Hello All,
I am working on the Nrf52810 board with sdk 14.2.
I have implemented the read ,write , delete feature in my code.
Now it is creating new entry for repeating/creating new record read write function each .
I wanted to read / write / delete in same location or (restrict in one location)
Here is my mainc file please check below.
* Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
* @brief Heart Rate Service Sample Application main file.
* This file contains the source code for a sample application using the Heart Rate service
* (and also Battery and Device Information services). This application uses the
* @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "ble_conn_state.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/*** Used for testing FDS ***/
static volatile uint8_t write_flag_fds_test = 0;
#define FILE_ID_FDS_TEST 0x1111
#define REC_KEY_FDS_TEST 0x2222
#define DEVICE_NAME "Nordic_HRM" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS 180 /**< The advertising timeout in units of seconds. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(2000) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL 81 /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL 100 /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT 1 /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL APP_TIMER_TICKS(1000) /**< Heart rate measurement interval (ticks). */
#define MIN_HEART_RATE 140 /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE 300 /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT 10 /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL APP_TIMER_TICKS(300) /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL 100 /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL 500 /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT 1 /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL APP_TIMER_TICKS(5000) /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(400, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(650, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define APP_FEATURE_NOT_SUPPORTED BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2 /**< Reply when unsupported features are requested. */
BLE_HRS_DEF(m_hrs); /**< Heart rate service instance. */
BLE_BAS_DEF(m_bas); /**< Structure used to identify the battery service. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id); /**< Battery timer. */
APP_TIMER_DEF(m_heart_rate_timer_id); /**< Heart rate measurement timer. */
APP_TIMER_DEF(m_rr_interval_timer_id); /**< RR interval timer. */
APP_TIMER_DEF(m_sensor_contact_timer_id); /**< Sensor contact detected timer. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static bool m_rr_interval_enabled = true; /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t m_battery_sim_cfg; /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state; /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t m_heart_rate_sim_cfg; /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state; /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t m_rr_interval_sim_cfg; /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state; /**< RR Interval sensor simulator state. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{BLE_UUID_HEART_RATE_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_BATTERY_SERVICE, BLE_UUID_TYPE_BLE},
{BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling File Data Storage events.
* @param[in] p_evt Peer Manager event.
* @param[in] cmd
static void fds_evt_handler(fds_evt_t const * const p_evt)
if (p_evt->id == FDS_EVT_GC)
NRF_LOG_DEBUG("GC completed\n");
/**@brief Function for handling Peer Manager events.
static void pm_evt_handler(pm_evt_t const * p_evt)
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("Connected to a previously bonded device.");
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
} break;
case PM_EVT_CONN_SEC_FAILED:
/* Often, when securing fails, it shouldn't be restarted, for security reasons.
* Other times, it can be restarted directly.
* Sometimes it can be restarted, but only after changing some Security Parameters.
* Sometimes, it cannot be restarted until the link is disconnected and reconnected.
* Sometimes it is impossible, to secure the link, or the peer device does not support it.
* How to handle this error is highly application dependent. */
} break;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
// Run garbage collection on the flash.
err_code = fds_gc();
if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
// Retry.
} break;
NRF_LOG_DEBUG("PM_EVT_PEERS_DELETE_SUCCEEDED");
advertising_start(false);
} break;
case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
// The local database has likely changed, send service changed indications.
pm_local_database_has_changed();
} break;
case PM_EVT_PEER_DATA_UPDATE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
} break;
case PM_EVT_PEER_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
} break;
case PM_EVT_PEERS_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
} break;
case PM_EVT_ERROR_UNEXPECTED:
// Assert.
APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
} break;
case PM_EVT_CONN_SEC_START:
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
case PM_EVT_PEER_DELETE_SUCCEEDED:
case PM_EVT_LOCAL_DB_CACHE_APPLIED:
case PM_EVT_SERVICE_CHANGED_IND_SENT:
case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
* in Battery Service.
static void battery_level_update(void)
uint8_t battery_level;
battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
err_code = ble_bas_battery_level_update(&m_bas, battery_level);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
battery_level_update();
/**@brief Function for handling the Heart rate measurement timer timeout.
* @details This function will be called each time the heart rate measurement timer expires.
* It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(void * p_context)
static uint32_t cnt = 0;
uint16_t heart_rate;
heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
cnt++;
err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
// Disable RR Interval recording every third heart rate measurement.
// NOTE: An application will normally not do this. It is done here just for testing generation
// of messages without RR Interval measurements.
m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer timeout.
* @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(void * p_context)
if (m_rr_interval_enabled)
uint16_t rr_interval;
rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
&m_rr_interval_sim_cfg);
ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer timeout.
* @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(void * p_context)
static bool sensor_contact_detected = false;
sensor_contact_detected = !sensor_contact_detected;
ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
err_code = app_timer_init();
// Create timers.
err_code = app_timer_create(&m_battery_timer_id,
APP_TIMER_MODE_REPEATED,
battery_level_meas_timeout_handler);
err_code = app_timer_create(&m_heart_rate_timer_id,
heart_rate_meas_timeout_handler);
err_code = app_timer_create(&m_rr_interval_timer_id,
rr_interval_timeout_handler);
err_code = app_timer_create(&m_sensor_contact_timer_id,
sensor_contact_detected_timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
p_evt->conn_handle,
p_evt->params.att_mtu_effective);
ble_hrs_on_gatt_evt(&m_hrs, p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
* @details Initialize the Heart Rate, Battery and Device Information services.
ble_hrs_init_t hrs_init;
ble_bas_init_t bas_init;
ble_dis_init_t dis_init;
uint8_t body_sensor_location;
// Initialize Heart Rate Service.
body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
memset(&hrs_init, 0, sizeof(hrs_init));
hrs_init.evt_handler = NULL;
hrs_init.is_sensor_contact_supported = true;
hrs_init.p_body_sensor_location = &body_sensor_location;
// Here the sec level for the Heart Rate Service can be changed/increased.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
err_code = ble_hrs_init(&m_hrs, &hrs_init);
// Initialize Battery Service.
memset(&bas_init, 0, sizeof(bas_init));
// Here the sec level for the Battery Service can be changed/increased.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
bas_init.evt_handler = NULL;
bas_init.support_notification = true;
bas_init.p_report_ref = NULL;
bas_init.initial_batt_level = 100;
err_code = ble_bas_init(&m_bas, &bas_init);
// Initialize Device Information Service.
memset(&dis_init, 0, sizeof(dis_init));
ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
m_battery_sim_cfg.min = MIN_BATTERY_LEVEL;
m_battery_sim_cfg.max = MAX_BATTERY_LEVEL;
m_battery_sim_cfg.incr = BATTERY_LEVEL_INCREMENT;
m_battery_sim_cfg.start_at_max = true;
sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
m_heart_rate_sim_cfg.min = MIN_HEART_RATE;
m_heart_rate_sim_cfg.max = MAX_HEART_RATE;
m_heart_rate_sim_cfg.incr = HEART_RATE_INCREMENT;
m_heart_rate_sim_cfg.start_at_max = false;
sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
m_rr_interval_sim_cfg.min = MIN_RR_INTERVAL;
m_rr_interval_sim_cfg.max = MAX_RR_INTERVAL;
m_rr_interval_sim_cfg.incr = RR_INTERVAL_INCREMENT;
m_rr_interval_sim_cfg.start_at_max = false;
sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
// Start application timers.
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = m_hrs.hrm_handles.cccd_handle;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
NRF_LOG_INFO("Disconnected, reason %d.",
p_ble_evt->evt.gap_evt.params.disconnected.reason);
#ifndef S140
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_EVT_USER_MEM_REQUEST:
err_code = sd_ble_user_mem_reply(m_conn_handle, NULL);
case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
ble_gatts_evt_rw_authorize_request_t req;
ble_gatts_rw_authorize_reply_params_t auth_reply;
req = p_ble_evt->evt.gatts_evt.params.authorize_request;
if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ) ||
(req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
(req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
&auth_reply);
} break;
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
err_code = fds_register(fds_evt_handler);
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_TIMEOUT_IN_SECONDS;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
/**@brief Function for the Power manager.
static void power_manage(void)
ret_code_t err_code = sd_app_evt_wait();
static void my_fds_evt_handler(fds_evt_t const * const p_fds_evt)
switch (p_fds_evt->id)
case FDS_EVT_INIT:
if (p_fds_evt->result != FDS_SUCCESS)
// Initialization failed.
case FDS_EVT_WRITE:
if (p_fds_evt->result == FDS_SUCCESS)
write_flag_fds_test=1;
static ret_code_t fds_test_write(void)
//static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
static uint8_t const m_deadbeef[8] = {0x00,0xA2,0xA3,0xA4,0x22,45,12,32};
fds_record_t record;
fds_record_desc_t record_desc;
// Set up data.
// Set up record.
record.file_id = FILE_ID_FDS_TEST;
record.key = REC_KEY_FDS_TEST;
record.data.p_data = &m_deadbeef;
//record.data.length_words = sizeof(m_deadbeef)/sizeof(uint32_t);
record.data.length_words = sizeof(m_deadbeef)/sizeof(uint8_t);
record_desc.record_id =1;
ret_code_t ret = fds_record_write(&record_desc, &record);
if (ret != FDS_SUCCESS)
return ret;
NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
return NRF_SUCCESS;
static ret_code_t fds_read(void)
fds_flash_record_t flash_record;
fds_find_token_t ftok ={0};//Important, make sure you zero init the ftok token
//uint32_t *data;
uint8_t *data;
uint32_t err_code;
NRF_LOG_INFO("Start searching... \r\n");
// Loop until all records with the given key and file ID have been found.
//while (fds_record_find(FILE_ID_FDS_TEST, REC_KEY_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
while (fds_record_find_in_file(FILE_ID_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
err_code = fds_record_open(&record_desc, &flash_record);
if ( err_code != FDS_SUCCESS)
return err_code;
NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
NRF_LOG_INFO("Data = ");
//data = (uint32_t *) flash_record.p_data;
data = (uint8_t *) flash_record.p_data;
// for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
// NRF_LOG_INFO("0x%8x ",data[i]);
// NRF_LOG_INFO("\r\n");
if(record_desc.record_id == 1)
NRF_LOG_INFO("%x",data[i]);
//NRF_LOG_INFO("0x%8x ",data[2]);
//fds_record_find_in_file()
// Access the record through the flash_record structure.
// Close the record when done.
err_code = fds_record_close(&record_desc);
if (err_code != FDS_SUCCESS)
return err_code;
return NRF_SUCCESS;
static ret_code_t fds_test_find_and_delete (void)
fds_find_token_t ftok;
ftok.page=0;
ftok.p_addr=NULL;
// Loop and find records with same ID and rec key and mark them as deleted.
fds_record_delete(&record_desc);
NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
// call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
ret_code_t ret = fds_gc();
return ret;
return NRF_SUCCESS;
static ret_code_t fds_test_init (void)
ret_code_t ret = fds_register(my_fds_evt_handler);
return ret;
ret = fds_init();
return ret;
return NRF_SUCCESS;
/**@brief Function for application main entry.
uint32_t err_code;
bool erase_bonds;
// Initialize.
log_init();
timers_init();
ble_stack_init();
gap_params_init();
gatt_init();
advertising_init();
services_init();
sensor_simulator_init();
conn_params_init();
peer_manager_init();
// Test FDS:
err_code =fds_test_init();
// err_code = fds_test_find_and_delete();
// APP_ERROR_CHECK(err_code);
err_code =fds_test_write();
//wait until the write is finished.
while (write_flag_fds_test==0);
err_code = fds_read();
// Start execution.
NRF_LOG_INFO("Heart Rate Sensor example started.");
application_timers_start();
advertising_start(erase_bonds);
//err_code = fds_test_find_and_delete();
// Enter main loop.
for (;;)
power_manage();
Please suggest how to read/write in same location without creating new record.
here is my debug output please check
<info> app: Writing Record ID = 2 <info> app: Start searching... <info> app: Found Record ID = 1 <info> app: Data = <info> app: 0 <info> app: A2 <info> app: A3 <info> app: A4 <info> app: 22 <info> app: 2D <info> app: C <info> app: 20 <info> app: Found Record ID = 2 <info> app: Data = <info> app: Heart Rate Sensor example started. <info> app: Fast advertising. <info> app: Writing Record ID = 3 <info> app: Start searching... <info> app: Found Record ID = 1 <info> app: Data = <info> app: 0 <info> app: A2 <info> app: A3 <info> app: A4 <info> app: 22 <info> app: 2D <info> app: C <info> app: 20 <info> app: Found Record ID = 2 <info> app: Data = <info> app: Found Record ID = 3 <info> app: Data = <info> app: Heart Rate Sensor example started. <info> app: Fast advertising. <info> app: Writing Record ID = 4 <info> app: Start searching... <info> app: Found Record ID = 1 <info> app: Data = <info> app: 0 <info> app: A2 <info> app: A3 <info> app: A4 <info> app: 22 <info> app: 2D <info> app: C <info> app: 20 <info> app: Found Record ID = 2 <info> app: Data = <info> app: Found Record ID = 3 <info> app: Data = <info> app: Found Record ID = 4 <info> app: Data = <info> app: Heart Rate Sensor example started. <info> app: Fast advertising.
Waiting for your valuable response.
Rohit
