SOFTDEVICE_PRESENT versus sd_softdevice_is_enabled()
Hello -
We are developing some low power code on the nRF52840-DK, using SDK 15.3.0 on FreeRTOS. I noticed that in the port_cmsys_systick.c file, in the vPortSuppressTicksAndSleep() function, that the code just checks if SOFTDEVICE_PRESENT is defined before calling a SoftDevice function:
#ifdef SOFTDEVICE_PRESENT
        uint32_t err_code = sd_app_evt_wait();
#else
In our case, we currently enable the SoftDevice when requiring BLE, but otherwise we do not request that the SoftDevice is enabled. In other words, we only call nrf_sdh_enable_request() when using BLE. We do however have SOFTDEVICE_PRESENT defined in our Makefile.
I am wondering if the port_cmsys_systick.c code is correct when the application does not have a SoftDevice enabled. At first glance it seems that defining SOFTDEVICE_PRESET implicitly assumes that the SoftDevice has been enabled, which may not be the case.
Brian
  • H
    this seems to be addressed in SDK v16.0.0, where sd_app_evt_wait() is wrapped in a   if (nrf_sdh_is_enabled()) statement, see below
    Here is the complete vPortSuppressTicksAndSleep function from port_cmsis_systick.c in SDK v16.0.0
    void vPortSuppressTicksAndSleep( TickType_t xExpectedIdleTime )
         * Implementation note:
         * To help debugging the option configUSE_TICKLESS_IDLE_SIMPLE_DEBUG was presented.
         * This option would make sure that even if program execution was stopped inside
         * this function no more than expected number of ticks would be skipped.
         * Normally RTC works all the time even if firmware execution was stopped
         * and that may lead to skipping too much of ticks.
        TickType_t enterTime;
        /* Make sure the SysTick reload value does not overflow the counter. */
        if ( xExpectedIdleTime > portNRF_RTC_MAXTICKS - configEXPECTED_IDLE_TIME_BEFORE_SLEEP )
            xExpectedIdleTime = portNRF_RTC_MAXTICKS - configEXPECTED_IDLE_TIME_BEFORE_SLEEP;
        /* Block all the interrupts globally */
        do{
            uint8_t dummy = 0;
            uint32_t err_code = sd_nvic_critical_region_enter(&dummy);
        }while (0);
    #else
        __disable_irq();
        enterTime = nrf_rtc_counter_get(portNRF_RTC_REG);
        if ( eTaskConfirmSleepModeStatus() != eAbortSleep )
            TickType_t xModifiableIdleTime;
            TickType_t wakeupTime = (enterTime + xExpectedIdleTime) & portNRF_RTC_MAXTICKS;
            /* Stop tick events */
            nrf_rtc_int_disable(portNRF_RTC_REG, NRF_RTC_INT_TICK_MASK);
            /* Configure CTC interrupt */
            nrf_rtc_cc_set(portNRF_RTC_REG, 0, wakeupTime);
            nrf_rtc_event_clear(portNRF_RTC_REG, NRF_RTC_EVENT_COMPARE_0);
            nrf_rtc_int_enable(portNRF_RTC_REG, NRF_RTC_INT_COMPARE0_MASK);
            __DSB();
            /* Sleep until something happens.  configPRE_SLEEP_PROCESSING() can
             * set its parameter to 0 to indicate that its implementation contains
             * its own wait for interrupt or wait for event instruction, and so wfi
             * should not be executed again.  However, the original expected idle
             * time variable must remain unmodified, so a copy is taken. */
            xModifiableIdleTime = xExpectedIdleTime;
            configPRE_SLEEP_PROCESSING( xModifiableIdleTime );
            if ( xModifiableIdleTime > 0 )
                    /* No SD -  we would just block interrupts globally.
                    * BASEPRI cannot be used for that because it would prevent WFE from wake up.
                    do{
                        __WFE();
                    } while (0 == (NVIC->ISPR[0] | NVIC->ISPR[1]));
            configPOST_SLEEP_PROCESSING( xExpectedIdleTime );
            nrf_rtc_int_disable(portNRF_RTC_REG, NRF_RTC_INT_COMPARE0_MASK);
            /* Correct the system ticks */
                TickType_t diff;
                TickType_t exitTime;
                nrf_rtc_event_clear(portNRF_RTC_REG, NRF_RTC_EVENT_TICK);
                nrf_rtc_int_enable (portNRF_RTC_REG, NRF_RTC_INT_TICK_MASK);
                exitTime = nrf_rtc_counter_get(portNRF_RTC_REG);
                diff =  (exitTime - enterTime) & portNRF_RTC_MAXTICKS;
                /* It is important that we clear pending here so that our corrections are latest and in sync with tick_interrupt handler */
                NVIC_ClearPendingIRQ(portNRF_RTC_IRQn);
                if ((configUSE_TICKLESS_IDLE_SIMPLE_DEBUG) && (diff > xExpectedIdleTime))
                    diff = xExpectedIdleTime;
                if (diff > 0)
                    vTaskStepTick(diff);
        uint32_t err_code = sd_nvic_critical_region_exit(0);
    #else
        __enable_irq();
    Best regards
    Bjørn
  • Hello -
    Thank you for the quick follow-up. In the v16.0.0 code, I see that sd_nvic_critical_region_enter() and sd_nvic_critical_region_exit() also seem to have the same issue:
    do{
    uint8_t dummy = 0;
    }while (0);
    #else
    __disable_irq();
    Is it okay to call sd_nvic_critical_region_enter() and sd_nvic_critical_region_exit() when the SoftDevice is not enabled?
    Brian
  • No, any function with a sd_-prefix will normally require the SoftDevice to be enabled. So if you're going to have the SoftDevice present but not always enabled, then I would wrap these sections in if (nrf_sdh_is_enabled())
    statements.
