Board buttons nRF52
HI,
I'm trying to add some functions to my code, and the buttons interaction is one of them. I saw some posts and I think I did exactly like that but I can't get interaction with buttons.
This is my main code.
So, the button functions are at line 696 and 736.
One more thing, if I run the code without that functions, I can connect the phone (with nRFConnect) with the board. But if I add that code, I can't get connection with phone. Buttons don't work too. I don't get any error when compiling and flashing.
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_app_bps_main main.c
 * @ingroup ble_sdk_app_bps
 * @brief Blood Pressure Service Sample Application main file.
 * This file contains the source code for a sample application using the Blood pressure service.
 * This file also contains the code for initializing and using the Battery Service and the Device
 * Information Service. Furthermore, it demonstrates the use of the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_dis.h"
#include "ble_sensor.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   BSP_BOARD_LED_1
#define BUTTON1_LED                     BSP_BOARD_LED_2                         /**< Is on when device is advertising. */
#define BUTTON2_LED                     BSP_BOARD_LED_3
#define BUTTON_DISCONNECT               BSP_BOARD_BUTTON_1
#define BUTTON_DISCONNECT3              BSP_BUTTON_3
#define DEVICE_NAME                     "Nordic_BPS"                            /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                   /**< Manufacturer. Will be passed to Device Information Service. */
#define MODEL_NUM                       "NS-BPS-EXAMPLE"                        /**< Model number. Will be passed to Device Information Service. */
#define MANUFACTURER_ID                 0x1122334455                            /**< Manufacturer ID, part of System ID. Will be passed to Device Information Service. */
#define ORG_UNIQUE_ID                   0x667788                                /**< Organizational Unique ID, part of System ID. Will be passed to Device Information Service. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                40                                      /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
#define APP_ADV_DURATION                18000                                   /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(500, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(1000, UNIT_1_25_MS)       /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                   0                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                   /**< Time from initiating event (connect or start of indication) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                  /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                       /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                       /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                       /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                       /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                    /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                       /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                       /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                      /**< Maximum encryption key size. */
#define MY_TIMER_INTERVAL     APP_TIMER_TICKS(2000)
#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
/**@brief Structure for a simulated blood pressure measurment. An instance of this struct is
          filled out before sending a notification to the peer with ble_bps_measurement_send.
APP_TIMER_DEF(my_timer_id);                                      /**< Battery timer. */
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                 /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                     /**< Advertising module instance. */
static uint16_t             m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
static ble_uuid_t m_adv_uuids[] =                                       /**< Universally unique service identifiers. */
    {SENSOR_UUID_SERVICE, BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
static void leds_init(void)
static void advertising_start(bool erase_bonds);
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t err_code;
    bool       is_indication_enabled;
    pm_handler_on_pm_evt(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
        case PM_EVT_CONN_SEC_SUCCEEDED:
            advertising_start(false);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
uint8_t vread = 0;
static void mytimer_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    ret_code_t err_code=NRF_SUCCESS;
    //err_code = ble_sensor_read_update(vread++);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    // Initialize timer module.
    err_code = app_timer_init();
    // Create timers.
    err_code = app_timer_create(&my_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                mytimer_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    uint32_t                err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_GENERIC_HID);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    APP_ERROR_HANDLER(nrf_error);
 * @details Initialize the Blood Pressure, Battery, and Device Information services.
    uint32_t           err_code;
    //X/ble_bps_init_t     bps_init;
    ble_dis_init_t     dis_init;
    ble_dis_sys_id_t   sys_id;
    // Initialize Queued Write Module
    err_code = ble_sensor_init();
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
    ble_srv_ascii_to_utf8(&dis_init.model_num_str, MODEL_NUM);
    sys_id.manufacturer_id            = MANUFACTURER_ID;
    sys_id.organizationally_unique_id = ORG_UNIQUE_ID;
    dis_init.p_sys_id                 = &sys_id;
    dis_init.dis_char_rd_sec = SEC_OPEN;
    err_code = ble_dis_init(&dis_init);
/**@brief Function for starting application timers.
static void application_timers_start(void)
    // Start application timers.
    err_code = app_timer_start(my_timer_id, MY_TIMER_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameter events.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail configuration parameter, but instead we use the
 *                event handler mechanism to demonstrate its use.
 * @param[in]   p_evt   Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
    ble_conn_params_init_t connection_params_init;
    memset(&connection_params_init, 0, sizeof(connection_params_init));
    connection_params_init.p_conn_params                  = NULL;
    connection_params_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY;
    connection_params_init.next_conn_params_update_delay  = NEXT_CONN_PARAMS_UPDATE_DELAY;
    connection_params_init.max_conn_params_update_count   = MAX_CONN_PARAMS_UPDATE_COUNT;
    connection_params_init.start_on_notify_cccd_handle    = BLE_GATT_HANDLE_INVALID;
    connection_params_init.disconnect_on_fail             = false;
    connection_params_init.evt_handler                    = on_conn_params_evt;
    connection_params_init.error_handler                  = conn_params_error_handler;
    err_code = ble_conn_params_init(&connection_params_init);
    ret_code_t err_code = sd_power_system_off();
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising");
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    ret_code_t err_code = NRF_SUCCESS;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            bsp_board_led_on(CONNECTED_LED);
            bsp_board_led_off(ADVERTISING_LED);
             NRF_LOG_INFO("Disconnected");
             bsp_board_led_off(CONNECTED_LED);
             bsp_board_led_on(ADVERTISING_LED);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in] event  Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
        case BSP_EVENT_WHITELIST_OFF:
        case BSP_EVENT_KEY_0:
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
static void log_init(void)
        nrf_pwr_mgmt_run();
    if (erase_bonds == true)
        delete_bonds();
        // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
    else{
        ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
        case BUTTON_DISCONNECT:
            if (button_action == APP_BUTTON_PUSH)
                /* Button pushed */
                bsp_board_led_on(BUTTON1_LED);
                /* APP_BUTTON_RELEASE */
        case BUTTON_DISCONNECT3:
                /* Button pushed */
                bsp_board_led_on(BUTTON2_LED);
static void buttons_init(void)
   // The array must be static because a pointer to it will be saved in the button library.
    static app_button_cfg_t buttons[] =
        {BUTTON_DISCONNECT, true, BUTTON_PULL, button_evt_handler},
        {BUTTON_DISCONNECT3, true, BUTTON_PULL, button_evt_handler},
    ret_code_t err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
    /* You can call this other places as well, for instance when you get BLE_GAP_EVT_CONNECTED */
    err_code = app_button_enable();
/**@brief Function for application main entry.
    bool     erase_bonds;
    // Initialize.
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    leds_init();
    buttons_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    NRF_LOG_INFO("Joao Example");
    application_timers_start();
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
        idle_state_handle();
With my best.
