_JUST_WORKS;
//tps_init_obj.tpl_wr_sec = SEC_JUST_WORKS;
err_code = ble_tps_init(&m_tps, &tps_init_obj);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
static void pm_evt_handler(pm_evt_t const * p_evt)
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("Connected to a previously bonded device.");
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
} break;
case PM_EVT_CONN_SEC_FAILED:
/* Often, when securing fails, it shouldn't be restarted, for security reasons.
* Other times, it can be restarted directly.
* Sometimes it can be restarted, but only after changing some Security Parameters.
* Sometimes, it cannot be restarted until the link is disconnected and reconnected.
* Sometimes it is impossible, to secure the link, or the peer device does not support it.
* How to handle this error is highly application dependent. */
} break;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
// Run garbage collection on the flash.
err_code = fds_gc();
if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
// Retry.
} break;
advertising_start(false);
} break;
case PM_EVT_PEER_DATA_UPDATE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
} break;
case PM_EVT_PEER_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
} break;
case PM_EVT_PEERS_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
} break;
case PM_EVT_ERROR_UNEXPECTED:
// Assert.
APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
} break;
case PM_EVT_CONN_SEC_START:
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
case PM_EVT_PEER_DELETE_SUCCEEDED:
case PM_EVT_LOCAL_DB_CACHE_APPLIED:
case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
// This can happen when the local DB has changed.
case PM_EVT_SERVICE_CHANGED_IND_SENT:
case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void notification_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
// Increment the value of m_custom_value before nortifing it.
m_custom_value++;
err_code = ble_cus_custom_value_update(&m_cus, m_custom_value);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
// Create timers.
err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler);
/* YOUR_JOB: Create any timers to be used by the application.
Below is an example of how to create a timer.
For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
one.
err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
APP_ERROR_CHECK(err_code); */
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
/* YOUR_JOB: Use an appearance value matching the application's use case.
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the YYY Service events.
* YOUR_JOB implement a service handler function depending on the event the service you are using can generate
* @details This function will be called for all YY Service events which are passed to
* the application.
* @param[in] p_yy_service YY Service structure.
* @param[in] p_evt Event received from the YY Service.
static void on_yys_evt(ble_yy_service_t * p_yy_service,
ble_yy_service_evt_t * p_evt)
switch (p_evt->evt_type)
case BLE_YY_NAME_EVT_WRITE:
APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
// No implementation needed.
//static void ble_cus_on_ble_evt
/**@brief Function for handling the Custom Service Service events.
* @details This function will be called for all Custom Service events which are passed to
* the application.
* @param[in] p_cus_service Custom Service structure.
* @param[in] p_evt Event received from the Custom Service.
static void on_cus_evt(ble_cus_t * p_cus_service,
ble_cus_evt_t * p_evt)
switch(p_evt->evt_type)
case BLE_CUS_EVT_NOTIFICATION_ENABLED:
err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
case BLE_CUS_EVT_NOTIFICATION_DISABLED:
err_code = app_timer_stop(m_notification_timer_id);
case BLE_CUS_EVT_CONNECTED:
case BLE_CUS_EVT_DISCONNECTED:
ble_cus_init_t cus_init = {0};
// Initialize CUS Service init structure to zero.
cus_init.evt_handler = on_cus_evt;
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.write_perm);
err_code = ble_cus_init(&m_cus, &cus_init);
/* YOUR_JOB: Add code to initialize the services used by the application.
ble_xxs_init_t xxs_init;
ble_yys_init_t yys_init;
// Initialize XXX Service.
memset(&xxs_init, 0, sizeof(xxs_init));
xxs_init.evt_handler = NULL;
xxs_init.is_xxx_notify_supported = true;
xxs_init.ble_xx_initial_value.level = 100;
err_code = ble_bas_init(&m_xxs, &xxs_init);
// Initialize YYY Service.
memset(&yys_init, 0, sizeof(yys_init));
yys_init.evt_handler = on_yys_evt;
yys_init.ble_yy_initial_value.counter = 0;
err_code = ble_yy_service_init(&yys_init, &yy_init);
tps_init();
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void application_timers_start(void)
/* YOUR_JOB: Start your timers. below is an example of how to start a timer.
err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
static void decitohex(int value)
long int decn,rmd,q,dn=0,m,l;
int i=1,j,tmp;
char s;
char a;
q = value;
for(l=q;l>0;l=l/16)
tmp = l % 16;
if( tmp < 10)
tmp =tmp + 48; else
tmp = tmp + 55;
dn=dn*100+tmp;
printf("\nThe equivalent Hexadecimal Number : ");
for(m=dn;m>0;m=m/100)
s=m % 100;
a+=s;
printf("%c",s);
NRF_LOG_INFO("s = %c\r\n", s);
NRF_LOG_INFO("a = %c\r\n", a);
// printf("\n\n");
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ret_code_t err_code = NRF_SUCCESS;
///uint32_t temp_name_id;
ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
NRF_LOG_INFO("Disconnected.");
NRF_LOG_INFO("temp_name_id = %d\r\n", temp_name_id);
for (uint8_t i = 0;i < strlen(temp_name_id);i++)
DEVICE_NAME1[i] = (temp_name_id);
NRF_LOG_INFO("DEVICE_NAME1[i] = %x\r\n", DEVICE_NAME1[i]);//x c
NRF_LOG_INFO("m_deadbeef = %x\r\n", m_deadbeef[0]);
//decitohex(temp_name_id);
m_deadbeef[0] = temp_name_id;
for(int i =0;i<8;i++)
NRF_LOG_INFO("m_deadbeef[%d] = %x\r\n",i, m_deadbeef[i]);
tempbuff[i]= m_deadbeef[i];
NRF_LOG_INFO("tempbuff[%d] = %x\r\n",i, tempbuff[i]);
//int i;
// if(tempbuff[0] == 45)
// i=i+1;
// NRF_LOG_INFO("i = %d\r\n",i);
// else
// Test FDS:
err_code =fds_test_init();
// err_code = fds_test_find_and_delete();
// APP_ERROR_CHECK(err_code);
err_code =fds_test_write();
// //wait until the write is finished.
while (write_flag_fds_test==0);
err_code = fds_read();
// DEVICE_NAME2[5] += (char*)DEVICE_NAME1[0];
// NRF_LOG_INFO("DEVICE_NAME2 = %c\r\n", DEVICE_NAME2[5]);
// DEVICE_NAME2[6] = DEVICE_NAME1[1];
// NRF_LOG_INFO("DEVICE_NAME2 = %c\r\n", DEVICE_NAME2[6]);
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_GATTS_EVT_WRITE:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
* @param[in] event Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_KEY_0
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
// init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
// init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
/* ret_code_t err_code;
ble_advdata_t advdata;
// Build advertising data struct to pass into @ref ble_advertising_init.
memset(&advdata, 0, sizeof(advdata));
// ble_adv_modes_config_t options = {0};
// options.ble_adv_fast_enabled = BLE_ADV_FAST_ENABLED;
// options.ble_adv_fast_interval = APP_ADV_INTERVAL;
// options.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
// err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
uint8_t adv_data[13] = {0};
uint8_t sr_data[20] = {0};
// flags for discoverable/connectable
adv_data[0] = 0x02; // ad field length = 2 bytes
adv_data[1] = 0x01; // ad field type = 0x01 [Flags)
adv_data[2] = 0x06; // flags = 0x06, connectable/undirected
// tx power field advertisement, iOS apps may need this
adv_data[3] = 0x02; // ad field length = 2 bytes
adv_data[4] = 0x0a; // ad field type = 0x0A [TX Power)
adv_data[5] = 0x03; // TX power in dBm
// NOTE: TX power is a signed 8-bit value, and is not changed automatically
// when using "hardware_set_txpower[<power>)". This may be anywhere from -23
// to +3 based on your settings. Negative values may be converted to two's
// complement form by adding 256, so for example -23 dBm would be 233 or 0xE9.
// custom manufacturer
adv_data[6] = 0x06; // ad field length = 5 bytes [arbitrary, maybe more or less but minimum 3)
adv_data[7] = 0xff; // ad field type = 0xFF [Manufacturer Specific Data)
adv_data[8] = 0xff; // unknown/prototype Company Identifier Code - octet 2
adv_data[9] = 0xff; // unknown/prototype Company Identifier Code - octet 1
adv_data[10] = 0xb1; // custom data byte //1 [can be anything)
adv_data[11] = 0xb2; // custom data byte //2 [can be anything)
adv_data[12] = 0xb3; // custom data byte //3 (can be anything)
// NOTE: manufacturer data fields should contain the Company Identifier Code
// in order to stay within BT 4.0 spec. You should also ideally obtain an
// an official Company Identifier Code, but 0xFFFF is suitable for development.
// (this is why the minimum ad field length for this is 3, so the CIC fits)
// More bytes are possible here, but not necessary for this demo.
// Compare with automatically generated ad packets from other
// demo projects to see what else you might put here, or read
// the relevant portions of the Bluetooth 4.0 Core Spec document
// for greater detail.
// build custom scan response data
// get Bluetooth MAC address of this device (NOTE: this is little-endian!)
sr_data[0] = 0x13; // ad field length = 19 bytes (0x13)
sr_data[1] = 0x09; // ad field type = 0x09 (Complete local name)
sr_data[2] = 0x4d; // 'M'
sr_data[3] = 0x79; // 'y'
sr_data[4] = 0x20; // ' '
sr_data[5] = 0x57; // 'W'
sr_data[6] = 0x69; // 'i'
sr_data[7] = 0x64; // 'd'
sr_data[8] = 0x67; // 'g'
sr_data[9] = 0x65; // 'e'
sr_data[10] = 0x74; // 't'
sr_data[11] = 0x20; // ' '
sr_data[12] = 0x01;
sr_data[13] = 0x02;
sr_data[14] = 0x03;
sr_data[15] = 0x04;
sr_data[16] = 0x05;
sr_data[17] = 0x06;
sr_data[18] = 0x07;
sr_data[19] = 0x08;
ble_gap_adv_params_t adv_params;
// uint32_t err_code;
err_code = sd_ble_gap_adv_set_configure(&adv_params, &adv_data[13], &sr_data[20]);
// ble_gap_adv_params_t adv_params;
// // Start advertising
// memset(&adv_params, 0, sizeof(adv_params));
// adv_params.type = BLE_GAP_ADV_TYPE_ADV_IND;
// adv_params.p_peer_addr = NULL;
// adv_params.fp = BLE_GAP_ADV_FP_ANY;
// adv_params.interval = APP_ADV_INTERVAL;
// adv_params.timeout = APP_ADV_TIMEOUT_IN_SECONDS;
// err_code = sd_ble_gap_adv_start(&adv_params, APP_BLE_CONN_CFG_TAG);
// bsp_board_led_on(ADVERTISING_LED);
// bsp_board_led_off(ADVERTISING_LED);
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void tx_power_set(void)
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_advertising.adv_handle, TX_POWER_LEVEL3);
//tx_power_set();
//ble_tps_tx_power_level_set(&m_tps,TX_POWER_LEVEL);
NRF_LOG_INFO("tx service started.");
static void my_fds_evt_handler(fds_evt_t const * const p_fds_evt)
switch (p_fds_evt->id)
case FDS_EVT_INIT:
if (p_fds_evt->result != FDS_SUCCESS)
// Initialization failed.
case FDS_EVT_WRITE:
if (p_fds_evt->result == FDS_SUCCESS)
write_flag_fds_test=1;
//static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
//static uint8_t const m_deadbeef[8] = {0xA1,0x00,0xA3,0xA4,00,45,12,32};
fds_record_t record;
fds_record_desc_t record_desc;
// Set up data.
// Set up record.
record.file_id = FILE_ID_FDS_TEST;
record.key = REC_KEY_FDS_TEST;
record.data.p_data = &m_deadbeef;
//record.data.length_words = sizeof(m_deadbeef)/sizeof(uint32_t);
record.data.length_words = sizeof(m_deadbeef)/sizeof(uint8_t);
record_desc.record_id =1;
ret_code_t ret = fds_record_write(&record_desc, &record);
if (ret != FDS_SUCCESS)
return ret;
NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
return NRF_SUCCESS;
fds_flash_record_t flash_record;
fds_find_token_t ftok ={0};//Important, make sure you zero init the ftok token
//uint32_t *data;
uint8_t *data;
uint32_t err_code;
NRF_LOG_INFO("Start searching... \r\n");
// Loop until all records with the given key and file ID have been found.
//while (fds_record_find(FILE_ID_FDS_TEST, REC_KEY_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
while (fds_record_find_in_file(FILE_ID_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
err_code = fds_record_open(&record_desc, &flash_record);
if ( err_code != FDS_SUCCESS)
return err_code;
NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
NRF_LOG_INFO("Data = ");
//data = (uint32_t *) flash_record.p_data;
data = (uint8_t *) flash_record.p_data;
// for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
// NRF_LOG_INFO("0x%8x ",data[i]);
// NRF_LOG_INFO("\r\n");
if(record_desc.record_id == 1)
NRF_LOG_INFO("%x",data[i]);
//NRF_LOG_INFO("0x%8x ",data[2]);
//fds_record_find_in_file()
// Access the record through the flash_record structure.
// Close the record when done.
err_code = fds_record_close(&record_desc);
if (err_code != FDS_SUCCESS)
return err_code;
return NRF_SUCCESS;
fds_find_token_t ftok;
ftok.page=0;
ftok.p_addr=NULL;
// Loop and find records with same ID and rec key and mark them as deleted.
fds_record_delete(&record_desc);
NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
// call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
ret_code_t ret = fds_gc();
return ret;
return NRF_SUCCESS;
ret_code_t ret = fds_register(my_fds_evt_handler);
return ret;
ret = fds_init();
return ret;
return NRF_SUCCESS;
/**@brief Function for application main entry.
uint32_t err_code;
bool erase_bonds;
// Initialize.
log_init();
timers_init();
//power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
peer_manager_init();
// Test FDS:
// err_code =fds_test_init();
// err_code =fds_test_write();
// while (write_flag_fds_test==0);
// err_code = fds_read();
// Start execution.
NRF_LOG_INFO("Template example started.");
application_timers_start();
advertising_start(erase_bonds);
tx_power_set();
// Enter main loop.
for (;;)
idle_state_handle();
Waiting for your Valuable response.
Rohit
