TWI-master integrate with Custom Service Code - NRF52 - SDK15.3.0
i'm using,BMD-301(NRF52832),SDK15.3.0
////////////////////////.......Issue-1..............
When i upload "twi_master_using_nrf_twi_mngr" peripheral example
i'm getting this error in log
TWI master example started.
<error> app: Fatal error
<warning> app: System reset
Please help me to solve it.
////////////////////////.......Issue-2..............
another thing is
i have developed custom service code using template
now as per my application i have to do i2c communication between nrf52832 and stm32 .
nrf52832 will be i2c(twi)-master.
so for that i need to add i2c-master (twi-master) functionality in nrf52832.
so how i can able to add or merge twi-master.
what config need to change in sdkconfig.h
what code need to add in custom service code.
please help me.
thanks.
    If you define DEBUG you should be able to find in app_error_fault_handler() what line of code is causing the error.
    You need to add all twi configuration you can find the in the sdk_config.h twi examples in the SDK to your project. As an example I suggest to look at \twi_scanner and \twi_sensor examples.
    Kenneth
  • Hello Kenneth,
    now code is working but when use
    following code to transmit data but it's stuck to  there and not transmit anything
    uint32_t err_code;
    uint8_t tx_data[] = {'a', 'b', 'c', 'd', 'e'};
    const nrf_drv_twi_t twi = NRF_DRV_TWI_INSTANCE(0);
    err_code = nrf_drv_twi_init(&twi, NULL, NULL);
    nrf_drv_twi_enable(&twi);
    err_code = nrf_drv_twi_tx(&twi, SLAVE_ADDRESS, tx_data, sizeof(tx_data), false);
    it stuck at
    err_code = nrf_drv_twi_tx(&twi,0x08, tx_data, sizeof(tx_data), false);
    i'm using this example
