hi guys,
I was just getting started with Nordic nRF52832,
I want to find buffer containing bluetooth scanning data (Beacon) to process but see the examples but can't see.
Can you show me how that function is used
thank a lot!
hi guys,
thank a lot!
You do not say anything about which SDK version or which example you are using, but I will give you an example.
Starting with the ble_app_blinky_c central application in SDK 16.0.0, you can get the advertising data of scanned devices that do not match the scan filer in scan_evt_handler, using the following code:
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
ret_code_t err_code;
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_NOT_FOUND:
NRF_LOG_INFO("Received advertising from: %02x:%02x:%02x:%02x:%02x:%02x:%02x", p_scan_evt->params.p_not_found->peer_addr.addr[0],
p_scan_evt->params.p_not_found->peer_addr.addr[1],
p_scan_evt->params.p_not_found->peer_addr.addr[2],
p_scan_evt->params.p_not_found->peer_addr.addr[3],
p_scan_evt->params.p_not_found->peer_addr.addr[4],
p_scan_evt->params.p_not_found->peer_addr.addr[5]);
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
This will print the address of the device that sent the advertising packet. Other beacon data can be accessed through the same struct.
To avoid that the scanner connects to a BLE blinky device, you must disable the scan filer by commenting out/removing these lines in scan_init():
// Setting filters for scanning. // err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false); // APP_ERROR_CHECK(err_code); // // err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name); // APP_ERROR_CHECK(err_code);
Jørgen
