ble_app_hrs_freertos example questions
Sorry for asking, maybe stupid questions, but looking at ble_app_hrs_freertos example in SDK 16.0.0 cant get through:
1.to documentation  ble_conn_params_init_t. first_conn_params_update_delay  and conn_params_update_delay   should be:  (in number of timer ticks)
So I can’t get it how 5000 ms and 30000ms (as per #define statements) become 5000 and 30000 ticks when RTC frequency as per sdk_config.h for this example is 32768 Hz? What I’m missing?
main.c:
#define FIRST_CONN_PARAMS_UPDATE_DELAY      5000           /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY       30000          /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
static void conn_params_init(void){
    cp_init.next_conn_params_update_delay  = NEXT_CONN_PARAMS_UPDATE_DELAY;
sdk_config.h:
// <0=> 32768 Hz
// <1=> 16384 Hz
 #define APP_TIMER_CONFIG_RTC_FREQUENCY 0
2. %s specificator for nrf_log_* doesn’t work in ble_app_hrs_freertos
I inserted those couple lines of code just before vTaskStartScheduler:
NRF_LOG_INFO("HRS FreeRTOS example started. 2");
 uint8_t bc_buf2[] = {'7','5','3','\0'};
 NRF_LOG_INFO("\n Received BC2: %s \n", bc_buf2); //WTF doesnt print %s
 uint32_t uint2 = 223377;
 NRF_LOG_INFO("\n Received ui32: %d \n", uint2); // %d  is Ok
    // Start FreeRTOS scheduler.
    vTaskStartScheduler();
And cant get the correct result neither on UART nor RTT transport:
Tera term output:
<info> app: HRS FreeRTOS example started. 2
<info> app:
 Received BC2: Ào
<info> app:
 Received ui32: 223377
<info> app: Fast advertising.
JLink RTT Viewer output:
00> <info> app: HRS FreeRTOS example started. 2
00>
00> <info> app:
00>  Received BC2: Ào
00>
00> <info> app:
00>  Received ui32: 223377
00> <info> app: Fast advertising.
And I tried almost all combination for the type of the buffer or casting it in the NRF_LOG_INFO statement
3. In sdk_config.h APP_TIMER_CONFIG_RTC_FREQUENCY 1 (template ) vs 0 (hrs_freertos)  - what is the objectives to use once 0 (32768 Hz) vs  1 (16384 Hz) ?
Thanks
  • First of all, the FreeRTOS is not running on app_timer.c but instead running on app_timer_freertos.c.
    Which means that its timings are not dictated by sdk_config.h but instead the define in FreeRTOSConfig.h -> configTICK_RATE_HZ
    You are not totally wrong though.
    We cannot get the granualarity of 1ms exactly using a 32768 Hz timer. Since configTICK_RATE_HZ = 1024Hz, one tick is equal 1/1024 seconds, which = 0.976ms.
    For realtime systems that need that can of granularity you should use portTICK_PERIOD_MS(time_in_ms) as below
    #define FIRST_CONN_PARAMS_UPDATE_DELAY      portTICK_PERIOD_MS (5000)           /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY       portTICK_PERIOD_MS (30000)          /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    Even though this is a bit harmless in current conditions, I can see that it could lead to bad results if the user has changed the configTICK_RATE_HZ rate to cause any other tick different than almost 1ms.
    Thanks for lettings us know this.
    2.
    instead of uint8_t define bc_buf2 as char. String literals work with char and not uints
    3.
    This define should be irrelevant in your use case since with freeRTOS you are not using app_timer.c file where the above mentioned define becomes valid.
    Since you should only use app_timer_freertos.c, the value above is not used
  • As this thread was not accepting any Replies until now, I already posted a new Question
    https://devzone.nordicsemi.com/f/nordic-q-a/55460/ble_app_hrs_freertos-2
    which is actually a continuation of this thread. If there is moderator - feel free to merge both if you find it appropriate. Thanks
  • we can continue the discussion in the other thread.
