Power Consumption issue
Hi all,
we are using nRF52810 and SDK 15.3.0
Project is based on central and peripheral concept.
we are facing issue with the peripheral BLE power consumption.
In the attached peripheral code, Application timer is set for every 15 minutes and in timer interrupt we are sending 40 bytes payload to central BLE and  peripheral BLE to goes to System On sleep mode.
In System ON sleep mode peripheral BLE consumes around 600uA.
we require power consumption during System ON sleep mode should be less than 10uA.
Kindly give us suggestion to reduce the power consumption .
Thanks and regards
venu
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "nrf_drv_timer.h"
#include "bsp.h"
#include "app_error.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Yogesh_Uart"//"Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                18000                                    /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(2000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define INTERVAL                        APP_TIMER_TICKS(30000)                      // data trans interval
#define data_INTERVAL                   APP_TIMER_TICKS(5000)
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
APP_TIMER_DEF(timer_id);
APP_TIMER_DEF(data_timer_id);
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);
//static void timers_init(void);
static void timeout_handler(void * p_context);
static void data_timeout_handler(void * p_context);                                                 /**< Advertising module instance. */
unsigned int count = 0;
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
    // Create battery timer.
    err_code = app_timer_create(&timer_id,
                                APP_TIMER_MODE_REPEATED,
                                timeout_handler);
     err_code = app_timer_create(&data_timer_id,
                                data_timeout_handler);
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
    unsigned int length = 0;
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
      UNUSED_PARAMETER(p_context);
      advertising_start();
      length=26;
      memcpy(data_array,"Reading Serial Number...\r\n",length);
      ble_nus_data_send(&m_nus, data_array,  &length, m_conn_handle);
      nrf_delay_ms(2000);
      sd_ble_gap_adv_stop(m_advertising.adv_handle);
      app_timer_stop(data_timer_id);
/**@brief Function for handling errors from the Connection Parameters module.
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            app_timer_start(data_timer_id,data_INTERVAL, NULL);
            NRF_LOG_INFO("Disconnected");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
   // if(adv  == 0)
       // event = BSP_EVENT_DISCONNECT;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
        nrf_pwr_mgmt_run();
 void advertising_start(void)
/**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
  //  buttons_leds_init(&erase_bonds);
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    app_timer_start(timer_id,INTERVAL, NULL);
    // Start execution.
    // Enter main loop.
    //advertising_start();
	/************change******************/
 nrf_gpio_pin_dir_set(4,NRF_GPIO_PIN_DIR_OUTPUT);
 nrf_gpio_pin_dir_set(6,NRF_GPIO_PIN_DIR_OUTPUT);
  nrf_gpio_pin_dir_set(9,NRF_GPIO_PIN_DIR_OUTPUT);
 nrf_gpio_pin_dir_set(10,NRF_GPIO_PIN_DIR_OUTPUT);
  nrf_gpio_pin_dir_set(12,NRF_GPIO_PIN_DIR_OUTPUT);
 nrf_gpio_pin_dir_set(14,NRF_GPIO_PIN_DIR_OUTPUT);
  nrf_gpio_pin_dir_set(15,NRF_GPIO_PIN_DIR_OUTPUT);
 nrf_gpio_pin_dir_set(16,NRF_GPIO_PIN_DIR_OUTPUT);
  nrf_gpio_pin_dir_set(18,NRF_GPIO_PIN_DIR_OUTPUT);
 nrf_gpio_pin_dir_set(20,NRF_GPIO_PIN_DIR_OUTPUT);
  nrf_gpio_pin_dir_set(25,NRF_GPIO_PIN_DIR_OUTPUT);
 nrf_gpio_pin_dir_set(28,NRF_GPIO_PIN_DIR_OUTPUT);
    nrf_gpio_pin_dir_set(30,NRF_GPIO_PIN_DIR_OUTPUT);
//output high
     nrf_gpio_pin_set(4);
    nrf_gpio_pin_set(6);
    nrf_gpio_pin_set(9);
    nrf_gpio_pin_set(10);
//output low
    nrf_gpio_pin_clear(12);
    nrf_gpio_pin_clear(14);
    nrf_gpio_pin_clear(15);
    nrf_gpio_pin_clear(16);
    nrf_gpio_pin_clear(18);
    nrf_gpio_pin_clear(20);
    nrf_gpio_pin_clear(25);
    nrf_gpio_pin_clear(28);
    nrf_gpio_pin_clear(30);
// nrfx_uarte_uninit();
//********end*********************/
    for (;;)
             idle_state_handle();
  • I don't know if this applies to the nrf5 SDK but try and disable UART. In the boards I have tried with the nRFConnect SDK (Using Zephyr), 600uA is generally an indicator of that.
  • Correct , this current draw indicates that the UART isn't disabled properly. Please disable the UART peripheral before going to sleep in your application.
  • HI Dears , Pls help to verify these files and advise changes tks Gaurav
    /** @file
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "bsp.h"
    #define DEVICE_NAME                     "Rahul_Uart"//"Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
                                    timeout_handler);
        uint32_t                err_code;
            uint32_t err_code;
                do
        uint32_t           err_code;
        // Initialize NUS.
        uint32_t err_code;
          length=26;
          nrf_delay_ms(2000);
        uint32_t err_code;
                sleep_mode_enter();
        uint32_t err_code;
            } break;
        uint32_t err_code;
       // if(adv  == 0)
        switch (event)
                sleep_mode_enter();
        uint32_t       err_code;
                index++;
                    if (index > 1)
                        do
                    index = 0;
    #else
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           err_code);
            nrf_pwr_mgmt_run();
        bool erase_bonds;
        // Initialize.
       uart_init();
        log_init();
        timers_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        // Enter main loop.
        for (;;)
    //output high
    //output low
     * Copyright (c) 2015 - 2019, Nordic Semiconductor ASA
    #include <nrfx.h>
    #if NRFX_CHECK(NRFX_UARTE_ENABLED)
    #if !(NRFX_CHECK(NRFX_UARTE0_ENABLED) || \
          NRFX_CHECK(NRFX_UARTE1_ENABLED) || \
          NRFX_CHECK(NRFX_UARTE2_ENABLED) || \
          NRFX_CHECK(NRFX_UARTE3_ENABLED))
    #error "No enabled UARTE instances. Check <nrfx_config.h>."
    #include <nrfx_uarte.h>
    #include "prs/nrfx_prs.h"
    #include <hal/nrf_gpio.h>
    #define NRFX_LOG_MODULE UARTE
    #include <nrfx_log.h>
    #define EVT_TO_STR(event) \
        (event == NRF_UARTE_EVENT_ERROR ? "NRF_UARTE_EVENT_ERROR" : \
                                          "UNKNOWN EVENT")
    #define UARTEX_LENGTH_VALIDATE(peripheral, drv_inst_idx, len1, len2)     \
        (((drv_inst_idx) == NRFX_CONCAT_3(NRFX_, peripheral, _INST_IDX)) && \
         NRFX_EASYDMA_LENGTH_VALIDATE(peripheral, len1, len2))
    #if NRFX_CHECK(NRFX_UARTE0_ENABLED)
    #define UARTE0_LENGTH_VALIDATE(...)  UARTEX_LENGTH_VALIDATE(UARTE0, __VA_ARGS__)
    #else
    #define UARTE0_LENGTH_VALIDATE(...)  0
    #if NRFX_CHECK(NRFX_UARTE1_ENABLED)
    #define UARTE1_LENGTH_VALIDATE(...)  UARTEX_LENGTH_VALIDATE(UARTE1, __VA_ARGS__)
    #else
    #define UARTE1_LENGTH_VALIDATE(...)  0
    #if NRFX_CHECK(NRFX_UARTE2_ENABLED)
    #define UARTE2_LENGTH_VALIDATE(...)  UARTEX_LENGTH_VALIDATE(UARTE2, __VA_ARGS__)
    #else
    #define UARTE2_LENGTH_VALIDATE(...)  0
    #if NRFX_CHECK(NRFX_UARTE3_ENABLED)
    #define UARTE3_LENGTH_VALIDATE(...)  UARTEX_LENGTH_VALIDATE(UARTE3, __VA_ARGS__)
    #else
    #define UARTE3_LENGTH_VALIDATE(...)  0
    #define UARTE_LENGTH_VALIDATE(drv_inst_idx, length)     \
        (UARTE0_LENGTH_VALIDATE(drv_inst_idx, length, 0) || \
         UARTE1_LENGTH_VALIDATE(drv_inst_idx, length, 0) || \
         UARTE2_LENGTH_VALIDATE(drv_inst_idx, length, 0) || \
         UARTE3_LENGTH_VALIDATE(drv_inst_idx, length, 0))
    typedef struct
        void                     * p_context;
        nrfx_uarte_event_handler_t handler;
        uint8_t            const * p_tx_buffer;
        uint8_t                  * p_rx_buffer;
        uint8_t                  * p_rx_secondary_buffer;
        volatile size_t            tx_buffer_length;
        size_t                     rx_buffer_length;
        size_t                     rx_secondary_buffer_length;
        nrfx_drv_state_t           state;
    } uarte_control_block_t;
    static uarte_control_block_t m_cb[NRFX_UARTE_ENABLED_COUNT];
    static void apply_config(nrfx_uarte_t        const * p_instance,
                             nrfx_uarte_config_t const * p_config)
        if (p_config->pseltxd != NRF_UARTE_PSEL_DISCONNECTED)
            nrf_gpio_pin_set(p_config->pseltxd);
            nrf_gpio_cfg_output(p_config->pseltxd);
        if (p_config->pselrxd != NRF_UARTE_PSEL_DISCONNECTED)
            nrf_gpio_cfg_input(p_config->pselrxd, NRF_GPIO_PIN_NOPULL);
        nrf_uarte_baudrate_set(p_instance->p_reg, p_config->baudrate);
        nrf_uarte_configure(p_instance->p_reg, p_config->parity, p_config->hwfc);
        nrf_uarte_txrx_pins_set(p_instance->p_reg, p_config->pseltxd, p_config->pselrxd);
        if (p_config->hwfc == NRF_UARTE_HWFC_ENABLED)
            if (p_config->pselcts != NRF_UARTE_PSEL_DISCONNECTED)
                nrf_gpio_cfg_input(p_config->pselcts, NRF_GPIO_PIN_NOPULL);
            if (p_config->pselrts != NRF_UARTE_PSEL_DISCONNECTED)
                nrf_gpio_pin_set(p_config->pselrts);
                nrf_gpio_cfg_output(p_config->pselrts);
            nrf_uarte_hwfc_pins_set(p_instance->p_reg, p_config->pselrts, p_config->pselcts);
    static void interrupts_enable(nrfx_uarte_t const * p_instance,
                                  uint8_t              interrupt_priority)
        nrf_uarte_event_clear(p_instance->p_reg, NRF_UARTE_EVENT_ENDRX);
        nrf_uarte_event_clear(p_instance->p_reg, NRF_UARTE_EVENT_ENDTX);
        nrf_uarte_event_clear(p_instance->p_reg, NRF_UARTE_EVENT_ERROR);
        nrf_uarte_event_clear(p_instance->p_reg, NRF_UARTE_EVENT_RXTO);
        nrf_uarte_int_enable(p_instance->p_reg, NRF_UARTE_INT_ENDRX_MASK |
                                                NRF_UARTE_INT_ENDTX_MASK |
                                                NRF_UARTE_INT_ERROR_MASK |
                                                NRF_UARTE_INT_RXTO_MASK);
        NRFX_IRQ_PRIORITY_SET(nrfx_get_irq_number((void *)p_instance->p_reg),
                              interrupt_priority);
        NRFX_IRQ_ENABLE(nrfx_get_irq_number((void *)p_instance->p_reg));
    static void interrupts_disable(nrfx_uarte_t const * p_instance)
        nrf_uarte_int_disable(p_instance->p_reg, NRF_UARTE_INT_ENDRX_MASK |
        NRFX_IRQ_DISABLE(nrfx_get_irq_number((void *)p_instance->p_reg));
    static void pins_to_default(nrfx_uarte_t const * p_instance)
        /* Reset pins to default states */
        uint32_t txd;
        uint32_t rxd;
        uint32_t rts;
        uint32_t cts;
        txd = nrf_uarte_tx_pin_get(p_instance->p_reg);
        rxd = nrf_uarte_rx_pin_get(p_instance->p_reg);
        rts = nrf_uarte_rts_pin_get(p_instance->p_reg);
        cts = nrf_uarte_cts_pin_get(p_instance->p_reg);
        nrf_uarte_txrx_pins_disconnect(p_instance->p_reg);
        nrf_uarte_hwfc_pins_disconnect(p_instance->p_reg);
        if (txd != NRF_UARTE_PSEL_DISCONNECTED)
            nrf_gpio_cfg_default(txd);
        if (rxd != NRF_UARTE_PSEL_DISCONNECTED)
            nrf_gpio_cfg_default(rxd);
        if (cts != NRF_UARTE_PSEL_DISCONNECTED)
            nrf_gpio_cfg_default(cts);
        if (rts != NRF_UARTE_PSEL_DISCONNECTED)
            nrf_gpio_cfg_default(rts);
    nrfx_err_t nrfx_uarte_init(nrfx_uarte_t const *        p_instance,
                               nrfx_uarte_config_t const * p_config,
                               nrfx_uarte_event_handler_t  event_handler)
        NRFX_ASSERT(p_config);
        uarte_control_block_t * p_cb = &m_cb[p_instance->drv_inst_idx];
        nrfx_err_t err_code = NRFX_SUCCESS;
        if (p_cb->state != NRFX_DRV_STATE_UNINITIALIZED)
            err_code = NRFX_ERROR_INVALID_STATE;
            NRFX_LOG_WARNING("Function: %s, error code: %s.",
                             __func__,
                             NRFX_LOG_ERROR_STRING_GET(err_code));
            return err_code;
    #if NRFX_CHECK(NRFX_PRS_ENABLED)
        static nrfx_irq_handler_t const irq_handlers[NRFX_UARTE_ENABLED_COUNT] = {
            nrfx_uarte_0_irq_handler,
            nrfx_uarte_1_irq_handler,
            nrfx_uarte_2_irq_handler,
            nrfx_uarte_3_irq_handler,
        if (nrfx_prs_acquire(p_instance->p_reg,
                irq_handlers[p_instance->drv_inst_idx]) != NRFX_SUCCESS)
            err_code = NRFX_ERROR_BUSY;
                             __func__,
            return err_code;
    #endif // NRFX_CHECK(NRFX_PRS_ENABLED)
        apply_config(p_instance, p_config);
        p_cb->handler   = event_handler;
        p_cb->p_context = p_config->p_context;
        if (p_cb->handler)
            interrupts_enable(p_instance, p_config->interrupt_priority);
        nrf_uarte_enable(p_instance->p_reg);
        p_cb->rx_buffer_length           = 0;
        p_cb->rx_secondary_buffer_length = 0;
        p_cb->tx_buffer_length           = 0;
        p_cb->state                      = NRFX_DRV_STATE_INITIALIZED;
                         __func__,
        return err_code;
    void nrfx_uarte_uninit(nrfx_uarte_t const * p_instance)
        nrf_uarte_disable(p_instance->p_reg);
        if (p_cb->handler)
            interrupts_disable(p_instance);
        pins_to_default(p_instance);
        nrfx_prs_release(p_instance->p_reg);
        p_cb->state   = NRFX_DRV_STATE_UNINITIALIZED;
        p_cb->handler = NULL;
        NRFX_LOG_INFO("Instance uninitialized: %d.", p_instance->drv_inst_idx);
    nrfx_err_t nrfx_uarte_tx(nrfx_uarte_t const * p_instance,
                             uint8_t const *      p_data,
                             size_t               length)
        NRFX_ASSERT(p_cb->state == NRFX_DRV_STATE_INITIALIZED);
        NRFX_ASSERT(p_data);
        NRFX_ASSERT(length > 0);
        NRFX_ASSERT(UARTE_LENGTH_VALIDATE(p_instance->drv_inst_idx, length));
        nrfx_err_t err_code;
        // EasyDMA requires that transfer buffers are placed in DataRAM,
        // signal error if the are not.
        if (!nrfx_is_in_ram(p_data))
            err_code = NRFX_ERROR_INVALID_ADDR;
                             __func__,
            return err_code;
        if (nrfx_uarte_tx_in_progress(p_instance))
                             __func__,
            return err_code;
        p_cb->tx_buffer_length = length;
        p_cb->p_tx_buffer      = p_data;
        NRFX_LOG_INFO("Transfer tx_len: %d.", p_cb->tx_buffer_length);
        NRFX_LOG_DEBUG("Tx data:");
        NRFX_LOG_HEXDUMP_DEBUG(p_cb->p_tx_buffer,
                               p_cb->tx_buffer_length * sizeof(p_cb->p_tx_buffer[0]));
        nrf_uarte_event_clear(p_instance->p_reg, NRF_UARTE_EVENT_TXSTOPPED);
        nrf_uarte_tx_buffer_set(p_instance->p_reg, p_cb->p_tx_buffer, p_cb->tx_buffer_length);
        nrf_uarte_task_trigger(p_instance->p_reg, NRF_UARTE_TASK_STARTTX);
        if (p_cb->handler == NULL)
            bool endtx;
            bool txstopped;
            do
                endtx     = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_ENDTX);
                txstopped = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_TXSTOPPED);
            while ((!endtx) && (!txstopped));
            if (txstopped)
                err_code = NRFX_ERROR_FORBIDDEN;
        NRFX_LOG_INFO("Function: %s, error code: %s.", __func__, NRFX_LOG_ERROR_STRING_GET(err_code));
        return err_code;
    bool nrfx_uarte_tx_in_progress(nrfx_uarte_t const * p_instance)
        return (m_cb[p_instance->drv_inst_idx].tx_buffer_length != 0);
    nrfx_err_t nrfx_uarte_rx(nrfx_uarte_t const * p_instance,
                             uint8_t *            p_data,
                             size_t               length)
        NRFX_ASSERT(m_cb[p_instance->drv_inst_idx].state == NRFX_DRV_STATE_INITIALIZED);
                             __func__,
            return err_code;
        bool second_buffer = false;
        if (p_cb->handler)
            nrf_uarte_int_disable(p_instance->p_reg, NRF_UARTE_INT_ERROR_MASK |
                                                     NRF_UARTE_INT_ENDRX_MASK);
        if (p_cb->rx_buffer_length != 0)
            if (p_cb->rx_secondary_buffer_length != 0)
                if (p_cb->handler)
                    nrf_uarte_int_enable(p_instance->p_reg, NRF_UARTE_INT_ERROR_MASK |
                                 __func__,
                return err_code;
            second_buffer = true;
        if (!second_buffer)
            p_cb->rx_buffer_length = length;
            p_cb->p_rx_buffer      = p_data;
            p_cb->p_rx_secondary_buffer = p_data;
            p_cb->rx_secondary_buffer_length = length;
        NRFX_LOG_INFO("Transfer rx_len: %d.", length);
        nrf_uarte_rx_buffer_set(p_instance->p_reg, p_data, length);
        if (!second_buffer)
            nrf_uarte_task_trigger(p_instance->p_reg, NRF_UARTE_TASK_STARTRX);
            nrf_uarte_shorts_enable(p_instance->p_reg, NRF_UARTE_SHORT_ENDRX_STARTRX);
        if (m_cb[p_instance->drv_inst_idx].handler == NULL)
            bool endrx;
            bool rxto;
            bool error;
            do {
                endrx  = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_ENDRX);
                rxto   = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_RXTO);
                error  = nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_ERROR);
            } while ((!endrx) && (!rxto) && (!error));
            m_cb[p_instance->drv_inst_idx].rx_buffer_length = 0;
            if (error)
                err_code = NRFX_ERROR_INTERNAL;
            if (rxto)
        return err_code;
    bool nrfx_uarte_rx_ready(nrfx_uarte_t const * p_instance)
        return nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_ENDRX);
    uint32_t nrfx_uarte_errorsrc_get(nrfx_uarte_t const * p_instance)
        return nrf_uarte_errorsrc_get_and_clear(p_instance->p_reg);
    static void rx_done_event(uarte_control_block_t * p_cb,
                              size_t                  bytes,
                              uint8_t *               p_data)
        nrfx_uarte_event_t event;
        event.type             = NRFX_UARTE_EVT_RX_DONE;
        event.data.rxtx.bytes  = bytes;
        event.data.rxtx.p_data = p_data;
        p_cb->handler(&event, p_cb->p_context);
    static void tx_done_event(uarte_control_block_t * p_cb,
                              size_t                  bytes)
        event.type             = NRFX_UARTE_EVT_TX_DONE;
        event.data.rxtx.p_data = (uint8_t *)p_cb->p_tx_buffer;
    void nrfx_uarte_tx_abort(nrfx_uarte_t const * p_instance)
        nrf_uarte_task_trigger(p_instance->p_reg, NRF_UARTE_TASK_STOPTX);
            while (!nrf_uarte_event_check(p_instance->p_reg, NRF_UARTE_EVENT_TXSTOPPED))
        NRFX_LOG_INFO("TX transaction aborted.");
    void nrfx_uarte_rx_abort(nrfx_uarte_t const * p_instance)
        // Short between ENDRX event and STARTRX task must be disabled before
        // aborting transmission.
            nrf_uarte_shorts_disable(p_instance->p_reg, NRF_UARTE_SHORT_ENDRX_STARTRX);
        nrf_uarte_task_trigger(p_instance->p_reg, NRF_UARTE_TASK_STOPRX);
        NRFX_LOG_INFO("RX transaction aborted.");
    static void uarte_irq_handler(NRF_UARTE_Type *        p_uarte,
                                  uarte_control_block_t * p_cb)
        if (nrf_uarte_event_check(p_uarte, NRF_UARTE_EVENT_ERROR))
            nrf_uarte_event_clear(p_uarte, NRF_UARTE_EVENT_ERROR);
            event.type                   = NRFX_UARTE_EVT_ERROR;
            event.data.error.error_mask  = nrf_uarte_errorsrc_get_and_clear(p_uarte);
            event.data.error.rxtx.bytes  = nrf_uarte_rx_amount_get(p_uarte);
            event.data.error.rxtx.p_data = p_cb->p_rx_buffer;
            // Abort transfer.
        else if (nrf_uarte_event_check(p_uarte, NRF_UARTE_EVENT_ENDRX))
            nrf_uarte_event_clear(p_uarte, NRF_UARTE_EVENT_ENDRX);
            size_t amount = nrf_uarte_rx_amount_get(p_uarte);
            // If the transfer was stopped before completion, amount of transfered bytes
            // will not be equal to the buffer length. Interrupted transfer is ignored.
            if (amount == p_cb->rx_buffer_length)
                    uint8_t * p_data = p_cb->p_rx_buffer;
                    nrf_uarte_shorts_disable(p_uarte, NRF_UARTE_SHORT_ENDRX_STARTRX);
                    p_cb->rx_buffer_length = p_cb->rx_secondary_buffer_length;
                    p_cb->p_rx_buffer = p_cb->p_rx_secondary_buffer;
                    rx_done_event(p_cb, amount, p_data);
                    rx_done_event(p_cb, amount, p_cb->p_rx_buffer);
        if (nrf_uarte_event_check(p_uarte, NRF_UARTE_EVENT_RXTO))
            nrf_uarte_event_clear(p_uarte, NRF_UARTE_EVENT_RXTO);
                // In case of using double-buffered reception both variables storing buffer length
                // have to be cleared to prevent incorrect behaviour of the driver.
                rx_done_event(p_cb, nrf_uarte_rx_amount_get(p_uarte), p_cb->p_rx_buffer);
        if (nrf_uarte_event_check(p_uarte, NRF_UARTE_EVENT_ENDTX))
            nrf_uarte_event_clear(p_uarte, NRF_UARTE_EVENT_ENDTX);
            if (p_cb->tx_buffer_length != 0)
                tx_done_event(p_cb, nrf_uarte_tx_amount_get(p_uarte));
    void nrfx_uarte_0_irq_handler(void)
        uarte_irq_handler(NRF_UARTE0, &m_cb[NRFX_UARTE0_INST_IDX]);
    void nrfx_uarte_1_irq_handler(void)
        uarte_irq_handler(NRF_UARTE1, &m_cb[NRFX_UARTE1_INST_IDX]);
    void nrfx_uarte_2_irq_handler(void)
        uarte_irq_handler(NRF_UARTE2, &m_cb[NRFX_UARTE2_INST_IDX]);
    void nrfx_uarte_3_irq_handler(void)
        uarte_irq_handler(NRF_UARTE3, &m_cb[NRFX_UARTE3_INST_IDX]);
    #endif // NRFX_CHECK(NRFX_UARTE_ENABLED)
  • Hi
    Please try uninitializing the UARTE by stopping RX/TX operations, calling the uninit function, and then power cycling the UART peripheral, please see the snippet below:
    void disabled_uart(void) {
      uint32_t err_code = app_uart_close();
    //  APP_ERROR_CHECK(err_code);
      NRF_UARTE0->TASKS_STOPTX = 1;
      NRF_UARTE0->TASKS_STOPRX = 1;
      NRF_UARTE0->ENABLE = 0;
      /* Workaround by disabling the UART peripherals due to Nordic SDK15.0 issue */
      *(volatile uint32_t *)0x40002FFC = 0; /* Power down UARTE0 */
      *(volatile uint32_t *)0x40002FFC;
      *(volatile uint32_t *)0x40002FFC = 1; /* Power on UARTE0 so it is ready for next time */
    What exactly is happening is explained in this post if you got any questions on this procedure.
    Simon
  • Hi Simon,
    We are getting error while building the code.
    It shows missing structure of “mst_uartConfig” at the time of build.
    please give us suggestion to resolve the error.
    kindly refer the attached image file for the error message.
    Thanks and Regards,
    venu
