Problem in getting data from sensor(vl53l0x) to nrf52832 using I2C interface
Hi Nordic Support,
I am getting zero distance value from sensor(vl53l0x). I used SLAVE_ADDRESS =0x29 and register address=0x01. My code is mentioned below
 void data_handler(void)
    uint16_t dist_buf=0;
    NRF_LOG_INFO("distance: %d (in mm).", data);
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
//printf("event =%d\n",p_event->type);
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
             if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
               data_handler();
            m_xfer_done = true;
            printf("done\n");
        case NRF_DRV_TWI_EVT_ADDRESS_NACK:
              printf("No address ACK on address\n");
        case NRF_DRV_TWI_EVT_DATA_NACK:
              printf("No data ACK on address\n");
 * @brief Initialize the master TWI
 * Function used to initialize master TWI interface that would communicate with simulated EEPROM.
 * @return NRF_SUCCESS or the reason of failure
static ret_code_t twi_master_init(void)
    ret_code_t ret;
    const nrf_drv_twi_config_t config =
       .scl                = TWI_SCL_M,
       .sda                = TWI_SDA_M,
       .frequency          = NRF_TWI_FREQ_400K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
       .clear_bus_init     = false
    do
        ret = nrf_drv_twi_init(&m_twi_master, &config, twi_handler,NULL);
        if(NRF_SUCCESS != ret)
        nrf_drv_twi_enable(&m_twi_master);
    }while(0);
    return ret;
static void read_sensor_data()
    m_xfer_done = false;
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi_master, SLAVE_ADDRESS, &data, sizeof(data));
   // result = (float)(data * 3.0517) ;
   // distance = (uint16_t)result;
    distance = (uint16_t)(data[0] << 8 | data[1]);
    printf("value %d\n",distance);
    bool erase_bonds;
  uint8_t register_address = 0x01;
  uint8_t buffer={0};
    // Initialize.
    log_init();
     ret_code_t err_code;
     twi_master_init();
      m_xfer_done=false;
     err_code=nrf_drv_twi_tx(&m_twi_master,SLAVE_ADDRESS,&register_address,sizeof(register_address),false);
     if(err_code == NRF_SUCCESS)
              NRF_LOG_INFO("Device Address and Register Address(3 bit mode+ 5 bit reg address sent");
     while(m_xfer_done == false)
        NRF_LOG_PROCESS();
    while (true)
        nrf_delay_ms(500);
        do
            __WFE();
        }while (m_xfer_done == false);
        read_sensor_data();
        NRF_LOG_FLUSH();
Please suggest whats wrong in this code and why i am getting zero distance value.
Thanks & Regards,
HEY
    Have you tried to debug the code to see if data_handler() gets called from your twi_handler() callback?  if you always get 0, it likely means that the data is not being read from the sensor so you're just getting the variable init value.
    Vidar
  • Hey vidar
    Thanks for the update!
    I have checked by debugging the code to see the data_handler() functionality and it is being called by the twi_handler()
    correctly.
    Now i am getting below mentioned Values always/constantly, whenever going for debugging the code.
    Please Suggest how to proceed on this.
    distance: 255 (in mm).done
    distance: 1 (in mm).done
    distance: 0 (in mm).done
    distance: 64 (in mm).done
    distance: 186 (in mm).done
    distance: 26 (in mm).done
    distance: 4 (in mm).done
    distance: 3 (in mm).done
    distance: 68 (in mm).done
    distance: 130 (in mm).done
    distance: 128 (in mm).done
    distance: 7 (in mm).done
    distance: 19 (in mm).done
    distance: 42 (in mm).done
    I noticed now that you're logging distance from your read_sensor_data() function as well. nrf_drv_twi_rx() will return as soon as the transaction has been set up (provided DMA buffers) and the completion/result of that transaction is reported to the app via the TWIM callback. So you should comment out the "distance = (uint16_t)(data[0] << 8 | data[1]);" and  "printf("value %d\n",distance);" line from your read_sensor_data() function so the distance is only logged from data_handler().
  • Hi Vidar,
    After commenting  "distance = (uint16_t)(data[0] << 8 | data[1]);" and  "printf("value %d\n",distance);" line from your read_sensor_data() function also, i am getting the above readings of distance.
    Please suggest for further.
1 2 3 4
