Can we get a 16MHz clock out over a GPIO pin? We could use this to clock some downstream devices.
The GPIO module runs on 16M so the theoretical max. frequency is limited to 8Mhz, unfortunately.
Thanks for the quick response. Would it be possible then to get an 8MHz clock out over a GPIO pin? Could you provide some example code?
Yes, it should be possible. I made the code below that you can use to test this.
#include <stdbool.h>
#include <stdint.h>
#include "boards.h"
void gpio_clock_8m(uint32_t pin_number)
NRF_TIMER1->PRESCALER = 0; // 16MHz
NRF_TIMER1->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Msk;
NRF_TIMER1->CC[0] = 1;
NRF_GPIOTE->CONFIG[0] = GPIOTE_CONFIG_MODE_Task | (pin_number << GPIOTE_CONFIG_PSEL_Pos) |
(GPIOTE_CONFIG_POLARITY_Toggle << GPIOTE_CONFIG_POLARITY_Pos);
/*Connect TIMER event to GPIOTE out task*/
NRF_PPI->CH[0].EEP = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[0];
NRF_PPI->CH[0].TEP = (uint32_t) &NRF_GPIOTE->TASKS_OUT[0];
NRF_PPI->CHENSET = 1;
/*Starts clock signal*/
NRF_TIMER1->TASKS_START = 1;
* @brief Function for application main entry.
/*Start HF crystal for improved clock tolerance*/
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
gpio_clock_8m(27);
for (;;)
__WFE();
Also, in case you haven't noticed, some pins are not recommended for high-frequency I/O operation (may interfere with RADIO). See the "Pin assignments" section of the PS to see which pins this applies to.
Thank you, this is extremely helpful. Yes, we will double-check to ensure we don't use a Radio sensitive pin. I appreciate your very quick response.
No problem. I hope the clock output characteristics meet your requirements.
