How to Write flash , Read flash and delete flash from one location only.
Hello All,
I am working on the Nrf52810 board with sdk 14.2.
I have implemented the read ,write , delete feature in my code.
Now it is creating new entry for repeating/creating new record read write function each .
I wanted to read / write / delete in same location or (restrict in one location)
Here is my mainc file please check below.
 * Copyright (c) 2014 - 2017, Nordic Semiconductor ASA
 * All rights reserved.
/** @example examples/ble_peripheral/ble_app_hrs/main.c
 * @brief Heart Rate Service Sample Application main file.
 * This file contains the source code for a sample application using the Heart Rate service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_sdm.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "sensorsim.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "ble_conn_state.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/***  Used for testing FDS ***/
static volatile uint8_t write_flag_fds_test = 0;
#define FILE_ID_FDS_TEST     0x1111
#define REC_KEY_FDS_TEST     0x2222
#define DEVICE_NAME                         "Nordic_HRM"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                   "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                    300                                     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS          180                                     /**< The advertising timeout in units of seconds. */
#define APP_BLE_CONN_CFG_TAG                1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO               3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define BATTERY_LEVEL_MEAS_INTERVAL         APP_TIMER_TICKS(2000)                   /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL                   81                                      /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                   100                                     /**< Maximum simulated 7battery level. */
#define BATTERY_LEVEL_INCREMENT             1                                       /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL            APP_TIMER_TICKS(1000)                   /**< Heart rate measurement interval (ticks). */
#define MIN_HEART_RATE                      140                                     /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE                      300                                     /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT                10                                      /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL                APP_TIMER_TICKS(300)                    /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL                     100                                     /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL                     500                                     /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT               1                                       /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL    APP_TIMER_TICKS(5000)                   /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL                   MSEC_TO_UNITS(400, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.4 seconds). */
#define MAX_CONN_INTERVAL                   MSEC_TO_UNITS(650, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (0.65 second). */
#define SLAVE_LATENCY                       0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                    MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY      APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT        3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                      1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                      0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                      0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                  0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES           BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                       0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE              7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE              16                                      /**< Maximum encryption key size. */
#define DEAD_BEEF                           0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define APP_FEATURE_NOT_SUPPORTED           BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2    /**< Reply when unsupported features are requested. */
BLE_HRS_DEF(m_hrs);                                                 /**< Heart rate service instance. */
BLE_BAS_DEF(m_bas);                                                 /**< Structure used to identify the battery service. */
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
APP_TIMER_DEF(m_battery_timer_id);                                  /**< Battery timer. */
APP_TIMER_DEF(m_heart_rate_timer_id);                               /**< Heart rate measurement timer. */
APP_TIMER_DEF(m_rr_interval_timer_id);                              /**< RR interval timer. */
APP_TIMER_DEF(m_sensor_contact_timer_id);                           /**< Sensor contact detected timer. */
static uint16_t m_conn_handle         = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static bool     m_rr_interval_enabled = true;                       /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t   m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t   m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t   m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
static ble_uuid_t m_adv_uuids[] =                                   /**< Universally unique service identifiers. */
    {BLE_UUID_HEART_RATE_SERVICE,           BLE_UUID_TYPE_BLE},
    {BLE_UUID_BATTERY_SERVICE,              BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE,   BLE_UUID_TYPE_BLE}
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    ret_code_t err_code;
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
void advertising_start(bool erase_bonds)
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling File Data Storage events.
 * @param[in] p_evt  Peer Manager event.
 * @param[in] cmd
static void fds_evt_handler(fds_evt_t const * const p_evt)
    if (p_evt->id == FDS_EVT_GC)
        NRF_LOG_DEBUG("GC completed\n");
/**@brief Function for handling Peer Manager events.
static void pm_evt_handler(pm_evt_t const * p_evt)
    switch (p_evt->evt_id)
        case PM_EVT_BONDED_PEER_CONNECTED:
            NRF_LOG_INFO("Connected to a previously bonded device.");
        } break;
        case PM_EVT_CONN_SEC_SUCCEEDED:
            NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
                         ble_conn_state_role(p_evt->conn_handle),
                         p_evt->conn_handle,
                         p_evt->params.conn_sec_succeeded.procedure);
        } break;
        case PM_EVT_CONN_SEC_FAILED:
            /* Often, when securing fails, it shouldn't be restarted, for security reasons.
             * Other times, it can be restarted directly.
             * Sometimes it can be restarted, but only after changing some Security Parameters.
             * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
             * Sometimes it is impossible, to secure the link, or the peer device does not support it.
             * How to handle this error is highly application dependent. */
        } break;
        case PM_EVT_CONN_SEC_CONFIG_REQ:
            // Reject pairing request from an already bonded peer.
            pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
            pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
        } break;
        case PM_EVT_STORAGE_FULL:
            // Run garbage collection on the flash.
            err_code = fds_gc();
            if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                // Retry.
        } break;
            NRF_LOG_DEBUG("PM_EVT_PEERS_DELETE_SUCCEEDED");
            advertising_start(false);
        } break;
        case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            // The local database has likely changed, send service changed indications.
            pm_local_database_has_changed();
        } break;
        case PM_EVT_PEER_DATA_UPDATE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
        } break;
        case PM_EVT_PEER_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
        } break;
        case PM_EVT_PEERS_DELETE_FAILED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
        } break;
        case PM_EVT_ERROR_UNEXPECTED:
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
        } break;
        case PM_EVT_CONN_SEC_START:
        case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
        case PM_EVT_PEER_DELETE_SUCCEEDED:
        case PM_EVT_LOCAL_DB_CACHE_APPLIED:
        case PM_EVT_SERVICE_CHANGED_IND_SENT:
        case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void)
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Function for handling the Heart rate measurement timer timeout.
 * @details This function will be called each time the heart rate measurement timer expires.
 *          It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(void * p_context)
    static uint32_t cnt = 0;
    uint16_t        heart_rate;
    heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    cnt++;
    err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
    // Disable RR Interval recording every third heart rate measurement.
    // NOTE: An application will normally not do this. It is done here just for testing generation
    // of messages without RR Interval measurements.
    m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer timeout.
 * @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(void * p_context)
    if (m_rr_interval_enabled)
        uint16_t rr_interval;
        rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                  &m_rr_interval_sim_cfg);
        ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer timeout.
 * @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(void * p_context)
    static bool sensor_contact_detected = false;
    sensor_contact_detected = !sensor_contact_detected;
    ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    err_code = app_timer_init();
    // Create timers.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
    err_code = app_timer_create(&m_heart_rate_timer_id,
                                heart_rate_meas_timeout_handler);
    err_code = app_timer_create(&m_rr_interval_timer_id,
                                rr_interval_timeout_handler);
    err_code = app_timer_create(&m_sensor_contact_timer_id,
                                sensor_contact_detected_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
/**@brief GATT module event handler.
static void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
                     p_evt->conn_handle,
                     p_evt->params.att_mtu_effective);
    ble_hrs_on_gatt_evt(&m_hrs, p_evt);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
 * @details Initialize the Heart Rate, Battery and Device Information services.
    ble_hrs_init_t hrs_init;
    ble_bas_init_t bas_init;
    ble_dis_init_t dis_init;
    uint8_t        body_sensor_location;
    // Initialize Heart Rate Service.
    body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
    err_code = ble_dis_init(&dis_init);
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
    m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
    m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
    m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
    m_heart_rate_sim_cfg.start_at_max = false;
    sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
    m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
    m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
    m_rr_interval_sim_cfg.start_at_max = false;
    sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
    // Start application timers.
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
    err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
    APP_ERROR_HANDLER(nrf_error);
    cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
    // Prepare wakeup buttons.
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected.");
            NRF_LOG_INFO("Disconnected, reason %d.",
                          p_ble_evt->evt.gap_evt.params.disconnected.reason);
#ifndef S140
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
        case BLE_EVT_USER_MEM_REQUEST:
            err_code = sd_ble_user_mem_reply(m_conn_handle, NULL);
        case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
            ble_gatts_evt_rw_authorize_request_t  req;
            ble_gatts_rw_authorize_reply_params_t auth_reply;
            req = p_ble_evt->evt.gatts_evt.params.authorize_request;
            if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                    (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                    if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                        auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                    auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                    err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
                                                               &auth_reply);
        } break;
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in]   event   Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
    err_code = fds_register(fds_evt_handler);
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
/**@brief Function for the Power manager.
static void power_manage(void)
    ret_code_t err_code = sd_app_evt_wait();
static void my_fds_evt_handler(fds_evt_t const * const p_fds_evt)
    switch (p_fds_evt->id)
        case FDS_EVT_INIT:
            if (p_fds_evt->result != FDS_SUCCESS)
                // Initialization failed.
				case FDS_EVT_WRITE:
						if (p_fds_evt->result == FDS_SUCCESS)
							write_flag_fds_test=1;
static ret_code_t fds_test_write(void)
		//static uint32_t const m_deadbeef[2] = {0xDEADBEEF,0xBAADF00D};
		static uint8_t const m_deadbeef[8] = {0x00,0xA2,0xA3,0xA4,0x22,45,12,32};
		fds_record_t        record;
		fds_record_desc_t   record_desc;
		// Set up data.
		// Set up record.
		record.file_id              = FILE_ID_FDS_TEST;
		record.key              		= REC_KEY_FDS_TEST;
		record.data.p_data       = &m_deadbeef;
		//record.data.length_words   = sizeof(m_deadbeef)/sizeof(uint32_t);
		record.data.length_words   = sizeof(m_deadbeef)/sizeof(uint8_t);
                                record_desc.record_id =1;
		ret_code_t ret = fds_record_write(&record_desc, &record);
		if (ret != FDS_SUCCESS)
				return ret;
		 NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
		return NRF_SUCCESS;
static ret_code_t fds_read(void)
		fds_flash_record_t  flash_record;
		fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
		//uint32_t *data;
		uint8_t *data;
		uint32_t err_code;
		NRF_LOG_INFO("Start searching... \r\n");
		// Loop until all records with the given key and file ID have been found.
		//while (fds_record_find(FILE_ID_FDS_TEST, REC_KEY_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
                while (fds_record_find_in_file(FILE_ID_FDS_TEST, &record_desc, &ftok) == FDS_SUCCESS)
				err_code = fds_record_open(&record_desc, &flash_record);
				if ( err_code != FDS_SUCCESS)
					return err_code;
				NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
				NRF_LOG_INFO("Data = ");
				//data = (uint32_t *) flash_record.p_data;
				data = (uint8_t *) flash_record.p_data;
//				for (uint8_t i=0;i<flash_record.p_header->length_words;i++)
//					NRF_LOG_INFO("0x%8x ",data[i]);
//				NRF_LOG_INFO("\r\n");
                                if(record_desc.record_id == 1)
                                        NRF_LOG_INFO("%x",data[i]);
                                  //NRF_LOG_INFO("0x%8x ",data[2]);
                                //fds_record_find_in_file()
				// Access the record through the flash_record structure.
				// Close the record when done.
				err_code = fds_record_close(&record_desc);
				if (err_code != FDS_SUCCESS)
					return err_code;
		return NRF_SUCCESS;
static ret_code_t fds_test_find_and_delete (void)
		fds_find_token_t    ftok;
		ftok.page=0;
		ftok.p_addr=NULL;
		// Loop and find records with same ID and rec key and mark them as deleted.
			fds_record_delete(&record_desc);
			NRF_LOG_INFO("Deleted record ID: %d \r\n",record_desc.record_id);
		// call the garbage collector to empty them, don't need to do this all the time, this is just for demonstration
		ret_code_t ret = fds_gc();
				return ret;
		return NRF_SUCCESS;
static ret_code_t fds_test_init (void)
		ret_code_t ret = fds_register(my_fds_evt_handler);
					return ret;
		ret = fds_init();
				return ret;
		return NRF_SUCCESS;
/**@brief Function for application main entry.
    uint32_t err_code;
    bool erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    sensor_simulator_init();
    conn_params_init();
    peer_manager_init();
		// Test FDS:
		err_code =fds_test_init();
//		err_code = fds_test_find_and_delete();
//		APP_ERROR_CHECK(err_code);
		err_code =fds_test_write();
		//wait until the write is finished.
		while (write_flag_fds_test==0);
		err_code = fds_read();
    // Start execution.
    NRF_LOG_INFO("Heart Rate Sensor example started.");
    application_timers_start();
    advertising_start(erase_bonds);
//err_code = fds_test_find_and_delete();
    // Enter main loop.
    for (;;)
            power_manage();
Please suggest how to read/write in same location without creating new record.
here is my debug output please check
<info> app: Writing Record ID = 2
<info> app: Start searching...
<info> app: Found Record ID = 1
<info> app: Data =
<info> app: 0
<info> app: A2
<info> app: A3
<info> app: A4
<info> app: 22
<info> app: 2D
<info> app: C
<info> app: 20
<info> app: Found Record ID = 2
<info> app: Data =
<info> app: Heart Rate Sensor example started.
<info> app: Fast advertising.
<info> app: Writing Record ID = 3
<info> app: Data =
<info> app: 0
<info> app: A2
<info> app: A3
<info> app: A4
<info> app: 22
<info> app: 2D
<info> app: C
<info> app: 20
<info> app: Data =
<info> app: Found Record ID = 3
<info> app: Data =
<info> app: Writing Record ID = 4
<info> app: Data =
<info> app: 0
<info> app: A2
<info> app: A3
<info> app: A4
<info> app: 22
<info> app: 2D
<info> app: C
<info> app: 20
<info> app: Data =
<info> app: Data =
<info> app: Found Record ID = 4
<info> app: Data =
Waiting for your valuable response.
Rohit
    Yes With, FDS it goes like this:
    • Every time you write a new record, you get a new record.
    • Every time you delete a record, you mark it as dirty.
    • Every time you update a record, you actually write a new record with updated data, and mark the old as dirty.
    • Every time you run garbage collection, dirty records are deleted.
    This is how FDS works, and the reason is that it makes sense to use this approach for a flash file system (given the limitations of physical flash memory).
  • I have modified my main.c please check
    i wanted to read /write 2 element of array as i have declear in main.c
    uint8_t m_deadbeef[2] = {54,12}
    But i can only access one element. and select element is showing 0.
    How i can access both the element .I have tried different methods but it is not working
    Please suggest any modification is required or any other issue is there..
    Here my New main.c file
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble.h"
    #include "fds.h"
    uint8_t  array_update[8] = {1,2,3,4,5,6,7,8};
    uint8_t m_deadbeef[2] = {54,12};//{8,45,69,44,22,45,12,32};
    uint8_t *temp_data;
            delete_bonds();
     * @param[in] cmd
            } break;
                             p_evt->conn_handle,
            } break;
            } break;
            } break;
                    // Retry.
            } break;
            } break;
            } break;
                // Assert.
            } break;
                // Assert.
            } break;
                // Assert.
            } break;
                // Assert.
            } break;
        cnt++;
        // Create timers.
                         p_evt->conn_handle,
                sleep_mode_enter();
    #ifndef S140
            } break;
        &auth_reply);
            } break;
        switch (event)
                sleep_mode_enter();
            case FDS_EVT_INIT:
    				case FDS_EVT_WRITE:
    //		static uint8_t const m_deadbeef[8] = {0x00,0xA2,0xA3,0xA4,0x22,45,12,32};
    		// Set up data.
    //for (int x = 0; x<8;x++)
    //  m_deadbeef[x] = array_update[x];
    		// Set up record.
    temp_data = m_deadbeef[0];
    		record.data.p_data       = &temp_data;
    				return ret;
    		return NRF_SUCCESS;
    		//uint32_t *data;
    		uint8_t *data;
    		uint32_t err_code;
    					return err_code;
    					NRF_LOG_INFO("0x%8d ",(data[i]));
    //                                data[2]= 45;
    //                                NRF_LOG_INFO("0x%8x ",data[2]);
    //                                NRF_LOG_INFO("0x%8x ",data[3]);
    //                                if(record_desc.record_id == 1)
    //                                        NRF_LOG_INFO("%x",data[i]);
    //                                  //NRF_LOG_INFO("0x%8x ",data[2]);
    					return err_code;
    		return NRF_SUCCESS;
    		ftok.page=0;
    		ftok.p_addr=NULL;
    				return ret;
    		return NRF_SUCCESS;
    					return ret;
    		ret = fds_init();
    				return ret;
    		return NRF_SUCCESS;
        uint32_t err_code;
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
    		// Test FDS:
        // Start execution.
        // Enter main loop.
        for (;;)
                power_manage();
    my output window
    <info> app: Data =
    <info> app: 0x 54
    <info> app: 0x 0
    <info> app:
  • Hi Rohit,
    There are two things I want to comment on here. First, the reason you get only the first element is that you are not doing what I suspect you meant to since you are not using pointers in a sensible way.
    You have:
    uint8_t *temp_data;
    On line 1072 you set the temp_data to the value of m_deadbeef[0]. So this means that the pointer temp_data  (which should hold an address), now instead holds the value 0x54. Then on line 1074 you do:
    So this means that you set the pointer to be written (record.data.p_data) to the address of the pointer temp_data. And since this pointer actually now is not a real pointer, but hold a data byte, this is the first byte that gets written. And the rest of the data that gets written is whatever comes in memory after that.
    There is also another problem: I think there is a misunderstanding with regard to word size here. Your m_deadbeef is two bytes long, but an FDS word is 4 bytes long. However, when you write the data in fds_test_write you specify that the length is sizeof(m_deadbeef)/sizeof(uint8_t), which is 2/1 = 2. And that corresponds to 8 bytes. So you write a record of 8 bytes, where the first two bytes are 54, 12, and the last six are whatever happens to be in memory after that.
    Einar
  • Hi Einar,
    Thanks for your correction and clarification on the FDS as i have misunderstood.
    I will work on your suggestion and let you know updates..
    Rohit
