NRF_RADIO->TXADDRESS and RX use case
I am using proprietary radio between 2 nrf51 devices, by copying from an example see code below.
That works but now I want to have more pairs of devices and I need to have unique addresses.
You would think I only need to change the TX and RX Adress registers but it is not so simple.
After doing some reading I think they only select the pipes (for reception of multiple addresses)
So since I have have 4 bytes address length I will only need to change the base0 address ?
And I can set RX and TX to 0 and leave the prefix alone ?
Or can I use one of the 8 bluetooth adresses DAB[] ?
I only need to send a sync packet so I don't want Enhanced shockburst retransmission etc, is this standard off or do I need to set a register ?
void radio_configure(void)
NRF_RADIO->POWER = (RADIO_POWER_POWER_Enabled << RADIO_POWER_POWER_Pos);
NRF_RADIO->EVENTS_END = 0;
(void)NRF_RADIO->EVENTS_END;
// Radio config
NRF_RADIO->TXPOWER = (RADIO_TXPOWER_TXPOWER_Pos4dBm << RADIO_TXPOWER_TXPOWER_Pos);
NRF_RADIO->FREQUENCY = FREQ_BIN; // Frequency bin 7, 2407MHz
NRF_RADIO->MODE = (RADIO_MODE_MODE_Nrf_1Mbit << RADIO_MODE_MODE_Pos);
// Radio address config
NRF_RADIO->PREFIX0 =
((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC1) << 8) // Prefix byte of address 1 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
NRF_RADIO->PREFIX1 =
((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
| ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL); // Base address for prefix 0 converted to nRF24L series format
NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL); // Base address for prefix 1-7 converted to nRF24L series format
NRF_RADIO->TXADDRESS = 0x00UL; // Set device address 0 to use when transmitting
NRF_RADIO->RXADDRESSES = 0x01UL; // Enable device address 0 to use to select which addresses to receive
// Packet configuration
NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE << RADIO_PCNF0_S1LEN_Pos) |
(PACKET_S0_FIELD_SIZE << RADIO_PCNF0_S0LEN_Pos) |
(PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
(RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos) |
(PACKET_BASE_ADDRESS_LENGTH << RADIO_PCNF1_BALEN_Pos) |
(PACKET_STATIC_LENGTH << RADIO_PCNF1_STATLEN_Pos) |
(PACKET_PAYLOAD_MAXSIZE << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
// CRC Config
NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x11021UL; // CRC poly: x^16 + x^12^x^5 + 1
else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
NRF_RADIO->CRCINIT = 0xFFUL; // Initial value
NRF_RADIO->CRCPOLY = 0x107UL; // CRC poly: x^8 + x^2^x^1 + 1
    TXADDRESS selects a combination of BASE and PREFIX bytes that makes up a transmit address, according to table 59 in manual. RXADDRESSES is a bit mask for BASE/PREFIX combinations that will match for receiver. It's better to use TXADDRESS=0 (RXADDRESSES=0x01) because it gives better sensitivity than 1-7.  You can leave TXADDRESS and RXADDRESSES as in example and change either BASE or PREFIX to have different addreses for each pair. Keep in mind that any byte of BASE/PREFIX should not be 0x00.
    No, you need to set both PREFIX and BASE, and RXADDRESS should not be 0.
  • Thanks for the explanation Dmitry.
    It is a bit clearer now.
    I could not found a table about this in the nrf51 manual (59 is about reset) but that is ok.
    I changed the code to this:
    uint32_t access_address = 0x10234577;
    NRF_RADIO->PREFIX0 = ((access_address >> 24) & 0x000000FF);
    NRF_RADIO->BASE0 = ((access_address << 8) & 0xFFFFFF00);
    NRF_RADIO->TXADDRESS = 0x00; // Use logical address 0 (prefix0 + base0)
    NRF_RADIO->RXADDRESSES = 0x01; // Enable reception on logical address 0 (PREFIX0 + BASE0)
    It is good to know that there may be no 0x00 in the address.
