Hello
I simply wanted to build an executable from a customized nrfutil. Ran the "pyinstaller nrfutil.spec" and afterwards started the nrfutil.exe from command line. This reported the import error "no module named package". After ensuring that the module exists, and after adding the path explicitly to the pathex variable in the .spec file, ths error remained. Having a look into the "warn-nrfutil.txt" i noticed that the module warning was written as "invalid module named package" and not "missing module named package". It seems that pyinstaller had found the module but classified it as invalid.
As a next step, I wanted to see if the error can be reproduced on another pc with a new and clean installation of the python environment and an untouched download of the latest nrfutil release's source from GitHub. The result was similar but not exactly the same.
Version of python: 2.7.16 (installed using the miniconda 2 installer)
Source for nrfutil: v6.0 (release from GitHub)
Step 1: Build Exe with "pyinstaller nrfutil.spec"
Step 2: Run Exe in subdirectory "dist"
---> Command Shell: ImportError: No module named crc16
---> warn-nrfutil.txt: invalid module named nordlicsemi.dfu.crc16
What is the reason for that?
