static void pm_evt_handler(pm_evt_t const * p_evt)
ret_code_t err_code;
switch (p_evt->evt_id)
case PM_EVT_BONDED_PEER_CONNECTED:
NRF_LOG_INFO("Connected to a previously bonded device.");
} break;
case PM_EVT_CONN_SEC_SUCCEEDED:
NRF_LOG_INFO("Connection secured: role: %d, conn_handle: 0x%x, procedure: %d.",
ble_conn_state_role(p_evt->conn_handle),
p_evt->conn_handle,
p_evt->params.conn_sec_succeeded.procedure);
} break;
case PM_EVT_CONN_SEC_FAILED:
/* Often, when securing fails, it shouldn't be restarted, for security reasons.
* Other times, it can be restarted directly.
* Sometimes it can be restarted, but only after changing some Security Parameters.
* Sometimes, it cannot be restarted until the link is disconnected and reconnected.
* Sometimes it is impossible, to secure the link, or the peer device does not support it.
* How to handle this error is highly application dependent. */
} break;
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
} break;
case PM_EVT_STORAGE_FULL:
// Run garbage collection on the flash.
err_code = fds_gc();
if (err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
// Retry.
} break;
advertising_start(false);
} break;
case PM_EVT_PEER_DATA_UPDATE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
} break;
case PM_EVT_PEER_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
} break;
case PM_EVT_PEERS_DELETE_FAILED:
// Assert.
APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
} break;
case PM_EVT_ERROR_UNEXPECTED:
// Assert.
APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
} break;
case PM_EVT_CONN_SEC_START:
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
case PM_EVT_PEER_DELETE_SUCCEEDED:
case PM_EVT_LOCAL_DB_CACHE_APPLIED:
case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
// This can happen when the local DB has changed.
case PM_EVT_SERVICE_CHANGED_IND_SENT:
case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init()
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
