Attempt to assign the value 'x' to the undefined symbol 'y'
OS: Windows 10
NRF Repository at branch master, commit bd67811aa123a49cb36991be886f3fafb4730449.
Zephyr version: 2.1.0
SES version: 4.20a
Have tried running SES on administrator.
Log:
Loading solution asset_tracker.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=C:/ncs2/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/ncs2/nrf/applications/asset_tracker/build -HC:/ncs2/nrf/applications/asset_tracker -DPYTHON_EXECUTABLE=C:/Program Files (x86)/Microsoft Visual Studio/Shared/Python37_64/python.exe -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/ncs/SEGGER/html/configure_nordic_project_menuconfig.py
-- Using application from 'C:/ncs2/nrf/applications/asset_tracker'
-- Selected BOARD nrf9160_pca10090ns
-- Cache files will be written to: C:\Users\Thomas Aunvik\AppData\Local/.cache/zephyr
USING OUT OF TREE BOARD
-- Loading C:/ncs2/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
Devicetree configuration written to C:/ncs2/nrf/applications/asset_tracker/build/zephyr/include/generated/generated_dts_board.conf
C:/ncs2/nrf/applications/asset_tracker/prj.conf:22: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
Parsing Kconfig tree in C:/ncs2/nrf/applications/asset_tracker/Kconfig
Loaded configuration 'C:/ncs2/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig'
Merged configuration 'C:/ncs2/nrf/applications/asset_tracker/prj.conf'
C:/ncs2/nrf/applications/asset_tracker/prj.conf:23: warning: attempt to assign the value 'y' to the undefined symbol LTE_NETWORK_MODE_LTE_M_GPS
C:/ncs2/nrf/applications/asset_tracker/prj.conf:24: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT
C:/ncs2/nrf/applications/asset_tracker/prj.conf:25: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL_LOG_LEVEL_DBG
C:/ncs2/nrf/applications/asset_tracker/prj.conf:27: warning: attempt to assign the value 'n' to the undefined symbol LTE_NETWORK_MODE_NBIOT
C:/ncs2/nrf/applications/asset_tracker/prj.conf:28: warning: attempt to assign the value 'n' to the undefined symbol LTE_LEGACY_PCO_MODE
C:/ncs2/nrf/applications/asset_tracker/prj.conf:29: warning: attempt to assign the value '"00000110"' to the undefined symbol LTE_PSM_REQ_RPTAU
C:/ncs2/nrf/applications/asset_tracker/prj.conf:30: warning: attempt to assign the value '"00000000"' to the undefined symbol LTE_PSM_REQ_RAT
C:/ncs2/nrf/applications/asset_tracker/prj.conf:33: warning: attempt to assign the value 'y' to the undefined symbol MODEM_INFO
C:/ncs2/nrf/applications/asset_tracker/prj.conf:36: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
C:/ncs2/nrf/applications/asset_tracker/prj.conf:37: warning: attempt to assign the value 'n' to the undefined symbol BSD_LIBRARY_TRACE_ENABLED
C:/ncs2/nrf/applications/asset_tracker/prj.conf:40: warning: attempt to assign the value 'y' to the undefined symbol CLOUD_API
C:/ncs2/nrf/applications/asset_tracker/prj.conf:41: warning: attempt to assign the value 'y' to the undefined symbol NRF_CLOUD
C:/ncs2/nrf/applications/asset_tracker/prj.conf:42: warning: attempt to assign the value 'y' to the undefined symbol NRF_CLOUD_LOG_LEVEL_DBG
C:/ncs2/nrf/applications/asset_tracker/prj.conf:50: warning: attempt to assign the value 'y' to the undefined symbol NRF9160_GPS
C:/ncs2/nrf/applications/asset_tracker/prj.conf:51: warning: attempt to assign the value 'y' to the undefined symbol NRF9160_GPS_LOG_LEVEL_DBG
C:/ncs2/nrf/applications/asset_tracker/prj.conf:62: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY
C:/ncs2/nrf/applications/asset_tracker/prj.conf:63: warning: attempt to assign the value 'n' to the undefined symbol DK_LIBRARY_INVERT_LEDS
C:/ncs2/nrf/applications/asset_tracker/prj.conf:89: warning: attempt to assign the value 'y' to the undefined symbol AWS_FOTA
C:/ncs2/nrf/applications/asset_tracker/prj.conf:90: warning: attempt to assign the value 'y' to the undefined symbol AWS_FOTA_LOG_LEVEL_DBG
C:/ncs2/nrf/applications/asset_tracker/prj.conf:91: warning: attempt to assign the value 'y' to the undefined symbol AWS_JOBS_LOG_LEVEL_DBG
C:/ncs2/nrf/applications/asset_tracker/prj.conf:92: warning: attempt to assign the value '128' to the undefined symbol AWS_FOTA_VERSION_STRING_MAX_LEN
C:/ncs2/nrf/applications/asset_tracker/prj.conf:93: warning: attempt to assign the value 'y' to the undefined symbol DFU_TARGET
C:/ncs2/nrf/applications/asset_tracker/prj.conf:96: warning: attempt to assign the value 'y' to the undefined symbol DOWNLOAD_CLIENT
C:/ncs2/nrf/applications/asset_tracker/prj.conf:97: warning: attempt to assign the value '4096' to the undefined symbol DOWNLOAD_CLIENT_STACK_SIZE
Error: Aborting due to non-whitelisted Kconfig warning
'C:/ncs2/nrf/applications/asset_tracker/prj.conf:22: warning: attempt to assign the value 'y' to the
undefined symbol LTE_LINK_CONTROL'. Note: If this warning doesn't point to an actual problem, you
can add it to the whitelist at the top of C:/ncs2/zephyr/scripts/kconfig/kconfig.py.
CMake Error at C:/ncs2/zephyr/cmake/kconfig.cmake:227 (message):
  command failed with return code: 1
  C:/ncs2/zephyr/cmake/app/boilerplate.cmake:567 (include)
  CMakeLists.txt:11 (include)
Project load failed
Reported error: solution load command failed (1)
