52833-DK ADC demo program - not reading voltages
I am running the ADC demo for the 52833-DK (pca10100) and can’t seem to get any valid readings.  SDK 16.0: examples\peripheral\saadc
I am applying 1.5V  to AIN0 on P8 and the readings are all around x23 counts.    I tried moving to AIN2 (sw change) with no luck.  I then went back to AIN0 and moved the 1.5V stimulus to each AIN channel to see if maybe there was a label misprint or something.    I have 2 boards and tried both with the same results.
I verified NRFX_SAADC_ENABLED=1 in sdk_config.h
 I went through and verified all of the ADC registers in the debugger and they look correct to me (single-ended, p-connected, n-disconnected, 10-bit, internal reference, Gain = 1/6, etc).  The ADC is sampling;  I see small changes in the readings, and I can change the reference to Vcc/4 on the fly and the readings will drop by 8 counts or so.
 Do I need to do something on the DK board to get analog readings?
